» My current avatar photoby roddie Today at 8:48 pm
by 1975 control line guy Today at 8:05 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by Levent Suberk Today at 2:10 pm
by rdw777 Today at 10:28 am
by layback209 Today at 1:20 am
by rsv1cox Yesterday at 6:55 pm
by roddie Yesterday at 6:20 pm
by roddie Yesterday at 3:27 pm
» Octura engines?
by UncleLumpy Yesterday at 8:16 am
» Tatone EM-7
by sosam117 Yesterday at 7:50 am
saito fa 56 rebuild
saito fa 56 rebuild
I have a saito fa 56 which needs rebuilt before i put it in a 72'' rc Quaker that i am buying from my uncle, here is what is wrong
The glow plug threads are stripped out, so thanks Jason for suggesting Clarence Lee to me i will send him the old cylinder assembly for the glow plug thread
Of course this means removing the piston which is ringed, so i will need a new ring from Frank Bowman because once you take the ring out, the old one will never seat the same way in the cylinder again
My question is, will i have to mess with the timing again, i am not going to be touching the timing gears but will be taking the cylinder off with the rockers.
thanks, Mitch
thanks, Mitch
mitchg95- Diamond Member
Re: saito fa 56 rebuild
Shouldn't need to worry about the timing unless you remove the cam gear box cover and cam gear which is not needed to do unless you change out the bearings.
Jason_WI- Top Poster
the bearings are in good shape i dont think ill remove the cam gear box cover
thanks Jason!
thanks Jason!
got the piston removed, the forth cylinder screw was a bugger to remove because it was stripped i got it out by gripping it real hard with the pliers on my multi-tool
looks like im ready for new parts
» My Saito twin
» ebay - Pink stinks but this is nice - Twin Saito's
» Tee Dee .09 rebuild.. and run!
» Cox Tee Dee .049 Rebuild ...
