» Jim Walker Bonanza etc.
by Ken Cook Today at 5:03 pm
by rdw777 Today at 2:52 pm
by rsv1cox Today at 10:52 am
by roddie Today at 10:30 am
by roddie Today at 10:02 am
by TD ABUSER Today at 9:25 am
» 1940's?...............
by rsv1cox Today at 7:46 am
» Lesson learned
August-2024
Dukes Mixture
Dukes Mixture
I have been studying the transition from spark ignition to glow in the late 40s and was wondering how you found the best nitro content for a fixed compression engine.
http://www.modelenginenews.org/~modeng74/index.html
The link did not work, this is the page.
![Dukes Mixture Scan10](https://i.servimg.com/u/f39/17/78/70/41/scan10.jpg)
crankbndr- Top Poster
Re: Dukes Mixture
By the 40's internal combustion had been around a rather long time. Many different fuels had been experimented with and look-up tables for compression ratio vs fuel and additives had been established. Knowing the desired fuel, a compression ratio is decided upon for suitable performance. This can also be worked the other way, such as converting a spark engine to glow.
Also there is no such thing as "fixed" compression ratio. It can be adjusted by shimming on almost any engine there is. (which does involve taking the engine to pieces, so OK, fixed, not adjustable while operating.) The point is, the design can be adjusted after it is built so it functions best on the desired fuel.
http://en.wikipedia.org/wiki/History_of_the_internal_combustion_engine
Re: Dukes Mixture
The use of nitro in model engines was pioneered by the Dooling brothers and Ray Arden about the same time the glow head came around, late 40s.
Even before full size racers started using nitro, this was uncharted territory for modelers at the time.
Re: Dukes Mixture
I don't doubt the time that nitromethane was used in model, or any engines, in the public eye. The oldest source I find for nitromethane is about 1911.
https://www.google.com/patents/US1015691?pg=PA1&dq=nitromethane&hl=en&sa=X&ei=vKzRUbSNEIOyyAH
I believe the compound was first isolated long before this.
The use as a fuel in racing cars (drag racing) started in the 1930's. It sounds like the development of engines paralleled in both auto racing and modeling.
For reference nitroglycerin was synthesized in 1847,
http://en.wikipedia.org/wiki/Nitroglycerin
Re: Dukes Mixture
For our purposes there are several things we can adjust for the "perfect" run. Prop size, for the particular airframe it is pulling, at the velocity we want to pull it. We can adjust nitro content...which affects power AND affects how long we can run on a given amount of fuel...for those timed events. We can adjust venturi size (on some) which affects power and fuel draw. We can adjust glow plug heat ranges...to coincide with nitro changes. and finally we can adjust head shims... to fine tune the firing timing to coincide with all the other stuff. These things are adjusted to coincide with altitude, temperature and humidity changes.
For most of us in a non-competition environment, ballpark ranges are good enough.
Some "expert" flyers know just what to adjust for a flight and need to be consistent to get maximum performance. I guess that's why they are experts. :-)
gcb- Platinum Member
» Source for 25% fuel with pure castor?
» Fuel Mixture
» how to remove this engine!!
» O.S. FS 40 Marine
» Coper Reed valve melted too mutch détergent in fuel mixture
» Fuel Mixture
» O.S. FS 40 Marine
