» Took an engine out last weekby OVERLORD Today at 2:56 am
» *Cox Engine of The Month* Submit your pictures! -November 2024-
by KariFS Today at 2:49 am
» COX .020 POWERED SPEEDSTER
by TD ABUSER Today at 1:59 am
» Cox extra 300s
by 1975 control line guy Yesterday at 9:57 pm
by Ken Cook Yesterday at 7:53 pm
by Ken Cook Yesterday at 4:16 pm
» Throttle control for Cox .010 "Viking" engine.
by ffkiwi Thu Oct 31, 2024 9:12 pm
by roddie Thu Oct 31, 2024 8:33 pm
by roddie Thu Oct 31, 2024 7:50 pm
by 1975 control line guy Thu Oct 31, 2024 9:54 am
» The Wood Shovel
by getback Thu Oct 31, 2024 5:27 am
by crankbndr Wed Oct 30, 2024 7:08 pm
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: COX .020 POWERED SPEEDSTER
I use to do swept tipped rounded flying surfaces, looks cool and appears fast just standing still.
Thru many Nano versions my understanding and approach for max speed changed.
Field tested noted improved performance:
Formed true airfoils for all flying surfaces, vertical stab included to obtain premium control and
function for the given surface area goals and to decrease R values.
Fully sculpting the balsa is an absolute must, I start with SIG airfoiled balsa for the wing.
3in and 4in wide planks depending on the engine displacement mod to semi or fully symmetrical.
Matching left and right moderate tapered leading edges to avoid surface trim corrections.
*** no swept tips as it reduces total leading edge drag and sharp squared off surface tips.
Leave it to gain longer narrow surface spans for improved lift and control - like gliders.
Gradual small surface control deflections to avoid abrupt drag angles from narrow
strip ailerons and elevators. Proper size surface control horns to achieve low drag.
Minimal firewall and air voids within the fuselage designed around the proper sized components / wires.
Example:
Example:
1/2A Nut wrote:I use to do swept tipped rounded flying surfaces, looks cool and appears fast just standing still.
That's a nice, clean and simple design there..!
I found a few sheet balsa wings in the attic that might be worth trying with the .020 fuselage that I'm running now.
Leaving the tips squared off works for me...
TD ABUSER- Gold Member
» TD .051 Powered RC Speedster
» For Sale: Two Estes Killer Bee 049's
» Cox .049's sweep top two spots in Open Vintage Speed in Santarem Portugal
» 38-in. Jetco Rearwin Speedster
» Mini Speedster plans please.
Page 4 of 4
