» COX .020 POWERED SPEEDSTERby 1/2A Nut Today at 3:34 pm
» The Wood Shovel
by rsv1cox Today at 3:09 pm
» Cox p39 Airacobra
by 1975 control line guy Today at 1:17 pm
» OK Cub .024
by GallopingGhostler Today at 12:16 pm
by rsv1cox Today at 12:14 pm
» Pt19 pilot and windshield
by getback Today at 5:23 am
by Admin Yesterday at 10:45 pm
» BMFA. UK AUCTION
by rsv1cox Yesterday at 7:25 pm
» Cox Star Cruiser Instruction/Manuel/Information
by DanMc Yesterday at 9:47 am
by roddie Mon Oct 21, 2024 5:50 pm
by Cox International Mon Oct 21, 2024 12:32 pm
» Stealth SB-X
by getback Mon Oct 21, 2024 8:15 am
Run time on a .15 Medallion
Hello all , on a .15 medallion how much run time in the air do you think it would get ,, new to me repaired .15 size Clown Well i am working on it and have a 1 oz. tank w/clunk plastic Think it will bee fast but want to keep the turning time down and still have fun ! I figure 2 mins. in the air is all i can afford
Re: Run time on a .15 Medallion
Don't contribute size for speed, the Medallion is a fairly low powered engine. It certainly would be quite faster with a modern .15. Your prop choice is also going to impact the plane's speed. I would insure that the engine is firmly mounted to the fuselage. No washers under the lug for engine offset as this can cause a lot of vibration. A old oil soaked fuselage is also a recipe for similar problems. The Medallion doesn't offer much of a footprint. I prefer to have at a minimum aluminum pads under the engine lugs and also on the inboard side of the fuse to insure a secure footing. Vibrations can create fuel foaming making the engine run leaner making it difficult to acquire a needle setting. If your really concerned about speed, put the prop on backwards and fly it as this will slow it down immensely.
I tried finding horsepower curves for the Medallion .15 without luck. Sceptre Flight has only the earlier 1960's throttle conversion, which unfairly limits power by reintroducing exhaust gases into the SPI passages diluting the fuel charge reducing power. There, the Medallion .15 converted to R/C had the power curve of the mid 1960's Enya .09-III TV.
https://sceptreflight.com/Model%20Engine%20Tests/Cox%20Medallion%2015%20RC.html
Captured from Sceptre Flight article, Dec 1964 Model Airplane News.
The RPM numbers seem decent for a non-Schneurle cross scavenge engine.
https://sceptreflight.com/Model%20Engine%20Tests/Cox%20Tee%20Dee%20and%20Medallions.html
Adrian's has done extra engine tests with power curves, but unfortunately not with this engine.
I can see where your concerns come in Ken. Not have much of an engine footprint requires more stout mounting to subdue vibration.
Jan/Feb 1963 American Modeler wrote:Medallion speeds:
The .15 - 7/4 prop 16,500 rpm; 7/6 prop 13,500 rpm; 8/4 prop 13,800 rpm; 9/3 prop 13,000 rpm.
Medallion specifications:
The .15 - Bore .951"; Stroke .556"; Displacement .152 cu-in; Weight 4.243 oz.
Last edited by GallopingGhostler on Tue Aug 27, 2024 7:53 am; edited 1 time in total (Reason for editing : Further clarification.)
Thanks Ken , can't quite rape my mind around the alum. pads got a pic ? Still what size fuel cell .
» Top Flight 3 Meter "Bird of Time" Sailplane & Cox Medallion .15
» Flew yesterday, first time in a LONG time....
» Triva Time II (an easy one this time)
» Medallion 049 & Medallion 049; what is the difference?
» How much run time do your Black Widows get on 8cc?
