by TD ABUSER Today at 2:30 am
Kyosho .049 Cox VW Beetle / Mini Cooper
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Kyosho .049 Cox VW Beetle / Mini Cooper
bnitram wrote:Oh great. You have luck. How far are you ? When will you finish the car ?
bnitram
I already assemble engine few days ago and try to fire it up couple times,but it did not work.
only one time almost start but stop like one second,my pull start some times very lose and will not spring back do you know what is cause this problem,i checked all cox web engine and problem guide,but still no idea what should i do next or just try start more.
brianskate- Moderate Poster
brianskate wrote:bnitram wrote:Oh great. You have luck. How far are you ? When will you finish the car ?
bnitram
Hi Brian, Make sure you have good fuel.. and the CORRECT fuel. I would highly recommend "Sig Champion" fuel for 1/2A (.049) engines, if you can source it. Do NOT use "Cox Super Fuel".. because "Hobbico" (it's distributor) has been made aware that it is actually harmful to Cox engines.. and they are in the process of reformulating the blend to have the correct amount and ratio of castor oil and synthetic oil in the mix.
Also.. do not connect any higher than 1.5V DC to the glow-plug. Doing so will immediately burn-out the element/coil in the glow-head.
Your pull-starter may have a worn "band-spring". Search on ebay for "Cox pull-starter" parts.. and try to get some spares. It might be worth taking the pull-starter assembly apart to inspect/re-wind it. Check for broken pieces of the band-spring. I don't know too much about the pull-starter.. but if the band-spring is broken at an end; you may be able to cut it shorter.. and file new notches into the band, where it connects to the housing. If the pull-cord is worn.. you may be able to replace it with some 30# test fishing line; like "Spiderwire EZ braid". When you reassemble the pull-starter, spray the internal components with a dry-type silicone lube, so it winds/unwinds smoothly.
Lastly.. open the needle-valve a little more than the specified "running-setting".. to start the engine. It may not be getting enough fuel. If it starts and continues to run with a low "burbly" sound.. that's ok. Gradually close the needle-valve until the engine begins to speed up. It's a good practice to adjust back and forth between the low (burbly) setting, where the engine is getting plenty of fuel and lubrication.. and shortly "peaking it out" to higher rpm's.. to get used to the needle-valve setting. When you run the car on the track/pavement, you'll need to find the optimal setting as well. This can change with atmospheric conditions and different fuel-blends too.
Hope this helps.. Good luck!
Thanks Roddie!!!
So detailed advise,i will get a new spring for the engine see if still got the lose problem.
For the fuel,it's really hard to find the nitro with castor in my area,I'm use the Tornado 25% nitro fuel,the fuel include 10.5% ricinus and synthetic oils.Also two D battery for glow head.
Very strange situation in my engine right now .
I'm unable to start with muffler and throttle parts,but if I take off these two parts I can start the engine for no problem,but once put back it became no start only few time look like a little fire up.buy never run.
Anyone got some idea can share to me.
Thanks
Thanks
Hi,
do you set the throttle right?
You have to start the engine at full throttle. otherwise the engine won't start. The throttle setting is not easy but if you open the muffler by removing the screw you can see the throttle valve. So you can correct the servo arm to full open.
I hope i can help you
bnitram
bnitram
bnitram- Silver Member
Yes full throttle is required on the beetle and the mini from kyosho. I don`t know why yet, couse the f1 car starts mostly on a little bit more than idle speed (I guess because of the flywheel or clutchbell). On the F1 car they are ball beared.
Make sure the arm for the throttle valve is mounted correctly, it has to be tight outherwise the servo will move it from its center. The cylinder slits have to be beside of the right and left side if you look through the exhaust.
Be sure the cylinder is thigten too and of course the glow plug head works. The Kyosho Cox Car engines are machined very well, they do start with the correct fuel and heater and correct full speed needle very fast, 3 turns from the bottom is recommended. You can also try 2 1/2 turn from the bottom on full throttle if it don't start and add some fuel on the screen.
These engines need some experience on cars, they are little diva's. But once thy start you don`t get it to know that such a little old fashionable engine is able to make those nice screaming sound. Nothing is to match with a cox engine...
My english is poor I know, i am sorry...
coxaddicted- Gold Member
It's okay, Coxaddicted, you are able to get your point across. Welcome back to CEF.coxaddicted wrote:...Nothing is to match with a cox engine...
Coxaddicted, your english is fine.
I have no problem understanding you.
Be comfortable pal.
Be comfortable pal.
dckrsn- Diamond Member
Yes, your English is fine - you have a better handle on the language than most people my age.
Wow,i maybe got some mistake in cylinder slits direction,right now my setting is face to exhaust port(throttle valve) 6 o'clock direction,another in 12 o'clock direction,will try to make it to 9 and 3 o'clock direction later.
I'm totally understand what you guys explanation,no problem.
It look like my start problem is not the cylinder slits direction,because my cylinder locked direction will be different once i installed the throttle valve part,right now i just put the washer(part 95) upside down the cylinder can be tighten like without throttle valve part,then my engine is started but unstable.
Maybe need some hard works
Was looking and this you may bee interested in .... http://www.ebay.com/itm/Cox-Dune-Buggy-Baja-Buggy-049-Gas-Parts-/111495715638?pt=LH_DefaultDomain_0&hash=item19f5a99b36 Hope not to mess with others bidding
Ok,i can start my engine in my hand for no big problem right now,but once install to chassis the zip starter become a nightmare,really hard to start the engine again.
thanks everyone who gave me some idea for start the engine.
Hello brianskate,
that is a good news. Do you have the muffler also installed when you start it in your hand? What is in the chassis difference ? Is the starter sluggish? Does the starter spring works ?
bnitram
PS:
in a few days I get my new boby because the VW Beetle is in too bad conditions. It will be a "Alfa Romeo Gulia Sprint GTA". I will post some pictures when I get it.
bnitram
PS:
quick hijack- sorry
Brianskate, welcome to the forum. I lived on the Island Taiwan/Formosa from 1961 to 1964 when my father was an adviser to General Chiang Kai-shek. We lived in Taichung and I have great memories of that time. Where are you? Tell us a little about your self
fredvon4 wrote:Brianskate, welcome to the forum. I lived on the Island Taiwan/Formosa from 1961 to 1964 when my father was an adviser to General Chiang Kai-shek. We lived in Taichung and I have great memories of that time. Where are you? Tell us a little about your self
@fredvon4
I don't think that this thread, a CAR thread, is the right place for life discussion.
Not without reason there is a introduction thread.
https://www.coxengineforum.com/f6-introduction
bnitram
Es tut mir leid , bitte vergib mir
Entschuldigung
I am well aware of the Intro part of this forum
If you saw my title of the post I said I was sorry in advance for the brief HiJack
I remember being first to welcome you in the intro thread you started Dec 1012
And I still feel the same way about you and your country
V/R
V/R
Hi guys,no problem,I'm just a normal rc cox fans from far far away Taiwan.
Glad to know some body had been stay in my country.
Yesterday I finally start the engine on chassis
Also play a while the throttle valve and needle valve with finger,right now I'm going to assemble all chassis then try it again,the zip starter look like really not good for start the cox engine,I already order some new spring part,will going to replace once I received,maybe can turn the zip starter more strong and easy start.
I will post some picture or video once I start the engine.
Es tut mir Leid bnitram, aber...
For real?! Holy... Now that's quite a story right there! Feel free to tell more, maybe on some other thread so as not to hijack this one.
ive always liked the GTP kyoshyo version but could never afford one ( they always get bidded out off my reach on evilbays)
Yes im back on CEF...(i think ive delt with all the lil demons in my head...after our son's demise)
ekitten2- Gold Member
Page 2 of 2 • 1, 2
» WTB: Kyosho Nitro VW Beetle or Mini Cooper (Cox .049 powered)
» Kyosho Cox .049 Mini Cooper Engine Assembly
» kyosho 049 mini/beetle
» Selling my Kyosho Cox Beetle & Cox SkyRally
» Searching for a kyosho cox vw beetle manual(Found!)
Page 2 of 2
