fuel tanks Cox_ba12
fuel tanks Pixel
by roddie Today at 8:48 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by rdw777 Today at 10:28 am
» Octura engines?
» Tatone EM-7
fuel tanks Empty
fuel tanks
fuel tanks Empty fuel tanks
Post  luke.w.pc Mon Aug 20, 2012 4:54 pm
hello im new to this forum and glow engines in general, i've recently purchased a surestart engine and fuel but not a fuel tank.
i am thinking about making a fuel tank but dont understand how the fuel will enter the the engine, will it suck in on its own, have to be gravity fed, or pumped in?
Would a syringe with plunger be ok or with an elastic band on th plunger to pressurise it.
I have also seen film canister tanks i assume they need a vent hole to allow fuel to flow out but how dosent the fuel leak from the vent?
thanks luke
luke.w.pc
luke.w.pc
Beginner Poster
Beginner Poster
fuel tanks Empty Re: fuel tanks
Post  jsesere Mon Aug 20, 2012 10:51 pm
Once the engine starts burning the prime it will suck fuel from the tank assuming the tank as both a fill/vent tube at the top and a fuel outlet comimg from the bottom inside rear of the tank. The tank can be leveL or slightly elevated.
Tanks are cheap. Here's a link to a 1 oz on eBAY.
http://www.ebay.com/itm/Sullivan-Fuel-Tank-Slant-1oz-SUL435-/360416623775?pt=Radio_Control_Parts_Accessories&hash=item53ea813c9f
jsesere
jsesere
Post  Jason_WI Mon Aug 20, 2012 11:03 pm
Or you can also use a tank that fits right onto the fuel inlet of the sure start:
http://coxengines.ca/cox-integrated-mini-fuel-tank.html
Jason_WI
Jason_WI
Post  jsesere Tue Aug 21, 2012 12:43 am
Only about a 60 sec run time though.
jsesere
jsesere
fuel tanks Empty Fuel filter
Post  luke.w.pc Tue Aug 21, 2012 6:38 am
Thanks for responses, Would it be expected to have a fuel filter if so which one and where do I get it?
luke.w.pc
luke.w.pc
Beginner Poster
Beginner Poster
Post  jsesere Tue Aug 21, 2012 7:33 am
Keep your fuel clean and you won't need one, but if you must try http://www.ebay.com/itm/Du-Bro-Silver-Aluminum-In-Line-Fuel-Filter-/350585474476?pt=Radio_Control_Parts_Accessories&hash=item51a085cdac.
jsesere
jsesere
Post  RknRusty Tue Aug 21, 2012 8:50 am
Welcome to CEF.
The starting instructions for the Surestart explain to open the needle and then use your finger to block the choke tube. Then hand turn the prop a couple of revolutions and the engine vacuum will pull fuel and prime the line. The height of the tank should be near the height of the engine centerline so it doesn't gravity flood, or so the engine doesn't have to work to pull the fuel uphill.
You can use a syringe until you get a tank. At least that will allow you to feed it while you do the break-in procedure.
Here is the engine manual:
http://coxengines.ca/files/049%20Surestart.pdf
Post  PV Pilot Tue Aug 21, 2012 10:49 am
Welcome to the site Luke. The vent on the assembled tank it placed upright, or , on the top of the tank stopper so fuel does not leak out.
I like the clear Sullivan Flextanks as opposed to the opaque white style. that way, as you bend your vent tube during construction, you can see where it is supposed to be placed at the top of the tank skin. Also the clear tanks allow you to see the fuel level easier when it is stuffed down inside a plane.
The Sullivan tanks come with instructions for assembly, where to place the vent, the bend in the brass tubing needed, ect.
http://www.sullivanproducts.com/Fueltanks1Content.htm
At the bottom of the page there Luke, you will see the Flextank slant type and you can see where the vent tube needs to bend up into the molded bubble on the top of tank. I use the clear Flextanks and reccommend them to everyone. They are easier on you all the way around, from construction to use.
PV Pilot
PV Pilot
High Tech Balsa Basher
