mitch's super .051, will it work? Cox_ba12
mitch's super .051, will it work? Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
mitch's super .051, will it work? Empty
mitch's super .051, will it work? Empty mitch's super .051, will it work?
Post  mitchg95 Fri Jun 15, 2012 3:01 pm
ive been wanting to build a custom .051 for speed, do you think this will work?
golden bee, gas tank, crankcase, black prop driver
teedee .051 cyl/piston
hi-comp glow head
cox car heat sink head
4.5''x4'' gray propellor
hi-performance mylar reed
hi nitro fuel
and the other normal parts that are in cox engines
will the heat sink head inprove speed because of the added cooling?
thanks
mitchg95
mitchg95
mitch's super .051, will it work? Empty Re: mitch's super .051, will it work?
Post  EXModelEngines Fri Jun 15, 2012 3:34 pm
Yeah, that would probably work nicely. You would probably have to run a few tests to see how much of a difference the heat sink actually makes.
I'd suggest (on top of what you already have written) a killer bee crankshaft installed in the crankcase of your choice and scrap the tank assembly and go with a killer bee style. Your going to be pulling a lot of fuel and using an external tank will help prolong run-times if you have the space in your plane.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  mitchg95 Fri Jun 15, 2012 3:37 pm
EXModelEngines wrote:Yeah, that would probably work nicely. You would probably have to run a few tests to see how much of a difference the heat sink actually makes.
Matt
thanks, i forgot to add the kb crank in the first post, stronger and lighter for better performance
wonder what kinda rpm this thing would do if i could get 50% nitro
mitchg95
mitchg95
Post  EXModelEngines Fri Jun 15, 2012 3:48 pm
Matt
50% might be pushing it with the TD 051 cylinder & piston. Not to say it cannot be done, but the wear you will be putting on that is going to reduce the life of a hard to get part.
I'd use a regular cylinder/piston. If you want to play around I have a bunch of modified Sure Start style ones that I use for testing. I could always send you a couple.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  mitchg95 Fri Jun 15, 2012 3:50 pm
Matt
Matt
good advice, i deffinetly dont want to reduce the life of a hard to get part. The sure start sounds like a great idea to fool around with mods and what not, what were you thinkin on the surestarts?
mitchg95
mitchg95
Post  John Goddard Fri Jun 15, 2012 5:19 pm
Yep the 60% wore my piston out in a dozen tanks or so.
As well as the KB crankshaft you'll need to put a PT19
Style stud in with a nut instead of a prop screw otherwise
A couple runs over 23/24 k and the prop screw will shear
The crank.
Good luck
John Goddard
John Goddard
Post  mitchg95 Fri Jun 15, 2012 5:22 pm
John Goddard wrote:Yep the 60% wore my piston out in a dozen tanks or so.
The crank.
Good luck
like this one? http://coxengines.ca/cox-.049-hub-nut-balancing-weight.html
mitchg95
mitchg95
Post  John Goddard Fri Jun 15, 2012 7:32 pm
Bingo
Very Happy
John Goddard
John Goddard
Post  mitchg95 Fri Jun 15, 2012 7:33 pm
sweet!!! tach race is in december right.....
mitchg95
mitchg95
mitch's super .051, will it work? Empty re: prop screw
Post  happydad Fri Jun 15, 2012 8:36 pm
The crank.
Good luck
John Goddard and others: i as well as others have purchased hardened steel caphead or buttonhead, (hex), screws which tend to last longer than the normal steel prop screws. they cost a bit more, but last longer.
happydad
Futaba Radio
happydad
happydad
Post  John Goddard Sat Jun 16, 2012 3:15 am
Many ways to skin a cat HD.
I went the stud+nut route for 2 reasons
1, it's what Paul (see sticky about mouse racers) recommends.
2, any motor racing bod worth their salt replaces bolts throughout
Their motors with studs and nuts. Particularly head bolts and
Rod bolts.
Another couple observations I'd make is a stud screws All the way home
A bolt can't, also a hardened bolt is not a High Tensile bolt
I don't think you'll be able to get a HT bolt in 2.56 (or whatever
The prop bolt is) I doubt
They exist. Certainly in Europe the authorities won't
Certify an M3 bolt.
Finally I have had a bolt/crank failure which I think was in
My original 'Raw Power' thread.
We are routinely seeing speeds 10 % higher than the tach
Race winners of only 6 months ago. When everyone's
Engine is spinning over 22k there will be failures at
Kim's place next year if anyone would like a side
Bet my money's on the bee cranked non studded
Mota's
Very Happy
John Goddard
John Goddard
Post  SuperDave Sat Jun 16, 2012 9:05 am
Mitch:
Describe the type of aircraft you wish to power with this "Super .051".
(Just curious)
SuperDave
SuperDave
Post  EXModelEngines Sat Jun 16, 2012 9:49 am
Matt
Matt
If you place an order I'd throw a couple cylinders I have played around with modifying in for no charge. I'd be interested to hear about the results in different setups.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  mitchg95 Sat Jun 16, 2012 12:25 pm
SuperDave wrote:Mitch:
(Just curious)
i did not really have a plane in mind, i was thinking of it being a test stand king
mitchg95
mitchg95
Post  mitchg95 Sat Jun 16, 2012 12:26 pm
Matt
Matt
Matt
ill have to get one of those prepaid visa cards, as i do not have a credit card of my own yet. Ill try to place another order sometime in the next week.
mitchg95
mitchg95
Post  EXModelEngines Sat Jun 16, 2012 12:30 pm
Matt
Matt
Matt
Could order from me directly, like you did before. Credit card, PayPal, money order, personal check are all forms of payment we accept.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  mitchg95 Sat Jun 16, 2012 12:34 pm
Matt
Matt
Matt
Matt
how bout' this? been wanting to get one for a while now http://www.exmodelengines.com/product.php?productid=17676&cat=267&page=1
mitchg95
mitchg95
Post  EXModelEngines Sat Jun 16, 2012 12:47 pm
Sure, whatever you need.
Send me an email sales@exmodelengines.com and we can discuss.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  mitchg95 Sat Jun 16, 2012 12:49 pm
EXModelEngines wrote:Sure, whatever you need.
Matt
sounds good Matt
mitchg95
mitchg95
Post  mitchg95 Sat Jun 16, 2012 4:04 pm
ill deffinetely keep you guys posted on this engine as i build her, ill try to get running photos and a video, first i have to build then get a new tach, mine broke :'(
mitchg95
mitchg95
mitch's super .051, will it work? Empty re: tach
Post  happydad Sat Jun 16, 2012 4:16 pm
mitchg95 wrote:ill deffinetely keep you guys posted on this engine as i build her, ill try to get running photos and a video, first i have to build then get a new tach, mine broke :'(
mitchg95: tachs are cheap. hobby people has them on sale every month or so for $9,95 or $15.95 or ???
HD
Futaba Radio
happydad
happydad
Post  mitchg95 Sat Jun 16, 2012 4:18 pm
HD
Futaba Radio
i will have to check that out and maybe order one Smile deffinetly need it to tune 4-stroke model engines because you cant tune them by sound like you can with a 2-stroke engine
mitchg95
mitchg95
Post  mitchg95 Sat Jun 16, 2012 5:45 pm
(Just curious)
what might you suggest Dave, im thinking Piper Super Cub
mitchg95
mitchg95
