Glow head issue? Cox_ba12
Glow head issue? Pixel
by TD ABUSER Today at 2:30 am
Glow head issue? Empty
Glow head issue?
Glow head issue? Empty Glow head issue?
Post  Cribbs74 Fri Dec 02, 2011 9:46 am
Guys,
I have a prob with one of my pee wee's it runs real well when the battery clip is attached but, when I pull the clip it starts to burble and it's tough to keep it running. If I re-attach the clip it takes off again and runs fine. The glow head looks almost new and glows bright when on the battery. Any Ideas?
Glow head issue? Empty Re: Glow head issue?
Post  PV Pilot Fri Dec 02, 2011 10:37 am
That's usually a really rich condition for the first check.
Does it stay lit if you leave the battery attached until it warms up?
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Cribbs74 Fri Dec 02, 2011 10:54 am
Perhaps more info would help. Usual start procedure followed, when it starts it's rich needle adjusted until it leans and smooths out. Pull the clip and then crackling and burbling etc. It's kind of like the glow plug won't stay hot. If I re attach the clip it goes back to running like normal.
With the glow head off the engine with the battery connected it glows red all day long.
Post  RknRusty Fri Dec 02, 2011 10:56 am
Methanol deficient fuel? I doubt it, not if your other engines run okay. Something has coated the platinum so the methanol cannot come in contact with it. Have you ever added an anti-foam agent to the fuel with this engine? Like a drop of Armour All. This is a strange one.
Try washing it with some acetone.
Post  SuperDave Fri Dec 02, 2011 11:10 am
I too suspect contamination of the glo element. A cleaning with acetone as suggested may help.
If it doesn't try a known good replacement glo head.
SuperDave
SuperDave
Post  microflitedude Fri Dec 02, 2011 11:26 am
Is the coil in good shape? If it is deformed or out of center the engine will not run well.
The smaller the engine, the more sensitive.
microflitedude
microflitedude
Post  Cribbs74 Fri Dec 02, 2011 12:30 pm
I will try cleaning it and ensure it is centered. I also will post back with results.
Post  Cribbs74 Fri Dec 02, 2011 12:33 pm
RknRusty wrote:Methanol deficient fuel? I doubt it, not if your other engines run okay. Something has coated the platinum so the methanol cannot come in contact with it. Have you ever added an anti-foam agent to the fuel with this engine? Like a drop of Armour All. This is a strange one.
I have not added a foaming agent. Using Sig champion fuel. Works fine in all engines but this one. By adding an agent are you saying to do that or not do that.
Post  Admin Fri Dec 02, 2011 12:54 pm
Try a new head if you have one. If it does the same thing, there could be something up with your fuel. Is the fuel old? Did you notice any condensation on the inside of the bottle? Did you leave the cap off for some extended amount of time?
Post  PV Pilot Fri Dec 02, 2011 1:22 pm
cribbs74 wrote:I will try cleaning it and ensure it is centered. I also will post back with results.
I would just try a soak, no toothbrushing obviously.
Back to my old standby. I have used Eagle 1 etching formula mag wheel cleaner and the reason for posting that is because I recently brought a old cruddy standard short Fox plug back from the dead. There was severe crud packed in around the coil Hooked it up intially to my glow driver and it wouldn't do anything, so I tried a soak and a few shake-outs with the Eagle 1 stuff and it worked, The plug lit up real nice and pulled about 3-4 amps at 1.5 volts. Hydrophluoric acid in there, so be carefull around soft painted surfaces and finger cuts,,better yet, wear some painters latex gloves. rinse it off well with just tap water, wipe the alum dust off with a towel
Auto parts store for that Eagle 1.
PV Pilot
PV Pilot
