» The Beaver chainsaw, Cox's most interesting productby EXModelEngines Today at 7:12 pm
» CO2 Engine
by kakariki53 Today at 6:49 pm
by balogh Today at 6:23 pm
by MauricioB Today at 3:44 pm
by roddie Today at 2:53 pm
by rdw777 Today at 1:46 pm
» 'Tweeners...
by rdw777 Today at 1:28 pm
by davidll1984 Today at 11:52 am
by davidll1984 Today at 7:48 am
» Black Widow Question
by Ken Cook Today at 7:05 am
» Inverted flying cub
by ppvj64 Today at 6:49 am
» Jim Walkers Firebabies with a story.
by rsv1cox Yesterday at 6:27 pm
Cox .020 PeeWee/TeeDee prop-screw
It's a size 3-48 UNC machine-screw. Now for my story; Up until this past week, I'd never owned a model engine smaller than .049 cu.in. I'd never even "held one" in my hand.. then I got a letter from my brother from another mother.. "Eric" (@getback) telling me that something was coming in the mail... but he didn't let-on as to what it was..
A PeeWee!!!!
There's something about a handwritten letter... So it just needed a prop-screw.
I have a stock of 3-48 X 1" length cap-screws (black oxide coated) so I cut a few to the required length. This engine's crankshaft bore had a depth of close-to 3/8" (10mm).. but I found that the 3-48 threads weren't tapped nearly that deep. Just-over 1/4" or maybe 7mm.
My screw kept running-out of threads before the propeller would tighten up..
89
I didn't have any flat-washers the correct size (which naturally bothered me.. ) so I came up with an unlikely adaptation. I have a stock of 3-48 lock-nuts.. so I decided to drill-out the threaded (steel) section to receive the body of my 3-48 cap-screws (.098") and then drilled-out the plastic (lock) part of the nut to receive the screw-head.. (.159") which provided a consistent bearing-surface on the prop-hub.. when snugged-up.
That's gonna' work just fine.. and I like the look..
A PeeWee!!!!
89
Re: Cox .020 PeeWee/TeeDee prop-screw
Good for Eric filling a void with a nice shiney Cox Pee Wee engine. And a great fix on the prop screw. Winners all the way around.
Roddie, the prop screw fix looks real good, almost scale like, looks like that .020 has potential for a Cox Engine of the Month winner.
Bernie of COX International sells socket head screws of the required dimensions for engine mounting purposes, and I replaced the slot round headed stock screw on my COX TeeDee020 with a socket head screw, that allows better tightening of the prop than the stock...I do not have any screws with American thread sizes here in our hardware stores..
https://coxengines.ca/mounting-screws/cox-049-engine-mounting-3-48-x-1-2-socket-head-screws-3-4.html
Only 1/2" long instead of 3/4", so will not work with a spinner, but just long enough for the hubs of props for 020 engines.
What a kind gesture by Eric, Those kinds of things will never be forgotten!!!….
You’ll enjoy the PeeWee Roddie…. Special little jewels with a lot of potential!!
rdw777- Diamond Member
Hey roddie , glad you had some screws to make it work looks like it will work just fine I know you said a few times you didn't have a Pee Wee soooooo now you do .
Bee sure to take a vedio when you run it
Now you can find anther project for it fun all the way around
PS Roddie had sent me a bunch of goodies also I had the stuff out and forgot to take any pictures I will pretty soon though going to need to et some things out of the box
» Broken prop screw Pee Wee .020
» COX 010 TeeDee prop screw
» mitch's super .051, will it work?
» RC TeeDee 020 vs RC PeeWee?
» Question Cox .020 prop screw size
