Engine Direction And Propeller On Tether Car Cox_ba12
Engine Direction And Propeller On Tether Car Pixel
Engine Direction And Propeller On Tether Car Empty
Help! Engine Direction And Propeller On Tether Car
Post  NEW222 Tue May 07, 2019 9:45 pm
Ok. So, I am planning on trying out my homemade tether car in the next week or two. With that said, I have a question regarding starting and running it. The engine is on the back pointed rearward. So, what propeller and direction does one run the engine? I keep thinking of it, then second guess myself. My original thought is using a standard propeller put on the engine backwards, and run in the original direction of the engine (RH). Is this correct, or am I not seeing it properly. I have both standard (RH) rotation propellers, and a few LH 6 x 2 propellers. If anyone could please help clear this up for me, it would be greatly appreciated.
Engine Direction And Propeller On Tether Car C310
Help! Re: Engine Direction And Propeller On Tether Car
Post  F4D Phantom II Tue May 07, 2019 11:54 pm
Hello new222
The one you have on should work well you mounted it correctly. Make sure the prop doesn`t hit the ground and if it does just swap for a 3 blade for more clearance. Have fun!
Juan
F4D Phantom II
F4D Phantom II
Post  NEW222 Wed May 08, 2019 6:42 am
Thank you.
Post  KariFS Wed May 08, 2019 11:02 am
To use a right-hand propeller as a pusher you should install it backwards and you also need to run it backwards (LH).
You can also run a backwards-installed left-hand propeller to the conventional direction and it will work as a pusher.
Actually you don’t even need to install a propeller backwards to run it as a pusher, you just need to run the engine backwards Huh... But with a backwards-installed propeller you will obviously get better thrust.
Post  coxaddict Wed May 08, 2019 2:04 pm
Try running the car with the engine facing the front too
coxaddict
coxaddict
Post  NEW222 Wed May 08, 2019 7:25 pm
coxaddict wrote:Try running the car with the engine facing the front too
Hmmm. Huh... Not as aerodynamic, but that never crossed my mind and is well worth a try. As simple as this is, it is also a good head-scratcher, well at least for me anyways. Very Happy
Thanks all for the help.
Post  aspeed Wed May 08, 2019 9:53 pm
The reedies run either direction so any prop is fine. Just make sure the flat surface of the prop faces the rear. Don't let it sit too long running as there is no cooling. A Texaco finned head or the clamp on cooling fin will help, but if it is a bit rich and moving it will be ok likely.
aspeed
aspeed
Post  Oldenginerod Wed May 08, 2019 11:46 pm
NEW222 wrote:Ok. So, I am planning on trying out my homemade tether car in the next week or two. With that said, I have a question regarding starting and running it. The engine is on the back pointed rearward. So, what propeller and direction does one run the engine? I keep thinking of it, then second guess myself. My original thought is using a standard propeller put on the engine backwards, and run in the original direction of the engine (RH). Is this correct, or am I not seeing it properly. I have both standard (RH) rotation propellers, and a few LH 6 x 2 propellers. If anyone could please help clear this up for me, it would be greatly appreciated.
Looks like you already have a LH prop fitted. Thumbs Up
