Landing-gear tips Cox_ba12
Landing-gear tips Pixel
by rdw777 Today at 4:49 pm
by rdw777 Today at 3:21 pm
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Landing-gear tips Empty
Landing-gear tips
Landing-gear tips Empty Landing-gear tips
Post  roddie Today at 1:58 pm
Feel free to post "yours"..  Smile
I keep an assortment of K & S alloy tubing on hand for a variety of uses.. and one of those uses is for axle-bushings. Having telescoping-pieces on-hand, allows the use of a wheel having a larger hub-diameter; to be fitted to an axle having a smaller diameter.
Some K & S from my stock..
A cut-off assortment; mostly Aluminum and Brass.. but some Copper and thick-wall random pcs. VERY handy to have.
Landing-gear tips K__s_t10
Recently sourced telescopic Aluminum tubes; 12" length.
Landing-gear tips K__s_a10
Landing-gear tips K__s_a11
Cutting short pieces of the tubing is best done using a Dremel-type rotary-tool with a cut-off wheel/mandrel. Do the cutting inside of a cardboard (4-gallon) box, open at the top.. with holes cut in the sides for your hands/forearms to fit through loosely. This helps prevent loosing the piece that you're cutting. Don't forget to use safety-glasses.. as a matter of fact; store a pair inside the box for whenever you use it.
Landing-gear tips Dremel10
I know.. it's one more thing to take-up space in your shop.. but it could double as a "photo-platform" if flipped-over and draped with a piece of cloth.. or maybe even an air-brush spray-booth..  Laughing
and yes; we're still on Landing-gear tips..  tongue
Landing-gear tips Empty A sprung tricycle nose-gear for profile fuse
Post  roddie Today at 2:52 pm
I came up with this arrangement for my P-38 Lightning.. I replaced a double-coil/.045" dia. music-wire strut with a beefier single-coil/.062" dia. one. A short inverted "L-bend" at the top of the strut; locks it from rotating L/R.
A hardwood block "insert" was made.. which retains the L-bend with a single steel strap with wood-screws.
Landing-gear tips New_no13
I used a similar L-bend retention system for "mains" on my current twin-engine project.. which will be a tail-dragger.
The strut lays in a slot and gets sandwiched between two plywood discs which are glued with epoxy.
Landing-gear tips 20241154
Landing-gear tips 20241153
Landing-gear tips 20241152
Landing-gear tips Empty Gear-blocks
Post  roddie Today at 4:22 pm
When I designed my Rare Bear for the 1st CEF Reed Speed contest (2014) I wanted a more scale/wider-stance on the mains; than what a standard inverted-V gear would provide... but I knew that my 1/8" balsa sheet-wing would need to support the two separate struts. What I did was to construct my sheet-wing with a 1/2-span strip-spar made of hardwood, for gear-blocks to tie-into.
The gear-blocks were also made from hardwood. I used some 3/8" (10mm) square-stock to make them. The block is first drilled-through and slotted to accept the music-wire. Once inserted into the block; the music wire can then be bent 90 degrees to lay in the slot. This will lock the strut in place when mounted to the spar.
Landing-gear tips 11-14-13
Landing-gear tips 11-18-12
Landing-gear tips 11-19-22
Landing-gear tips 11-19-24
Landing-gear tips 11-19-23
Landing-gear tips 1-24-110
The "mains" on my P38 had very similar hardwood gear-blocks.. except that they were "epoxied" into the 90 degree intersection of the sheet-wing and profile-fuse.
Landing-gear tips Dsc05235
Landing-gear tips Dsc05236
Landing-gear tips Dsc05237
Landing-gear tips Dsc05318
Landing-gear tips Dsc05319
Landing-gear tips 20201235
Landing-gear tips Dsc05812
Landing-gear tips 3-30-110
I'll admit; it's the fabricating/building that I enjoy the most!  Smile
Landing-gear tips Empty Re: Landing-gear tips
Post  rdw777 Today at 4:49 pm
Roddie wrote:I'll admit; it's the fabricating/building that I enjoy the most!  Smile
I like the building and fab part too Roddie….. Sometimes, Well maybe most of time, A part doesn’t exist to what we have envisioned ….With model building much of it tends to be mechanically oriented…..Fabbing the individual parts makes finished  “whole “ seem very satisfying Very Happy
