» My current avatar photoby roddie Today at 8:48 pm
by 1975 control line guy Today at 8:05 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by Levent Suberk Today at 2:10 pm
by rdw777 Today at 10:28 am
by layback209 Today at 1:20 am
by rsv1cox Yesterday at 6:55 pm
by roddie Yesterday at 6:20 pm
by roddie Yesterday at 3:27 pm
» Octura engines?
by UncleLumpy Yesterday at 8:16 am
» Tatone EM-7
by sosam117 Yesterday at 7:50 am
P.A.W. .09 Diesel Lazy Bee Installation
Nitro's evil influence continues as my second P.A.W. Diesel arrives from Mr. Eric Clutton and gets put through it's break-in paces. After threatening to remove the P.A.W. .06 diesel from my faithful Lazy Bee and reinstalling my equally faithful O.S. .10, I was suddenly seized by the idea of upping the engine size with a larger diesel. It came in today, and I had to hustle through my afterwork stuff to get some time to put it on a stand.
These suckers surely are a different breed of cat, and I've got to admit that I really like their low buzz on a close fly-by. It's fairly cool out tonight, and I DID have to heat the head a bit with a heat gun to get it to finally pop, but it finally settled into a good run in spite of my still-amateurish attempts to reconcile it's mixture and compression adjustments.
I ran out of energy and daylight at about the same time, so it'll get bolted to the Bee later. Videos to follow...
Re: P.A.W. .09 Diesel Lazy Bee Installation
Kim wrote:...These suckers surely are a different breed of cat, and I've got to admit that I really like their low buzz on a close fly-by. It's fairly cool out tonight, and I DID have to heat the head a bit with a heat gun to get it to finally pop, but it finally settled into a good run in spite of my still-amateurish attempts to reconcile it's mixture and compression adjustments.
Kim, here's a link to the hows and whys of PAW break in...LOTS of good info to get the best from your PAW.
http://www3.telus.net/dieselcombat/diesel_care.htm
Hope it helps.
gcb- Platinum Member
PAW engines are very straight forward to use, for the 09 mkII a 9x4 or 8x6 prop is a good match and just take your time running in the engine, it will improve gradually for quite some time.
The carb is a little crude (and lean at low revs), and you can get a better idle by using an Enya 09 carb (direct drop in and gives you an adjustable airbleed). The stock carb should still give you an idle around 3500rpm though. Here is one off mine (an mkII) in a thunder tiger scooter;
TT Scooter and PAW 09RC
Thanks Guys !
The Lazy Bee gets it's forth or fifth power-plant switch in it's 18 years of cruising Missouri Skies. I spent this evening extending the Bee's throttle cable, modifying a Hayes engine mount for the P.A.W. .09, and making up a new mount for it's film canister fuel tank.
Now, we just need another calm evening, so that the Bee can try out it's new diesel engine.
There seems to be a very large gap between the crankcase and prop driver, is it on properly?
If the gap is too large the crankpin will hit the backplate at low revs. You might want to put a few shims behind the propdriver before you run the engine.
» what airplanes have you built? post your pics of the models and feel free to talk about your airplanes
» Lazy susan for lazy U-controllers?
» Introducing the Blue Bee, the Blew diesel Medallion, and the disappointing OK Cub diesel.
» My DIESEL fleet and Diesel fuel blending DIY
» Diesel Fuel Question
