[solved]Medallion 09 Propdriver removal?
Now I've found the bits I need, can anyone tell me the correct way to remove a Medallion .09 propdriver and fit a new one? I've seen tools available to do it on 049s, but I'm sure they won't fit an 09!
Wilf
Wilf
Ivanhoe- Diamond Member
Re: [solved]Medallion 09 Propdriver removal?
Here it was posted on the cox engine collection site.
http://sites.google.com/site/coxenginecollection/replacing-a-broken-crankshaft-in-a-post-1959-babe-bee
nitroairplane wrote:Here it was posted on the cox engine collection site.
No, I've seen that, that's replacing a broken crankshaft, I need to know how to pull the old propdriver off with the crankshaft in situ. On the 049 I know you can fit a propscrew then use it to gently tap the shaft backwards (Having removed the piston, of course) but the 09 has a "Stepped" propdriver and you can't see the end of the shaft, so I need to know if you can do it the same way.
Oh yes i believe you can.
But on 2 engine with bad drive plates i used the tool for cutting wires (the name has escaped me)to pul it off at the case.
But i cannot recommend it because if not done with caution you will damage the engine.
Indra:
The tool that you used was mostly a pair of diagonal cutting pliers a.k.a. "dikes"
SuperDave- Rest In Peace
Yep thats them Dave.
I use them a lot for various things but the name escaped me.
Indra:
You might try "dikes" when cutting your toenails.
SuperDave wrote:Indra:
Are you speaking from personal experiences?
I find toe nail clippers to be sufficient.
nitroairplane wrote:SuperDave wrote:Indra:
I always find a pair of bolt croppers does the job
nitroairplane wrote:Oh yes i believe you can.
I did think of that, or possibly levering with a pair of thin screwdrivers, but quickly dismissed both ideas!
Maybe.
It is possible to do but if done wrong you will foul the case/collet/crank.
I just posted this in the other thread. The Medallion instructions say to use the engine tool to unscrew the carb retaining collett and it will push off the drive plate. It's on every .049 tool. It's a 1 toothed cutout in the middle of the Cox wrench. It works great on Tee Dees too.
How come I never thought of that it would have saved many a driveplate in my early days!
RknRusty wrote:I just posted this in the other thread. The Medallion instructions say to use the engine tool to unscrew the carb retaining collett and it will push off the drive plate. It's on every .049 tool. It's a 1 toothed cutout in the middle of the Cox wrench. It works great on Tee Dees too.
Great stuff, thanks, Rusty, best idea yet!
» Tee Dee .09 rebuild.. and run!
» NO pliers, but how do I get it off?
» Spray bar removal
» Paint removal
» Flats on top cylinder fin for COX wrench - DIY
» Spray bar removal
» Paint removal
