Another build
Another build
The weather here is still rough. Very wet and windy and so it is time to start another build.
I won't say what it is but feel free to guess. It is a kit that I have had for some time and supposedly 1/2 A.
The wing looks a tad complex but is based around a 3/32 balsa spar with a 1/32 ply reinforcement in the centre section. Although a kit, the spar is made from sheet material by sticking on patterns from the plan.
These patterns were not easy to line up straight and took quit a few attempts using the guidance of a straight edge.
Anyway, here is the spar - almost 3ft long
Re: Another build
THAT is pretty !!!!!!!!!!!!!
Re: Another build
Impeccable construction Ian. So.. it's not a scale model.. which leaves me with nothing for a guess. Something whispered Eindecker to me.. when you posted photos of the built-up wing.
Re: Another build
Strike two. I'm not good at this.
Either way if Ian's building it I know it will be good.
Re: Another build
I can see why Eindecker came to mind - when covered it could also look like "Das Ugly Stik".
It also seems to be large for 1/2A - at first I thought it was UK 1/2A with a 3ft wingspan for control line.
Re: Another build
My first thought was a Stik, but the tip is wrong, as is the trailing edge and there's not two leading edge ribs in a Das Littlest Stik. 36 inch span is really big for 1/2A too. Hmmm.
No clue, but it sure is pretty. Please carry on. The fuselage might give it away.
Dave P.- Gold Member
Re: Another build
Looks to me to be a Brodak 1/2A Pathfinder there's not too many I-Beam wings in 1/2A.
Re: Another build
Ken Cook wrote:Looks to me to be a Brodak 1/2A Pathfinder there's not too many I-Beam wings in 1/2A.
Well done Ken, you are correct. Will post more details later today.
Re: Another build
I was flying one with a Norvel .061 Big Mig, is this going diesel? I found the gear extremely weak which I remade. I enjoyed doing squares with this plane, it cuts corners very clean and accurate. I gave it to my flying buddy Larry and I know I'll never see it again. I don't know what he does with my offerings, I never see him fly any of them ever. I've gifted him at least 6 planes.
Re: Another build
Subscribed and taking notes. This one is on my Dream Sheet for a future build.
That wing is just a work of art! I can't wait to see the fuselage.
Re: Another build
Ken - I am still in a quandry with the engine for this. The kit specifies 049 to 070 and specifically recommends the Brodak 049.
I have several seemingly suitable engines including Brodak 049s but an 049 (0,8cc) seems to be a tad small for this airframe.
I have an AMA 061, a couple of Norvel 061s (but I can't find them), MP Jet 061 BB, Thunder Tiger GP 07 and a Norvel 074.
My first choice would have been the Norvel 074 but it has the button glow head, Although there are replacement heads on the Norvel Web site - standard glo, turbo glo and a diesel head - the site doesn't let me place orders to the UK so b******s to them.
The MP Jet is quite heavy and the Thunder Tiger is RC - the carb looks a little fragile for side mounted control line flying.
So I am now torn between the PAW 06 and AM 10 - both 1 cc diesel.
I keep considering electrifying it but the fuselage would need beefing up. I have seen the larger Pathfinders electrified and they fly really well.
Re: Another build
The Brodak .049 would be the completely wrong choice and it's only suggested because of who's selling it. I had the Norvel .074 on mine originally. Way too much engine, this is also a engine caught in between prop sizes with very limited offerings. I couldn't get the speeds under supersonic and this is very problematic for a stunter. Running it very rich was the only way to achieve what I was shooting for and adjusting speeds by your needle is very poor. You may already know this but removing your plug on your Norvel .061 and counting the holes in the liner quickly determines sport engine vs combat version. 3 holes in the liner is the higher performance AME vs 5 holes for the Big Mig. I like your thinking on the PAW .06. I've always desired that engine. I think it would be over the top cool to see that on the nose.
Re: Another build
The engine will be a PAW 06 (100).
One of the problems with the PAW engines is identifying them. They all look the same size and PAW keep changing the naming convention. The 80 is also the 049, the 100 becomes 06, the 149 the 09, the 249 the 15 .................... there is a 55 or 033!
The 049 and the 06 share the same case and have the same dimensions - so does the 15 and the 19, the 29 and the 35, the 49 and the 60. Then they have the plain bearing, single bearing and twin bearing versions as well as competition tuned.
They are not always marked. The 06 I have has no markings but all the 100s have 100 stamped on the cover plate The anomolies are endless.
There are restrictions at my flying field where all engines except diesels up to 15s must be silenced. We fly PAW 19s unsilenced because you can't tell the difference!
Re: Another build
Never thought I would hear Ken say something is too powerful. I guess with limited props it just is too much.
Looks good Ian, surprised you chose another slab sided model!
Re: Another build
Cribbs74 wrote:Never thought I would hear Ken say something is too powerful. I guess with limited props it just is too much.
My dislike of slab sided models holds no bounds but I cannot resist a bargain. Unfortunately, depending on your point of view, I have over 15 slabby sided kits - 5 of which are Flite Streaks (one is the Combat which a proper fuselage), two are Carrier deck and a variety of Sig and RSM kits.
As some of my fellow modellers have moved to RC over the years (and got older!)- every now and again they have gone for loft clearance of kits they are not going to build. Some are ancient and I get them for the price on the box and so at current prices (and lack of kits in this country) - they are a bargain.
They always come with a PROPER model aeroplane though!
The picture on the Pathfinder box is also decieving. At first glance, it looks like a proper fuselage.
Re: Another build
Back to the build. I find sanding a laborious and often mind numbing process so sanding 1/4" stock for flaps isn't a task I look forward to.
However, I have found that using tape to mark out or define areas for sanding (per Windy videos) and taking the slightly risky approach of using 80 grit paper to remove the bulk really speeds this up.
I also use these to keep a straight edge
and
for profiling
and
for profiling
Re: Another build
The plan for this model promotes the normal wing hinges but the trailing edge of the wing is flat and 1/4" thick and the flaps are 1/4" rounded.
Hinge fitting - first of all freeing the hinge for clean movement and then slotting is another laborious task prone to error in lining up the hinges. The trailing edge would also present problems sinking the hinge so that the pin is flush.
I thought I would try the round pivot pin hinges.
So using my trusty Proxxon drilly thing with a grinding point (a drill bit tends to rip balsa)
drilling a hole is easy and quick
A little push with the hinge itself creates a nice square hole to sink the hinge
et voila
marking the centre point of the hinge for mating
Then we have a really flush neat flap joint. The whole process for two flaps took 10 minutes.
et voila
Re: Another build
That is a nice looking wing Ian . You build fast ! I spend more time looking and thinking at my plane than building it but they eventually get done and flown .
Mike1484
Mike1484
Mike1484- Gold Member
Re: Another build
Now things get a little fiddly - more time with not much to show.
The tailplane is complete
but this needs normal hinges and a wire elevator joiner and hinge making. Constant fit and refit until the elevators are parallel.
The wing flaps also needed a flap joiner and hinge
I now have to be careful when I remove the flaps, elevator and joiners to replace them exactly as removed or I will end up with them cockeyed.
» 2x4 kit build
» Idk how to build.
» look what rkflyer sent me and jack AGAIN!
» My son’s first C/L build
» 2x4 kit build
» Idk how to build.
