» Duende V model from RC Model magazine 1983.by MauricioB Today at 3:46 pm
by Kim Today at 12:35 pm
by rdw777 Today at 9:28 am
by Kim Today at 9:18 am
by Admin Today at 1:35 am
» Engine choice
K&B Sea Fury outboard engine, casting and box repair
I have seen a lot of castings in my lifetime, HO gauge locomotives - plastic, zinc, brass, bronze; model airplane engines etc.. But I have never seen a casting better than this K&B outboard engine. From the starter on down to the propeller it is excellent. Fit and finish even on this vintage example is so well done. I wonder why Cox never offered one.
Box is stained and the stage for the engine is well bent. Pledge and a warm Monokote iron helped to lessen the damage.
Re: K&B Sea Fury outboard engine, casting and box repair
$10.95 back then is every bit of $100 today. I would think that very few teens owned one of these when they were offered.
Ken Cook wrote: $10.95 back then is every bit of $100 today. I would think that very few teens owned one of these when they were offered.
This guy did Ken. From his ebay description:
My Boyhood Sea Fury which powered a kit boat back it the day. Turns over with a satisfying pop and is clean and complete.
Please note the ping pong balls dated '56 and initialed. These were tied to the engine in case of a loose engine or "high speed disintegration".
Stand and balls included (currently cracked and fragile) if desired.
$100 would have bought all my Cox engines and hollow logs when I was a kid. Earning fifty cents an hour - $5.00 for a 10 hour day working on a poultry farm wasn't easy and I watched every dime. Still do. The fellow accepted my offer.
But Sea Fury #2 arrived today. I was wondering how he was going to pack those ping-pong balls. Clever, packed inside a hard plastic cylinder.
Slightly different engine, perhaps older model. Glow plug configuration is different and there is no "pilot" (above on parts illustration) to set thrust angle. Beautifully clean.
Edit add.... Whoops, looks like I never included a parts illustration. It's that multi-toothed thing just under the fuel tank.
Very Cool Bob ! She is clean that boy took good care of his toys , should get Jacob to put the instruction sheet in the section for them . That is a good idea to put ping pong balls on it to keep above waters to retrieve if needed I had a chance to buy 3 of them at one time for $350 wish I had now and then but budget would not let me do it Nice stand for it too !
getback wrote:Very Cool Bob ! She is clean that boy took good care of his toys , should get Jacob to put the instruction sheet in the section for them . That is a good idea to put ping pong balls on it to keep above waters to retrieve if needed I had a chance to buy 3 of them at one time for $350 wish I had now and then but budget would not let me do it Nice stand for it too !
Thanks Eric. Me being me I installed the engine backwards on the stand. Picture above. Got it right now. I got a kick out of the fuel tank cap attached by a chain. Product of the '60's my '84 RX-7 doesen't even have that feature.
Are you going to run it , i know I would want to hear that baby even in a tub of water (bathtub) not
rdw777- Diamond Member
getback wrote:Are you going to run it , i know I would want to hear that baby even in a tub of water (bathtub) not
Nah, I'm to much of a coward. The two I have are just too nice. I have been looking for a beat-up example but the worst ones now on ebay are still too nice and cost more than the two that I have. One will pop up some day. The damaged Wen Mac with the Cox cylinder is in my mailbox right now, I'm just to lazy to go down and get it.
Nap time for this old fella after spending the morning working in the woods.
Robert, I keep my eye out for something. Maybe outerzone has plans. Steam and bend, I may make my own. Another "Silver Lining" that floats use for your stencils.
I find it strange, I never was attracted to these glow boat engines..................now
Hello!
I'd found a Allyn Sea Fury last weekend that is in perfect state but, unfortunately the needle is missing.
I'd found yours posts and I'll interested to know i you can give me the dimensions of that part.
A little dimensioned drawing will be appreciate.
Does a Cox .049 needle could fit on that engine?
I not sure to make it navigate but i would like to crank it one time at least.
Thanks for your help
Gab- Beginner Poster
Bonjour GAB, et bienvenue sur le forum
Nous sommes dans le même « bateau » pour ainsi dire, l’un des miens manque aussi l’aiguille. J’ai joint quelques photos, faites-moi savoir si vous avez besoin de quelque chose de plus précis et je sortirai mes pieds à coulisse.
Hi GAB, and welcome to the forum
We are in the same "boat" so to speak, one of mine is missing the needle too. I attached some pictures, let me know if you need something more precise and I will get out my calipers.
This Atwood needle from MECOA may fit, but it would be best to ask someone who has both type engines and see if they swap from one to the other.
https://www.mecoa.biz/shopexd.asp?id=1433
Merci Bob, thanks Oldenginerod!
Even if french is easier for me i continuing in english, it's will be more understandable for the international community, no? (Or not... )
Caliper is a good suggestion.
The most difficult will be for the thread. Something tells me that it's a imperial ones...
I'd a look to the mecao link but it seems to me that this needle is shorter than the original. Even if i can see K&B on the page...
I'll contact them and ask their opinion...
Yes it actually ran!
I have one of these and I ran it. Before R/C you let it go and hoped it circled back. Even used it briefly on a hydrofoil equipped model. My University prof was very impressed as was I.
This goes back to 1974.
706jim- Gold Member
Hi Gab, Welcome to the forum!
I noticed that the engine in your photo has a "spark plug" installed. I believe that there should be a "glow plug" installed in its place. A spark plug requires the use of other ignition components like a battery, coil and breaker-points. A glow-plug doesn't need these extra parts to ignite the fuel. The fuel for a glow-plug engine is "GLOW-FUEL" which is a combination of methanol, nitromethane and castor/synthetic oil.
I could be mistaken.. but make sure that you know what you have BEFORE attempting to run the engine.
Best of luck finding a needle for it.
Roddie, Champion made those plugs as glow as well. They made the 3/8"-24 spark plugs, 1/4"-32 spark plugs and 1/4"-32 VG-3 glow plugs
Thanks Bob!
So if i well understand the pictures, the major thread diameter is 1,75mm and the minor thread diameter is 1,13mm.
It's could be UNF #0: .060/.047 (1,52mm/1,19mm) or a size 11 in BA standard (1,5mm/1,13mm).
Could you confirm me that the major thread diameter is the same than just behind the knurled button?
Can you have a look too on the dimension from the tip of needle and the start of thread?
Thanks.
@roddie, thanks you.
i'm used with glow and spark plugs, i didn't already have a look to it.
it seems that it's,as say Ken Cook, a Champion VG-3 glow plug so i have to see if it's good or if should find a new one.
Thanks.
So for the moment i staying on a BA11 ( due to the inner diam of 1,13).
From my researches, i'd found that this standard is a old one (BS93:1951) and that could match to our 1954 engine...
I'd manage to find a BA11 die in England ( steam models )
I'm not allowed, for the moment, to post the link...
it's seems to me that the tread, on pictures, is a little smaller that the shaft...
If you tell me that the major thread diameter is 1,5mm it's could be winned!
It's 1.71 vs. 1.74 within the margin of error of my calipers. Actually all they did was thread a blank shaft probably removing a little metal in the process. It could very well be 1.5mm.
The Champion plug is quite old and I personally wouldn't use it. The wire has a fair amount of resistance and it takes a stout battery to light one off especially if you flood the engine. They make great conversation pieces and look great on period correct shelved engines. If you want reliability, use a new plug.
Gents I don't know why you are rabbiting on about 11BA-there is NO way on earth that an American engine would be using a BRITISH thread on the needle valve. I hope I don't have to explain-in an international forum like this that 'BA' is the abbreviation for 'British Association'-a thread series first proposed in 1884 and adopted in 1903-mainly used in clocks, watches, scientific instruments and electrical equipment. Even more ironically in the context of this particular forum thread it has a METRIC base.....and the antipathy of the USA to all things metric is well known....
The thread you want is 1-72.....how do I know?...because I have two Furys here both awaiting new needles-and currently sporting a 1-72 socket head screw screwed into the spraybar awaiting the day I get sufficiently motivated to turn up a suitable knob for the end and grind an appropriate taper on the other.....
Microfasterners.com will be more than happy to sell you a small quantity of 1-72 screws.....that's where mine came from-1-72 socket head in 1 inch length.....from memory that was the only head format I found on the website that offered that length in 1-72....and has the advantage that the small diameter socket head can be easily concealed with a knob...or if you so desire-in the interests of authenticity, cut off...and a replica larger diameter flat knob tapped 1-72 screwed on and soldered in place.....
ChrisM
' ffkiwi
ChrisM
' ffkiwi
ffkiwi- Gold Member
"Fighting the metric system every inch of the way" Rene - AKA Markeysky.
1/72 sounds about right Chris. I have been tempted to try a variety of needles in the Sea Fury, but have never gotten around to it. Thanks for the education.
So a UNF 1-72, less exotic than my BA one
I'll look for that type of screw or die at 1-72.
As we says: it's better one who know than ten who search, thanks ffkiwi.
» Engine Fury 049
» Cox Outboard engine
» Crazy bee powered wit m'y reed fury engine
» Help in sorting out the W/M Atwood outboard engine.
» Interesting vintage engine. Fury Twin Stack
