» My N-1R build logby roddie Today at 12:17 pm
by bsadonkill Today at 11:31 am
by MauricioB Today at 10:49 am
» Octura engines?
by UncleLumpy Today at 8:16 am
» Tatone EM-7
by sosam117 Today at 7:50 am
» Honoring All Who Served
by rsv1cox Yesterday at 3:30 pm
by TD ABUSER Yesterday at 1:41 pm
by balogh Yesterday at 1:36 pm
» K&B .09 Torpedo Engine
by LooseSpinner99 Yesterday at 12:01 pm
» 3D printing of parts?
by UncleLumpy Yesterday at 9:08 am
» L4 Grasshopper
by bottomgun Yesterday at 7:58 am
Kyosho .049 Cox VW Beetle / Mini Cooper
Hello everybody,
this thread is the same as "Cox Stocker 0.49 / Indy Car / Nissan GTP" from "coxaddicted" but here we talk and share pictures or videos from the Kyosho .049 Cox VW Beelte or Mini Cooper.
So if somebody has this car let us know. Every picture or video from your car will be welcome.
Also if somebody has some questions about that.
bnitram
bnitram
bnitram- Silver Member
Re: Kyosho .049 Cox VW Beetle / Mini Cooper
Here are some pictures from my Beetle:
I think in one or two weeks it will be ready to run. If everything runs perfectly i will look for a new body or new paint because the old one is a bit broken.
bnitram
bnitram
I wondered, how fast do those go on an 0.049?
daddyo- Gold Member
I guess around 18mph, the COX Stocker should reach 30mphdaddyo wrote:I wondered, how fast do those go on an 0.049?
Here are all available Kyosho Cox Cars:
Here is a close up from my Beetle:
Bnitram, do you have got the pump-filler cap of the tank? You need this for easy priming the engine.
coxaddicted- Gold Member
Nice car too!
Yes i have pump-filler cap but my is broken. But if you take a normal medical syringe and put a little piece of hosepipe(Schlauch) over the output you can push air into the tank. That works perfectly.
I also have a question to you:
How much ° degrees does the gas and steering servo move?
45° / 60° / 90° or how much?
bnitram
bnitram
Does no body no?
bnitram
bnitram
Hi bnitram,
the servo move is very limited at this model. Both is adjustable, my gas servo moves only 30° between full throttle and brake.
You have to check if the valve in the muffler opens complete, idle will be adjusted over the valve too.
The steerring servo also around 30°. You can pm me if you like.
Regards
Regards
Hi,
how can i adjust the movement ?
My Servos has 45°.
Yes. The throttle is set correctly.
bnitram
My Servos has 45°.
bnitram
Hi all,
since my last post i had not much time for my car. But in the last two days i build a controller which allows me, to reduce the servo movement to max 30°.
Here a pic:
This controller is based on a ATtiny13, who converts the signal correctly.
I will try to make the test run today, but the weather is not very good. I hope it will change in the next hours, so i can make a test run.
Here is another picture where you can see the currently built technology:
bnitram
Here a pic:
bnitram
The weather has change for some hours and I could make my test run
After I tried lots of times to start the engine,it always run for some seconds. After half an hour it RUN!
So I make a test drive, but my brakes doesnt work and the idle speed was too high, so i cant stand still. The car was driving any time....
While I was driving I lost my battery and I had no more control of the car. At the end the car drive under another (real) car and overturned...
Nothing happend to the car, but I have to trim the settings. The next time I will run it, I will make a Video too.
bnitram
bnitram
coxaddicted wrote:I guess around 18mph, the COX Stocker should reach 30mphdaddyo wrote:I wondered, how fast do those go on an 0.049?
Thanks for getting these two threads going. Can you provide some history on these models? What years were they manufactured? Also, I see them come up on Ebay from time to time in both used and new condition. The new ones seem very expensive. How much should they cost in a used and new condition? Thanks for any information. Andy
anm2- Gold Member
Hello Andy
I only know the production time of the GTP Nissan and the Stocker discussed in the other thread.
The GTP Nissan was produced from 1989 to 1991 and the Stocker from 1990 to 1993.
I also have the manuel from both car types. GTP Nissan/Stocker and from the Mini/Beetle.
If you want the PDF's write me.
Some informations about the Mini/Beetle:
Measure died: 1/12
Length: 339mm
Width: 164mm
Height: 121mm
Wheelbase: 210mm
Ground clearance: 12mm
Track width: 130mm
Wheel diameter: 55mm
Wheel width: 27mm
Translation: 6.87 / 1
Weight: 950g
bnitram
Measure died: 1/12
Length: 339mm
Width: 164mm
Height: 121mm
Wheelbase: 210mm
Track width: 130mm
Wheel width: 27mm
Weight: 950g
bnitram
i once had a mini cooper
i still am bummed that i had to sell it
robot797- Platinum Member
Just bought this little awesome Beetle from used,but there is no gasket under my engine glow plug head,the Kyosho original manual also did not show the gasket,any body got same question???or i just get a gasket?what model is this .049 engine?
brianskate- Moderate Poster
Hello brianskate,
when I bought my car this gasket was also missing but its the standart 049 gasket. You can buy it here:
http://coxengines.ca/cox-.049-glow-head-gasket-3.html
The engine is a standart Cox .049 Production Engine like this one:
http://coxengines.ca/cox-.049-production-engine-pt-19.html
Nothing realy special. You can take parts from all 049 cox engines without SPI. Only the glow plug is special because of the lathed surface(without the fins), but you also can take a "normal" and turn it on a lathe to a "car glow plug".
It would be nice if you also can post some pictures
with best regards
bnitram
PS:
Do you have an english version of the manuel? I only got a japanese manual...
with best regards
bnitram
PS:
Hello bnitram,
So happy can get some response from you,look like i really need to get a gasket for my engine,i going to use diesel fuel to clean my engine,should i also put the glow head into the fuel for clean??
for the glow head replace part which one should i get??
Cox part # 325
Cox Part # 1702
also the normal glow head you mention is this adapter right ??
SKU: 49ADAPT
ps.my manual is same like your japanese version.
here is one of my disassemble pictures
Cox part # 325
Cox Part # 1702
SKU: 49ADAPT
Hello
Yes. A new gasket is a must. If you need a new glow plug you have to take the 325 but you also can take the adapter that you have ride above. I don't have the adapter but I will make one by my self because I have 3 broken heads... Than its cheaper to convert it than by original heads...
Oh I don't no. A safety way is to take rc fuel.
With best regards
bnitram
With best regards
bnitram
YES,going to clean my engine as soon as possible,can't wait to see this little guy back on line.
I also realized the pull start only pull motor like one 360 turn,is that enough to start the engine??
brianskate wrote:YES,going to clean my engine as soon as possible,can't wait to see this little guy back on line.
Yes. The spring starters are only to pull the engine though 1 rotation on the airplane engines. All it takes is one good bump and it is off to the races!
To the Forum brianskate , Nice looking cars !! Guys , Getback Would like to see those babys in Action!!
Ha..Ha..Ha Just found the gasket inside top of cylinder.
Forgot to introduce myself ,I'm from Taiwan~Hello everybody~
Of course! The starter is very good and the engine runs directly the right direction.
Haha yes. The gasget remains mostly in the motor when the head is removed.
If your glow head is still ok you can fire it up after cleaning
@getback:
If the weather in germany would be better i will make a video. It's really a nice car.
with best regards
bnitram
@getback:
with best regards
bnitram
Engine parts diving
Got some vintage new 335 1 fin glow head
Oh great. You have luck. How far are you ? When will you finish the car ?
bnitram
bnitram
» WTB: Kyosho Nitro VW Beetle or Mini Cooper (Cox .049 powered)
» Kyosho Cox .049 Mini Cooper Engine Assembly
» kyosho 049 mini/beetle
» Selling my Kyosho Cox Beetle & Cox SkyRally
» Searching for a kyosho cox vw beetle manual(Found!)
