Need Norvel engine help Cox_ba12
Need Norvel engine help Pixel
by rsv1cox Today at 9:47 am
by TD ABUSER Today at 12:50 am
by 1975 control line guy Yesterday at 10:35 pm
by 706jim Yesterday at 9:32 pm
by TD ABUSER Yesterday at 2:58 pm
» Pathé Modeling Videos
by rdw777 Yesterday at 10:28 am
by roddie Tue Nov 12, 2024 3:27 pm
Need Norvel engine help Empty
Need Norvel engine help Empty Need Norvel engine help
Post  batjac Sat Jan 25, 2014 12:20 am
Well, I went back to cleaning my desk again.  And, again, I got sidetracked.  I have these two Norvel engines.  Both came from LMH helicopters.  They both have the thrust washer for the LMH heli clutch, and both are threaded for 5-40 bolts.  My question is about the numbers on the side.  One engine is numbered 6100166 and the other is 7122014.  Does this mean that the first engine is a .061 Vmax6 engine and the second one is a .074 Vmax7 engine?  I don't know why the one on the right has a long tube on the venturi and the other has a short tube, unless LMH decided later on that the longer tube got cooler, cleaner air somehow by moving the suction point away from the crutch?
Need Norvel engine help DSCN1063_zpsc2b0221d
The only other markings are on the other side on the upper cylinder area.  The one with the number 6100166 has 1.0BEP written on it:
Need Norvel engine help DSCN1065_zpsc0d08151
The one with the number 7122014 has unclear writing.  It looks like 1.0BP-PY maybe?
Need Norvel engine help DSCN1068_zps542faa36
Any ideas what these numbers mean?  I'd ask this on the Norvel forum, but no one has posted to that forum in months.
Also, I was just curious.  Has anyone ever ran a Norvel engine with .049 glow head?  I'd imagine the compression drops, and therefore the speed.  But, it should run okay, yes?  Just a stray thought.
The Mix n' Match Mark
Need Norvel engine help Empty Re: Need Norvel engine help
Post  ekitten2 Sat Jan 25, 2014 12:53 am
yes i have run a norvel with a cox head...only because i need that engine running ...an yes the power was down
ekitten2
ekitten2
Post  Surfer_kris Sat Jan 25, 2014 1:01 am
I don't know much about the helicopters, but both engines are .061 in size (from the marking on the left side) so they would both have been in/for the Vmax6, I would assume.
The heads are the same for the .049 and .061 engines.
Surfer_kris
Surfer_kris
Post  batjac Sat Jan 25, 2014 4:40 am
Surfer_kris wrote:I don't know much about the helicopters, but both engines are .061 in size (from the marking on the left side) so they would both have been in/for the Vmax6, I would assume.
So the 1.0 BEP somehow equates to 1cc displacement?
The Student Mark
Post  Surfer_kris Sat Jan 25, 2014 6:03 am
Yes, the numbers 1.0 stands for 1cc aka 0.061 cubic inch...
Surfer_kris
Surfer_kris
Post  RknRusty Sat Jan 25, 2014 8:54 am
Bernie's clamp ring heads and drop-in plugs are the same compression ratio as stock Norvel heads.
Post  fredvon4 Sat Jan 25, 2014 10:14 am
I run them very successfully with a head adapter cut for Nelson plugs, 4 head shims to start and get first few runs on the engine then play with shims and nitro to get high RPM consistent runs (IN THE AIR)
(actually my first one I tried Rusty's way with a low compression Cox head, then back to factory head, and then to the Galbreath Nelson adapter)
I do not waste time with the muffler
I do adapt a Cox fine thread NVA as per Ken Cook and Rusty on this site
I do run bladder
very cost effective engine for me as the Cyclon and Fora are expensive and hard to get
