Having some fun with a baja bug engine... Cox_ba12
Having some fun with a baja bug engine... Pixel
by rsv1cox Today at 7:38 am
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Having some fun with a baja bug engine... Empty
Having some fun with a baja bug engine... Empty Having some fun with a baja bug engine...
Post  ideeman1994 Sun Oct 09, 2011 10:22 am
I don't know if this should go in "Off Topic" or in "General discussion", but anyway...
I bought this engine a few months ago, but I didn't have a car to put it on... So I had an idea: building a tiny generator, maybe the smallest ever made lol!
Having some fun with a baja bug engine... Genera10_800x600
It's just for the fun, it produces a faint light with a 4.8V light bulb :p
The generator itself is a 9-12V motor
Having some fun with a baja bug engine... 314663_10150481579784816_152837594815_11111521_1824918596_n
Having some fun with a baja bug engine... 307565_10150481580184816_152837594815_11111526_418898509_n
Somebody should try with a pager motor and a NanoBee engine lol!
ideeman1994
ideeman1994
https://www.facebook.com/pages/Cox-engines/152837594815
Having some fun with a baja bug engine... Empty Re: Having some fun with a baja bug engine...
Post  EXModelEngines Sun Oct 09, 2011 11:21 am
Thats really neat!
I wonder what the max it could generate is?
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  microflitedude Sun Oct 09, 2011 12:59 pm
I was trying to that with a dragster engine. How do you connect the shaft to the engine? If you have an old printer, those motors generate more current.
microflitedude
microflitedude
Post  nitroairplane Sun Oct 09, 2011 1:22 pm
microflitedude wrote:I was trying to that with a dragster engine. How do you connect the shaft to the engine? If you have an old printer, those motors generate more current.
I could try it with a blitz .05cc but don't want to risk it.
although it would be cool.
You could generate more power by messing with gearing.
i think a .010 sized one would be pretty cool.
nitroairplane
nitroairplane
Post  ideeman1994 Sun Oct 09, 2011 1:53 pm
Sure, using a stepper motor should generate waaaay more power, and I've got a few of those.... But the torque needed is higher than a classic DC motor, and I don't want to risk breaking anything off...
For the connection, well, I had to modify a bit the starting system of the engine... It's not easy to explain, as my english is not perfect, and this pull start system is a bit complex Wink
When I received the engine, it was competely seized... I removed the cylinder-piston assem, to ease the crankshaft unlocking, and removed the plasic gear installed onto the flyweel... Unfortunately, the metal hex "nut" going into this plasting thing broke off when I tried to make it turn over... So I just put another screw directly onto the flywheel, and simply pressed the plastic gear on the flywheel... It's simply held by the shavings in the end of the flywheel (I think it's called the knurling Huh... )
This is the engine side... For the motor side, the shaft connects into the hole where the screw holding the plastic gear used to be... It's not the exact diameter, but I stuffed it with some folded paper, so that the motor shaft makes a tight fit with the screw hole. It doesn't hold perfectly, but that's good enought for me Laughing
Hope you understood, if not, i'll try to make some pictures tomorrow Smile
ideeman1994
ideeman1994
Post  nitroairplane Sun Oct 09, 2011 1:56 pm
ideeman1994 wrote:Sure, using a stepper motor should generate waaaay more power, and I've got a few of those.... But the torque needed is higher than a classic DC motor, and I don't want to risk breaking anything off...
It may be knurling is it similar to what is at the tip of a crankshaft?
nitroairplane
nitroairplane
Post  ideeman1994 Sun Oct 09, 2011 1:57 pm
Yes, I think that's it... Oh, wait, I'll take a picture Smile
ideeman1994
ideeman1994
Post  nitroairplane Sun Oct 09, 2011 1:59 pm
ideeman1994 wrote:Yes, I think that's it... Oh, wait, I'll take a picture Smile
cool it most probably is.
nitroairplane
nitroairplane
Post  ideeman1994 Sun Oct 09, 2011 2:09 pm
Having some fun with a baja bug engine... Dsc02910
You see, normally the screw and the hex shaped metal thing goes all the way throught this plastic gear...
From the flywheel to the plastic thing, it was: the hex long nut throught the gear (screwed in place in the flywheel), then the screw holding this plastic part, whose head was sticking where the pen is.
Having some fun with a baja bug engine... Dsc02911
But here, as the hex nut broke off, I replaced it with a simple screw, going directly into the flywheel, and the plastic gear holds with those metal irregularities.
Having some fun with a baja bug engine... Dsc02912
Another shot where the end screw was, whitch is now where the DC motor shaft is installed.
ideeman1994
ideeman1994
Post  nitroairplane Sun Oct 09, 2011 2:12 pm
yeah that is knurling.
nitroairplane
nitroairplane
Post  PV Pilot Sun Oct 09, 2011 2:27 pm
That grey piece has what looks to be, or could be used as a o-ring pulley groove. that way you could keep all those pieces intact and bolted on.
Purchase some o-ring material the same width as the groove in that grey drive piece, and pulley off to another dynamo motor.
You can get the little dynamo right here.
http://www.ministeam.com/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2eministeam%2ecom%2fcgi%2dbin%2fss000001%2epl%3fTB%3dA%26GB%3dA%26SS%3ddynamo%26SX%3d0%26PR%3d%2d1%26PG%3d%26REFPAGE%3dhttp%253a%252f%252fwww%252eministeam%252ecom%252facatalog%252fsearch%252ehtml%26PN%3d1&WD=dynamo&PN=Mamod_Accessories%2ehtml%23aMADY#aMADY
Holy monster link!! sorry about that. It does work tho'
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  ideeman1994 Sun Oct 09, 2011 2:32 pm
I also thought that, but it ended that it would be easier to connect the shaft directly... I didn't want to make something reliable, just to see if i'd work...
Maybe one day, if I've got some time, I'll try to build a better one, with a metal base and that kind of pulley Smile
ideeman1994
ideeman1994
Post  Admin Sun Oct 09, 2011 2:47 pm
I was always going to build a .049 generator after I saw one at our state fair about 6-7 years ago. I believe it was a stand selling Generac generators. I wish I would have taken a picture but then, I didn't have a camera phone then so I couldn't take a pic. I remember they had a Estes Babe Bee with a grooved (so a string could be wrapped to start it) flywheel and a gear connecting to a small complex gearbox. The gearbox turned a small AC alternator (the rotor was a solid magnet while the stator had the windings). The alt was able to power a hand held TV and a few flashlight bulbs.
Post  nitroairplane Sun Oct 09, 2011 2:53 pm
Admin wrote:I was always going to build a .049 generator after I saw one at our state fair about 6-7 years ago. I believe it was a stand selling Generac generators. I wish I would have taken a picture but then, I didn't have a camera phone then so I couldn't take a pic. I remember they had a Estes Babe Bee with a grooved (so a string could be wrapped to start it) flywheel and a gear connecting to a small complex gearbox. The gearbox turned a small AC alternator (the rotor was a solid magnet while the stator had the windings). The alt was able to power a hand held TV and a few flashlight bulbs.
That mustve been cool i actually saw one with a wen mac .049 on youtube.
nitroairplane
nitroairplane
Post  ideeman1994 Sun Oct 09, 2011 2:56 pm
A hand held tv Shocked
Mine cannot power more than a 5V lightbulb...
ideeman1994
ideeman1994
Post  nitroairplane Sun Oct 09, 2011 3:03 pm
ideeman1994 wrote:A hand held tv Shocked
yes but if you use a transformer you could turn that to 1 million volts that is the theory behind how a 230v mains supply can charge a 3.7 volt lipo battery.
Infact power stations create power at 25000 volts but at our home we get 230v
so if you want to you can power a hand held tv with yours if you like.
pocket tasers use 3 1.5 volt AAA cells.
nitroairplane
nitroairplane
Post  ideeman1994 Sun Oct 09, 2011 3:08 pm
I can raise it to 2 millions volts if I want, but I still won't have enought power... My lightbulb uses 4.8V under 500mAmps, and it lights up faintly... Whitch means I've got less than 2 watts... A handheld TV uses a bit more than that Crying or Very sad
ideeman1994
ideeman1994
Post  nitroairplane Sun Oct 09, 2011 3:12 pm
ideeman1994 wrote:I can raise it to 2 millions volts if I want, but I still won't have enought power... My lightbulb uses 4.8V under 500mAmps, and it lights up faintly... Whitch means I've got less than 2 watts... A handheld TV uses a bit more than that Crying or Very sad
yeah i know i was only adressing the problem of voltage not electrical power.
nitroairplane
nitroairplane
Post  Admin Sun Oct 09, 2011 3:25 pm
They had a complex gearbox that raised the speed and torque. The gearbox was about 2 times the size of the .049 and it spun a alternator about 2 times the size of the .049 as well. I think it was one of those LDC hand held TVs that take like 4 AA batteries, it wasn't one of those Sony Watchmans with the tube that takes a few more amps.
Post  microflitedude Sun Oct 09, 2011 7:24 pm
The are steppers in printers, but there are also plain 'ole DC motors. I have a bunch and they seem to give the most amperage.
microflitedude
microflitedude
