Tee Dee Engine rebuild Cox_ba12
Tee Dee Engine rebuild Pixel
by Admin Today at 1:35 am
» Engine choice
Tee Dee Engine rebuild Empty
Tee Dee Engine rebuild Empty Tee Dee Engine rebuild
Post  fargophil Thu Jan 06, 2022 9:51 pm
In the process of rebuilding an old Tee Dee .049.Removed the venthri and needle valve, when I did so a small flat plastic piece cam off. I presume it is a gasket for the m\needle valve and goes under the needle valve when reinstalling the venturi?
fargophil
fargophil
Bronze Member
Bronze Member
Tee Dee Engine rebuild Empty Re: Tee Dee Engine rebuild
Post  Cribbs74 Thu Jan 06, 2022 10:08 pm
Nope. Not a gasket. The venturi is a direct fit into the carb body. It could be a aluminum spacer that Cox sold separately when using a muffler on a TD to clear the venturi.
Unless you are talking about the black steel spring that is used to keep the needle from rotating. That does go under the needle valve body.
Post  fargophil Thu Jan 06, 2022 10:21 pm
Upon further inspection I do believe that is what it is. Thanks.
fargophil
fargophil
Bronze Member
Bronze Member
