by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Stripped glow-plug threads?
The 1/4-32 thread is not a real common size at your local hardware store... If you accidentally "cross-thread" a glow-plug you'll need to re-tap the hole in the head. Some people "chase" the threads on their plugs, as a "safety measure"; just in case there's a "burr"... (which "un-noticed"... can ruin your day)
McMaster-Carr Co. stocks this uncommon size tap... as well as the "threading die"
1/4-32 TAP(s)
http://www.mcmaster.com/#standard-taps/=okb9ak
1/4-32 THREADING DIE
http://www.mcmaster.com/#standard-threading-dies/=okbcrs
1/4-32 TAP(s)
Re: Stripped glow-plug threads?
Yes, thanks for that Roddie.
Good idea.
2-56 and 5-40 are also good
ones to have on hand for Cox's.
Good idea.
dckrsn- Diamond Member
You can root about on ebay and get chasing dies and taps for a whole lot less than McMaster-Carr. For the number of times you can expect it used a carbon steel tap or die that is kept with oil will outlast you. HSS (high speed steel) is more rust resistant, but still can rust.
I just ordered a couple taps and a chasing die for $20 from the 'bay, shipping included.
Bob, did you read my other post from today? (link below) Most "hard-to-find" engine hdwe. that is common to our engines; can be found at McMaster-Carr Co.dckrsn wrote:Yes, thanks for that Roddie.
Good idea.
https://www.coxengineforum.com/t5656-5-40-nuts-for-using-a-prop-stud
1/4" x 32 glow plug taps and dies also used to be made by "Harry Higley" and were available at most hobby shops. Perhaps not so much since the electric revolution.
gcb- Platinum Member
Hey Phil, That's definitely a good deal. McMaster-Carr isn't cheap... but you can usually obtain "hard-to-find" hdwe. there... especially when it comes to 5-40 screws/nuts/studs... Did you see my other post today?pkrankow wrote:You can root about on ebay and get chasing dies and taps for a whole lot less than McMaster-Carr. For the number of times you can expect it used a carbon steel tap or die that is kept with oil will outlast you. HSS (high speed steel) is more rust resistant, but still can rust.
Oh yeah, I caught that.roddie wrote:Bob, did you read my other post from today? (link below) Most "hard-to-find" engine hdwe. that is common to our engines; can be found at McMaster-Carr Co.
Been using McMaster, Grainger and MSC for years, at work and home.
I use those same suppliers when I need to. Don't forget Fastenal and the local welding supply houses. The MSC big book is awesome for gluing fuselage doublers. I have a hard time stomaching the combined price of a premium product, and shipping, when I know a tool is only going to be used a few times.dckrsn wrote:Oh yeah, I caught that.roddie wrote:Bob, did you read my other post from today? (link below) Most "hard-to-find" engine hdwe. that is common to our engines; can be found at McMaster-Carr Co.
I chased a glow plug with 1/4-28 once. it don't work, but the threads are PRETTY!
» Stripped Glow Plug
» Exact Threads of screw in glow plug igniters
» Glow Head Threads and Never-Seize
» Cox Tee Dee high-compression glow head question
» Cox .09 glow plug ?
