Stels .049 Cox_ba12
Stels .049 Pixel
by LooseSpinner99 Today at 4:38 pm
by Kim Today at 3:28 pm
by rsv1cox Today at 2:23 pm
by rdw777 Today at 11:24 am
» Pathé Modeling Videos
Stels .049 Empty
Stels .049
Stels .049 Empty Stels .049
Post  JPvelo Fri Feb 12, 2016 12:47 pm
I just picked up a Stels .049. It came with a standard glow plug head and felt like it had no compression. I put a standard cox head on and it has plenty of compression and fired right up on prime. The needle valve is extremely loose, hoping for some input from someone with Stels experience.
Stels .049 CHUMrBc
Stels .049 T9HmZbK
Stels .049 CEhiQUd
JPvelo
JPvelo
Stels .049 Empty Re: Stels .049
Post  RknRusty Fri Feb 12, 2016 3:01 pm
That's interesting. Dual exhaust. The case and cylinder look a lot like an AME. I wonder if it ever had a venturi. May be a pretty strong little powerplant.
Post  Ken Cook Fri Feb 12, 2016 3:02 pm
Jim I love the Stels engines. The earlier engines didn't come with plugs and the recommended prop was the 1702 Cox high compression. Stels started to manufacture there own drop in style plugs on the later variants and I have about a dozen of them. These worked good. The Galbreath Nelson setup is a good solution if you don't want to use the Cox hi comp. Here's some of the problems with this engine. It will run on bladder with the exception of that needle. It's just too coarse for a decent setting. It's either too lean or dead rich. The other problem is the rear exhaust. It will burn the you know what out of your fingers when adjusting the needle.  It will run fine on 35% but it wants to do some rpm's. I have the instructions for these and the recommended fuel for break in was 45% nitro 20% oil. It just says to run the engine until the black oil ceases to remain and then the nitro can be increased. The bathtub venturi is too large for suction. Stels did offer inserts but they too were generally too large. Your engine I see still has the three stock screws holding the cylinder flange to the case. These screws can and will break having the cylinder blow off. It's best to replace these with socket head screws which can be easily found in the r/c car section of most hobby shops. I believe the thread is 2.5 mm. It's a simple fix and a good peace of mind. These engines were designed mainly for combat and they're high quality. They don't like big props. Anything larger than 4 1/4" and the engine isn't going to be real happy. They also like low pitch. APC 4.6 x 3 works but I like to trim them down a bit as the 3 pitch holds it back. I like to use a Cox black 5x3 cut down to 4" and even less with the tips smoothly rounded off. Great engines and they made a side exhaust version of these as well which are just wonderful to run. I have the larger .15 size twin horn as well. Ken
Post  RknRusty Fri Feb 12, 2016 3:17 pm
I found this, Looks like it may have been a diesel. 6th engine from the top.
http://www.mh-aerotools.de/airfoils/cox_smallengines.htm
Oh, Ken posted too.
Post  Cribbs74 Fri Feb 12, 2016 3:17 pm
Jim,
That needle valve looks to have a jam nut that can tighten down the needle. Like a ST NV.
Post  JPvelo Fri Feb 12, 2016 3:20 pm
Cribbs74 wrote:Jim,
That's what I thought, I tightened the nut but still loosey goosey. I'll probably retrofit a postage stamp needle.
JPvelo
JPvelo
Post  RknRusty Fri Feb 12, 2016 3:34 pm
Ken are those the same size screws that hold down the AME and Big Mig cylinders?
Sorry to go off topic, but I'm going to the LHS tomorrow, and have been wanting to get some.
Post  Ken Cook Fri Feb 12, 2016 4:16 pm
The needle valve assembly can be replaced with a 128 tpi spraybar but the hole in the case of the Stels is very large. A Driskill needle will fit but even the Driskill needle isn't as fine to provide the same adjustment. A Fora needle would be the cat's meow if you could find one. If you do use a Cox just have a bushing made. Another thing you will be faced with after a Cox retro fit is the length of the spraybar. It's not very long on fuel line side.
Post  Ken Cook Fri Feb 12, 2016 4:22 pm
Rusty, the screws are the same thread and you could increase the length a few mm for added holding power. The Big Mig however used a much larger slotted head opposed to allen cap screw. Revlite engines use a large head screw and the pre revlite engines used a screw similar to the one Jim has on his engine. Doug Galbreath who is known for his free flight activity would automatically switch out the screws if you sent him the engine. Ken
Post  Dane Martin Sun Feb 14, 2016 2:05 pm
JPvelo wrote:
Cribbs74 wrote:Jim,
One thing I've noticed with those older jam nut style nva's is that if they were tight, and lots of adjustments were made, then the brass starts to wear. The "shavings" end up in the slots. The nut gives the excess metal no where to go.
Take it apart and run a razor saw in the slots to clean them out. Then reassemble and try again. Should fix it up nice. That way there's some squish room in the spray bar slots again
Dane Martin
Dane Martin
Silver Member
Silver Member
