Cleaning up a Baja Bug engine Cox_ba12
Cleaning up a Baja Bug engine Pixel
Cleaning up a Baja Bug engine Empty
Cleaning up a Baja Bug engine Empty Cleaning up a Baja Bug engine
Post  rsv1cox Tue Jan 24, 2017 5:16 pm
Awoke to snow this morning.
Cleaning up a Baja Bug engine Baja_e12
Part of the "Grab bag" bundle.
Cleaning up a Baja Bug engine Baja_e10
Before coffee, walked over to the garage and short boiled the Bug engine and a Gilbert 11, both not to nasty hence the 3 hour boil.  Neither came out as clean as I'm used to but further scrubbing in Simple Green and an alcohol rinse on the Cox helped.  The Gilbert will have to be dunked again or disassembled and a mild media blast.  Best part on the Cox is that the pull starter works fine.  I remember destroying the one on our original  Baja Bug years ago.
Cleaning up a Baja Bug engine Baja_e11
Cleaning up a Baja Bug engine Baja_e13
The usual age related corrosion on the fuel tank.  Didn't Mark Boesen chuck one of these up in a drill press and polish it out?
How many here make these engines with drives part of your collections?
Last edited by rsv1cox on Wed Jan 25, 2017 6:54 am; edited 1 time in total (Reason for editing : Turned "may" into many.............New right eye arrives Feb 1 :))
Cleaning up a Baja Bug engine Empty Re: Cleaning up a Baja Bug engine
Post  getback Tue Jan 24, 2017 6:01 pm
cheers Turned out good Bob , Yeah chunk the back plate in some Hobbies #9 for 1/2 hr. scrub with brush alh. rinse you may want to replace the stiff intake hose and chuck the tank up in the drill 800 grit is good sander and replace parts as needed to run !! Hand Shake I have one that
s pretty but haven't ran it ...... cant believe U got some more Snow!! 70 here tomorrow Clapping Babe Bee .049
Post  Marleysky Tue Jan 24, 2017 6:57 pm
[quote="rsv1cox"]Awoke to snow this morning.
[url=https://servimg.com/view/19152833/1352]
How may here make these engines with drives part of your collections?
ARRRRH! Snow!   We have been snow free for a couple of weeks, all the snow and ice dams on the roof have melted. weatherman says we gonna get some b4 the end of this week! Getting spoiled enjoying this "global warming"
I do have a pull start engine in my collection. Just thought it was cool. Had imagined putting it in a small to medium sized boat, take the gear off and install a shaft drive. I bought plans for Dumas "short stuff" so it's in the que.
Post  watertrucker Tue Jan 24, 2017 8:43 pm
Nice looking engines, rsv1cox. Quick question: did you boil the Cox with the pull start attached? I picked up a Cox Jeep and I freed the engine up with after run oil but would like to give it a hot antifreeze bath to clean it up(pretty nasty, think it was stored outside in a storage shed) but don't want to ruin the pull start. Thanks!
watertrucker
watertrucker
Bronze Member
Bronze Member
Post  KariFS Wed Jan 25, 2017 1:34 am
rsv1cox wrote:How may here make these engines with drives part of your collections?
Well, at least I do Smile Here's a thread from a few months ago about the clean-up of my car engine:
https://www.coxengineforum.com/t10059-mystery-motor-from-an-unknown-vehicle
I assembled this engine with the needle and the cooling element pointing towards a different direction compared to the original arrangement so that it is easier and more compact to store.
Post  rsv1cox Wed Jan 25, 2017 7:25 am
I remember that thread Kari, nice clean up on a colorful engine. Mine made it onto my "Enya tree" presently the only non-Enya to do so.  Placed it beside an Enya .09 Car/Helo engine.
Cleaning up a Baja Bug engine Cox_en16
And watertrucker, no, I didn't remove the starter mechanism.  It didn't look as nasty as the others I had taken apart and frankly I didn't want to deal with those little pauls on the eccentric.  I just removed the glow head and loosened the case screws and boiled it like that.  I didn't try to pull the starter prior to boiling.  But after the boil I removed the case, immersed it in full strength Simple Green then pulled the starter, then into hot water rinse again operating the starter, blew out with compressed air, then into clean 91% alcohol pulling the starter,more compressed air then a liberal spray of RemOil in all openings.  Smooth as silk now, but the exterior needs some polish.
I have this one coming for Lieven and will ship it as soon as it arrives.
Cleaning up a Baja Bug engine Cl110
Cleaning up a Baja Bug engine Cl210
Cleaning up a Baja Bug engine Cl410
Cleaning up a Baja Bug engine Cl_510
He should have fun cleaning it up.  I just hope the starter mechanism works.
Post  rsv1cox Wed Jan 25, 2017 7:31 am
getback wrote:cheers  Turned out good Bob , Yeah chunk the back plate in some Hobbies #9 for 1/2 hr. scrub with brush  alh. rinse you may want to replace the stiff intake hose and chuck the tank up in the drill 800 grit is good sander and replace parts as needed to run !! Hand Shake I have one that
Snow gone this morning Eric and maybe 50 degrees today.  We sit at about 1400 feet above sea level and temps go down as elevation goes up. Sad This Florida boy is used to 25' ASL.
I will try the Hoppees and try to clean that case up, the rest of it looks pretty good.
Bob.
Post  watertrucker Wed Jan 25, 2017 8:31 am
Well, I'm gonna get my $5 Goodwill crockpot going and cook it. Thanks!
watertrucker
watertrucker
Bronze Member
Bronze Member
Post  Ken Cook Thu Jan 26, 2017 4:03 am
The pull starter is a very simple mechanism. 2 small steel discs are under the gray worm drive gear. These have a tendency to get stuck and need freeing up. Cox would put a sticker on the chassis indicating to pour fuel into the starter mechanism. A larger problem is the 90 deg bend on the spring steel recoil spring. If it breaks off, it's very difficult to re bend it without breaking. That's usually the fate of the starter and your in need of another.
Post  rsv1cox Thu Jan 26, 2017 7:37 am
Darned if these car engines don't multiply.
Seems that during the night Mrs. Enya and Mr. Cox got together and brought forth these hybrid twins, one with a birthmark. Smile
Cleaning up a Baja Bug engine More_c10
