Testors Engine Propeller Cox_ba12
Testors Engine Propeller Pixel
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Testors Engine Propeller Empty
Testors Engine Propeller Empty Testors Engine Propeller
Post  NEW222 Mon Jun 25, 2018 5:49 pm
Hi all. So, I recently came to aquire a Testors 8000 series engine. However, the main shaft is larger than that of a Cox engine. What propellers does one use, or is it safe to drill out a Cox or Master Airscrew propeller? Thanks in advance.
Testors Engine Propeller Empty Re: Testors Engine Propeller
Post  batjac Mon Jun 25, 2018 11:15 pm
For my Testors engines I just drill out the hole on a Cox 5x3 safety prop. I make sure to mark the props with "WM" for Wen-Mac, since they're the same as a Testors. Works fine for me.
The Marked Mark
Post  NEW222 Tue Jun 26, 2018 11:19 am
Thank you.
Post  TLAnderson Tue Jun 26, 2018 9:00 pm
batjac wrote:For my Testors engines I just drill out the hole on a Cox 5x3 safety prop.  I make sure to mark the props with "WM" for Wen-Mac, since they're the same as a Testors.  Works fine for me.
The Marked Mark
Yep. That's what I did on this Testors Albatross, when the original prop got broken in a botched hand launch\crash.
Testors Engine Propeller Dsc00710
TLAnderson
TLAnderson
Post  Oldenginerod Wed Jun 27, 2018 5:21 pm
I recall Bernie had quite a few original Testors props in stock some time back. Not sure if he still has any.
Post  roddie Wed Jun 27, 2018 7:38 pm
Chancey, The Testors .049 engines have a 6-32 threaded crankshaft which measures .161" diameter. A #20 (decimal/inch) machinist-drill has a .161" diameter.
Alternately.. a 4.1mm metric drill has a .1614" diameter.. and would also be a good choice.
Either of these drill-sizes are what you'd want to use to enlarge a propeller's hub-hole to fit your Testors .049 engine.
Don't drill the hole oversize.. or else you'll likely have a propeller that's off-center and out-of-balance after it's mounted.
Don't re-use the propeller on a Cox .049 engine once it's been drilled-out to fit the Testors engine's 6-32 shaft. Keep the propellers separate.. and marked for the engines that they fit. The Cox .049's 5-40 prop-screw is .039" smaller in diameter than the 6-32 size.
Post  GallopingGhostler Wed Jun 27, 2018 8:09 pm
Oldenginerod wrote:I recall Bernie had quite a few original Testors props in stock some time back.  Not sure if he still has any.
No longer shows on-line, my guess is he finally sold out.
Post  NEW222 Wed Jun 27, 2018 9:25 pm
Thanks roddie for all the information. I am glad I now know the size of the shaft as well. I do have those drill bits available to me to use also, so I will give it a go. Thank you.
Post  roddie Fri Jun 29, 2018 12:05 am
NEW222 wrote:Thanks roddie for all the information. I am glad I now know the size of the shaft as well. I do have those drill bits available to me to use also, so I will give it a go. Thank you.
Hey Chancey.. you're welcome my friend. It's imperative to keep precision measurements with model-aircraft applications.
Post  Cox International Mon Sep 10, 2018 5:06 pm
Sorry but just saw this post:
https://www.ebay.com/itm/7824-Vintage-Testors-Model-Airplane-Prop-2-Blade-6-Propeller/371977064889?epid=22002738548&hash=item569b8f91b9:g:uAAAAOSwR2RaKs~8
https://www.ebay.com/itm/4100-5016-Vintage-Testors-Model-Airplane-Prop-2-Blade-4-1-2-Propeller/371977109433?hash=item569b903fb9:g:ptYAAOSwX3FaA4Xv
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
