» BMFA. UK AUCTIONby Coxfledgling Today at 10:54 am
» Cox Star Cruiser Instruction/Manuel/Information
by DanMc Today at 9:47 am
» COX .020 POWERED SPEEDSTER
by 1/2A Nut Today at 8:50 am
by rsv1cox Today at 7:44 am
» Pt19 pilot and windshield
by howardhb Today at 7:24 am
by roddie Yesterday at 5:50 pm
by Admin Yesterday at 4:06 pm
by Cox International Yesterday at 12:32 pm
» Stealth SB-X
by getback Yesterday at 8:15 am
by Ken Cook Yesterday at 3:39 am
by rsv1cox Sun Oct 20, 2024 8:04 pm
by roddie Sun Oct 20, 2024 5:44 pm
Cox 020 PeeWee rebuild questions
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Cox 020 PeeWee rebuild questions
With the flat side ( 2nd photo) facing the backplate, I would give it a try...the other side (1st photo) shows a not that smooth surface with which sealing may not be perfect.
balogh wrote:With the flat side ( 2nd photo) facing the backplate, I would give it a try...the other side (1st photo) shows a not that smooth surface with which sealing may not be perfect.
I agree.. the smooth-side looks good.. and should be tried facing/against the sealing "mouth" of the venturi-tube. Once the retaining circlip is properly installed; you "shouldn't" be able to BLOW any air past the reed when blowing from the "clip-side". You "should" be able to SUCK air past the reed. This is how the engine meters fuel on every stroke.. and it has to be a positive on-off action.. for the engine to continue running on fuel from the tank.
» Cox Tee Dee .049 Rebuild ...
» Tee Dee Engine rebuild
» Ez Bee rebuild
» TD rebuild .049
» Tee Dee .09 rebuild.. and run!
» Ez Bee rebuild
» TD rebuild .049
Page 3 of 3
