» BMFA. UK AUCTIONby Coxfledgling Today at 10:54 am
» Cox Star Cruiser Instruction/Manuel/Information
by DanMc Today at 9:47 am
» COX .020 POWERED SPEEDSTER
by 1/2A Nut Today at 8:50 am
by rsv1cox Today at 7:44 am
» Pt19 pilot and windshield
by howardhb Today at 7:24 am
by roddie Yesterday at 5:50 pm
by Admin Yesterday at 4:06 pm
by Cox International Yesterday at 12:32 pm
» Stealth SB-X
by getback Yesterday at 8:15 am
by Ken Cook Yesterday at 3:39 am
by rsv1cox Sun Oct 20, 2024 8:04 pm
by roddie Sun Oct 20, 2024 5:44 pm
What's the Best Reed for Cox Reed Valve Engines.
Page 2 of 2
Page 2 of 2 • 1, 2
Re: What's the Best Reed for Cox Reed Valve Engines.
Was your left handed prop a Cox? The only known left handed prop that I'm aware of that Cox made was a 6x2. In my opinion is nothing more than a air beater. It was designed for beginners and it doesn't have enough pitch to make the model fly fast enough. However, you stating the rpm's were down using one leads me to believe you were using a Tornado yellow pusher prop.
I also commend your choice of plane. I too, use a ARF Baby Clown. I was just able to sneak a Perfect tank between the leading edge and the back of the nylon motor mount. I did replace the fuse. The stock fuse was typical punk wood that Brodak uses. Light as a can be with no strength. The screws were pulling through the fuse and plastic motor mount once oil migrated under the covering destroyed it.
I did away with the two gear landing gear and went with a single. Overall though the Brodak Baby Clown uses a fairly large Hershey bar wing. I built a PDQ Baby Clown and it looks nothing like the Brodak offering. The Brodak Baby Clown will do the pattern with clarity.
Page 2 of 2 • 1, 2
» Reed Valve
» Cylinder shimming
» Reed Valve Material
» Car and plane .049 Reed valve engines crankchaft difference
» Pee Wee .020 Reed Valve
» Cylinder shimming
Page 2 of 2
