Tee Bee build
Tee Bee build
Thanks for your interest.
The engine posted in the Cox Engine of the Month is my first prototype. It was designed to improve consistent running of a Bee style engine. The venturi internal diameter is sized for proper fuel draw on suction. The TD crankshaft/ front housing is mounted like Enya engines, using 4 screws. The engine was designed and built without drawings. Everything new was hand fitted. A No. 1 cylinder and low compression head was used for break in. The engine was run using 10% nitro and a 6x3 prop. RPMs was a steady13k.
coxaddict- Gold Member
Re: Tee Bee build
very cool
cox24711- Platinum Member
Re: Tee Bee build
Looks like a fun build wtg
Re: Tee Bee build
Very nice work! It looks great!
fit90- Diamond Member
Tee Bee build
I noticed a spring in the fuel supply line , have you tried this before on Tee Dee engines?
I've had trouble getting my TD to draw fuel from a tank.
Nice looking work!
Nice looking work!
RK Flyer- Gold Member
Re: Tee Bee build
NICE!! you did a very good job on the machining and looks thought out to what you wanted , 13K is a good start out with a steady run with only 10% nitro . getback
Re: Tee Bee build
Thanks for all the compliments.
The hardest part in this build was deciding what steps to take machining the parts. I am not a trained machinist and any one with a lathe and mill can build one. It all starts with an idea, and CEF fueled the fire!
After watching Rusty's demonstration on the spring verses no spring I felt that having one in there should help keep fuel in the line. Never thought of using it on a tanked TD though.
I also have Cox based twins both geared and grafted case. All are prototypes and all are designed to be flown.
will post in the future.
Mahalo
coxaddict
Mahalo
coxaddict
Re: Tee Bee build
THANKS AGAIN Mahalo !! keep up the good work getback
» The RMH Bipe build thread
» 1/2A FW 190 Build
» 2x4 kit build
» 1/2A FW 190 Build
» 2x4 kit build
