Dual Exhaust Cox_ba12
Dual Exhaust Pixel
by GallopingGhostler Today at 6:41 pm
by GallopingGhostler Today at 6:35 pm
by 1/2A Nut Today at 2:24 pm
by TD ABUSER Today at 2:17 pm
by 1975 control line guy Today at 9:28 am
by GallopingGhostler Yesterday at 7:39 pm
by rdw777 Yesterday at 6:58 pm
by Kim Thu Nov 14, 2024 3:28 pm
by bsadonkill Thu Nov 14, 2024 1:19 pm
by Levent Suberk Thu Nov 14, 2024 11:39 am
» Pathé Modeling Videos
Dual Exhaust Empty
Dual Exhaust
Dual Exhaust Empty Dual Exhaust
Post  roddie Mon Feb 02, 2015 12:18 pm
With muffler pressure.
Dual Exhaust Dsc02425
Dual Exhaust Dsc02426
Dual Exhaust Dsc02427
Dual Exhaust Empty Re: Dual Exhaust
Post  balogh Wed Feb 04, 2015 4:33 pm
There was a thread somewhere on how to build such a muffler. ..could you remind me please?
Post  dckrsn Wed Feb 04, 2015 5:38 pm
balogh wrote:There was a thread somewhere on how to build such a muffler. ..could you remind me please?
Here it is.
https://www.coxengineforum.com/t5505-a-cheap-sport-muffler
Post  microflitedude Wed Feb 04, 2015 5:59 pm
Very nice. Are you still getting good pressure with two exhaust outlets?
microflitedude
microflitedude
Post  roddie Fri Feb 06, 2015 1:25 pm
microflitedude wrote:Very nice. Are you still getting good pressure with two exhaust outlets?
Matt, I honestly haven't flown with the pressure-tap yet.. so I don't know how well it will work. I'm showing this as a possibility, because none of the other commercially available mufflers for Cox .049 engines have a pressure tap.
Keep in mind that my muffler design uses inter-changeable pipes having different size holes drilled in them for varying degrees of back-pressure. Dual-pipes drilled-out to the max. (.205") may not provide much (if any) pressure to a tap.. but dual pipes drilled smaller.. or a "single" pipe should. I have an assortment of pipes (.22cal ammo shell-casings) that I've drilled-out between .144" and .205" in increments of approx. .007" for testing. This gives me 9 different sizes to experiment with. Running dual-pipes having different sizes.. and placed 180 degrees apart could have cross-scavenging effects. Whether this would be beneficial remains to be seen.
Being able to successfully tap muffler pressure off a Cox .049 engine could improve stunt performance when using an external hard-tank. Testing is as easy as flying the model first without the line connected to the tank.. then attaching it prior to a 2nd flight, to one vent.. while plugging the other to see if you get a steadier engine run.
Post  Surfer_kris Fri Feb 06, 2015 2:14 pm
I don't think you'll need a pressure tap unless you seriously change the backplate, or mount the tank too far outward.
The Babe Bee certainly runs very well on an external tank (in an RC plane) and the TD 05RC runs well without pressure from the muffler too.
Surfer_kris
Surfer_kris
Post  RknRusty Fri Feb 06, 2015 7:10 pm
That's the experiment Roddie equipped me to try, and I disappointed him by not getting around to it. I've still got the stuff and put the muffler on the Kitty Cat plane waiting for a good goof-off day to take it to the church. I have to have a launch assistant for that platter plane.
On the other hand i have made good use of Roddie's aluminum engine bearers and small wheels. My stunters have Roddie tail wheels.
Post  roddie Fri Feb 06, 2015 8:29 pm
RknRusty wrote:That's the experiment Roddie equipped me to try, and I disappointed him by not getting around to it. I've still got the stuff and put the muffler on the Kitty Cat plane waiting for a good goof-off day to take it to the church. I have to have a launch assistant for that platter plane.
Hey Rusty.. no worries man. We all have a focus.. and yours lately has been on larger CLPA competition airplanes.. and you're advancing very well! I love reading about your attention to detail with every aspect concerning your building, tuning and flying experiences!
