Throttle control for Cox .010 "Viking" engine. Cox_ba12
Throttle control for Cox .010 "Viking" engine. Pixel
Throttle control for Cox .010 "Viking" engine. Empty
Throttle control for Cox .010 "Viking" engine. Empty Throttle control for Cox .010 "Viking" engine.
Post  MauricioB Mon Oct 28, 2024 6:05 pm
Prototype.
In an attempt to preserve the original shape of the Cox .010 engine cylinder (this one is stepped, has a skirt at its base, does not allow a direct throttle control ring, without first modifying it for the case), then, I made this double-outlet exhaust chamber and each outlet has a post-combustion engine gas exhaust control valve, which interact with each other by means of a steel wire. The two valves work in unison, controlling the engine rpm.
Judging by the size of the pieces made, (very small to the hands), place two coins in comparison, 1 EURO on the left and 1 ARGENTINE Peso on the right.
In the photos you can see the parts and the assembly of the pieces.
Throttle control for Cox .010 "Viking" engine. 20241016
Throttle control for Cox .010 "Viking" engine. 20241017
Throttle control for Cox .010 "Viking" engine. Empty Re: Throttle control for Cox .010 "Viking" engine.
Post  706jim Tue Oct 29, 2024 12:17 am
Beautiful work!
706jim
706jim
Post  ffkiwi Tue Oct 29, 2024 12:19 am
Nice work Mauricio.....and an interestingly different approach. somewhere in my archives I have an Aeromodeller Annual article on exhaust restrictors for Cox engines...probably dating to the mid 60s or thereabouts, on home made restrictors to reduce power for trimming. IIRC there were construction dimensions for all sizes of Cox....including the orifice hole size....which might relevant to your efforts...
ChrisM
'ffkiwi'
ffkiwi
ffkiwi
Post  balogh Tue Oct 29, 2024 12:29 am
Fantastic accessory, Mauricio..looking forward to your test stand video..how do you add the ring to the cylinder if the skirt on the cylinder base is not removed?
Post  MauricioB Tue Oct 29, 2024 7:56 am
Thanks guys, any information you can provide is welcome, thanks in advance!
András, the exhaust chamber hugs the base of the crankcase, that is to say the lip that the crankcase has, which is practically equal to the diameter of the cylinder skirt, at the top, the first cooling fin is in charge of making the final pressure on the exhaust chamber, a custom-made washer can be placed if necessary, but if the measurements are taken perfectly, it will work correctly.
Detail: on the back of the chamber, you will see a threaded plug, this is to place a pressurizer, but apparently, it is not necessary.
You can see the video here, I am very surprised, it really works haha, it works! I can't believe it!!! I LOVE THIS FORUM.
If you are really interested in making it, I have no problem passing the measurements of my .010 VIKING Controller!
Post  getback Tue Oct 29, 2024 8:20 am
WOW It throttles really good better than most the exhaust throttles i have seen very quick! Job well done ! Very Happy
Post  balogh Tue Oct 29, 2024 8:30 am
This is amazing, Mauricio! And thanks for the clarification about how the throttle chamber mounts on the cylinder...
Post  Levent Suberk Tue Oct 29, 2024 12:26 pm
Clever design Very Happy
Post  rdw777 Tue Oct 29, 2024 12:47 pm
Beautiful engineering and craftsmanship Mauricio!!!…. Producing and working with parts this small is very challenging…. It works perfectly…. Not very often achieved with the .010 attempt to throttle…. Do you have an certain airplane in mind for it?
Post  MauricioB Wed Oct 30, 2024 6:42 am
balogh wrote:This is amazing, Mauricio! And thanks for the clarification about how the throttle chamber mounts on the cylinder...
Thanks to you Andras. There really are no losses, but for that, machining must be done with a digital caliper, that way the precision is much more secure, at least in my case.
Post  MauricioB Wed Oct 30, 2024 6:45 am
getback wrote:WOW It throttles really good better than most the exhaust throttles i have seen very quick! Job well done ! Very Happy
Dear friend Eric, thank you for your message. It really works. I must say that I was anxious while making the parts, since I have no references of real measurements necessary for the proper functioning of the engine.
I based myself on the principle of the throttle ring, taking into account the exit surface of each exhaust port and so I planned this design. Of course, maybe it can go better if other measurements are tested or maybe not, but I am already very well with this throttle, it perfectly meets my expectations.
Post  MauricioB Wed Oct 30, 2024 6:49 am
Levent Suberk wrote:Clever design Very Happy
Thanks Levent!!...many years ago I saw something on the internet about a Pee Wee .020, I don't remember if it was an engine on ebay and had an accessory, something similar to this, but I never found it online again to compare and take some safety reference. So with that fuzzy image in my mind, plus the experience of the exhaust chamber I made for some of my engines, seeing that it can be made perfectly sealed (without leaks) and that by covering the outlets the engine even stops, then I put together the idea and this is what came out.
Thanks again.
Post  MauricioB Wed Oct 30, 2024 6:55 am
rdw777 wrote:Beautiful engineering and craftsmanship Mauricio!!!…. Producing and working with parts this small is very challenging…. It works perfectly…. Not very often achieved with the .010 attempt to throttle…. Do you have an certain airplane in mind for it?
Dear Roberto... while I was making my throttle I took a picture that reminded me of you, I'm serious. You do a lot of handcrafted work and this picture I'm sharing here, making the valve cams out of bronze sheet metal, in the early hours of one of these days, reminded me of you.
I don't have any particular model in mind right now. This is because there are many Cox cylinders with the skirt at the base, which means that a throttle ring cannot be placed, unless it is by a split sleeve and an upper ring, or by turning the cylinder itself, etc. This solves that point for these cylinders with a skirt and can be made for all types of displacements, that's great, from .010 to whatever you can think of, just by enlarging the scale, of course.
A hug dear friend!
Throttle control for Cox .010 "Viking" engine. 20241018
Post  Gordinir8 Wed Oct 30, 2024 7:48 am
just came here from you tube video, Very nice mod indeed, i think i will 3d design and print one to test fit first and then make it on the lathe but for a 049, it is a good way to redirect all this oil messing the models.
Gordinir8
Gordinir8
Silver Member
Silver Member
Post  Gordinir8 Wed Oct 30, 2024 7:50 am
ffkiwi wrote:Nice work Mauricio.....and an interestingly different approach.  somewhere in my archives I have an Aeromodeller Annual article on exhaust restrictors for Cox engines...probably dating to the mid 60s or thereabouts, on home made restrictors to reduce power for trimming. IIRC there were construction dimensions for all sizes of Cox....including the orifice hole size....which might relevant to your efforts...
ChrisM
'ffkiwi'
I would pay millions to see that article Very Happy Do you think you can dig it out?
Thomas
Gordinir8
Gordinir8
Silver Member
Silver Member
Post  ffkiwi Thu Oct 31, 2024 9:12 pm
ChrisM
'ffkiwi'
Thomas
I'll have a fossick around for it this weekend
ChrisM
ffkiwi
ffkiwi
Post  davidll1984 Sat Nov 02, 2024 6:18 am
I like this design this way the valves can be placed in front of the exhaust ports on the cylinder the fact of using two valves instead of one must help not to lose performance I know from experience that an exhaust control is very efficient And I believe that this one must be very good and that is what the video demonstrates with my car I only use one valve but seeing this system inspires me. But for me it is the quest for performance and the development of a noise reduction system that led me in a direction but Mauricio different approach inspires me. The cox cylinder has two windows on the cylinder and all this is really very logical to have two valves or even without using two valves an exhaust manifold with two outlets is preferable and I believe greatly reduces the effect of loss of performance due to exhaust gases recirculated by the spi This is a great invention my friend, thanks for sharing the results. Small Cox Logo Babe Bee .049 cheers Hand Shake
