Shell Shocks First Cox Build - Page 6 Cox_ba12
Shell Shocks First Cox Build - Page 6 Pixel
by getback Yesterday at 11:52 am
by GallopingGhostler Fri Nov 22, 2024 3:04 pm
Shell Shocks First Cox Build - Page 6 Empty
Page 6 of 6 Previous  1, 2, 3, 4, 5, 6
Shell Shocks First Cox Build - Page 6 Empty Re: Shell Shocks First Cox Build
Post  nitroairplane Sat Nov 19, 2011 4:26 am
shell shock wrote:not at the moment. still waiting on a clear day to test the new lighter tail...
thanks for the show of interest man
So where is your balance at?
nitroairplane
nitroairplane
Post  shell shock Sat Nov 19, 2011 8:18 am
he he he, by addind a 2oz weight (bringing the total to 14oz) it is 1 inch into the wing (going from the back)
shell shock
shell shock
Post  RknRusty Sat Nov 19, 2011 8:36 am
Huh... Shouldn't it be more like 1" behind the leading edge?
Post  shell shock Sat Nov 19, 2011 9:41 am
im still looking for ways to bring the CoG away from the trailing edge.
shell shock
shell shock
Post  Mark Boesen Sat Nov 19, 2011 10:21 am
More thoughts: possibly add a thick firewall, maybe cut a 1"x2" piece of wood, moving the engine forward? Move the wing back if possible, also I'm sure you've moved the battery pack as far forward as possible?
At least now you'll remember to check CG.
Post  nitroairplane Sat Nov 19, 2011 10:37 am
yes I used a really thick firewall on my first CL model because I used a new Sure start instead of the heavy DC wasp it had before.
nitroairplane
nitroairplane
Post  Mark Boesen Sun Nov 20, 2011 10:52 pm
...forgot to mention, larger heavier wheels can also add to nose weight.
Post  microflitedude Mon Nov 21, 2011 12:24 pm
I think at this point, you should try to remove weight. 14oz is pushing it for an easy to fly airplane.
Did you move everything as far as you can forward?
microflitedude
microflitedude
Post  Mark Boesen Mon Nov 21, 2011 2:39 pm
Obviously the goal is to build a plane as light as possible and if it's tail heavy, naturally you would want to remove weight if possible, but realistically there isn’t much aft of the wing you can remove.
1st step: move equipment/engine forward.
2rd step: add nose weight.
3rd step: modify airframe, move wing back and/or shorten fuselage.
4th step: all of the above
Years ago on my control line aerobatic models where CG is very critical, adding heavier wheels or lighter mains and larger tail wheel would sometimes give me the balance I would be looking for.
Post  shell shock Sat Nov 26, 2011 12:52 pm
wow, i missed alot. Yes, i have cut a large section of the rear tail. just enough to bring the CoG forward abit. using front gear would btring it up further. thanks for all the input guys
shell shock
shell shock
