» Happy Birthday Robert ( Rsv1cox )by GallopingGhostler Today at 8:32 am
» Irvine Mills .75 replica
by Coxfledgling Today at 8:09 am
» COX .020 RC PROJECT
by 1/2A Nut Today at 4:32 am
by Admin Today at 1:33 am
by MauricioB Yesterday at 11:02 pm
» OS MAX-D
by Ken Cook Yesterday at 3:38 pm
by getback Yesterday at 3:22 pm
by getback Yesterday at 7:55 am
» Wanted peewee 20 fuel tank
by GallopingGhostler Yesterday at 2:05 am
» Fox .35 Modifications
by Ken Cook Fri Oct 04, 2024 7:40 pm
by Admin Fri Oct 04, 2024 7:33 pm
by rsv1cox Fri Oct 04, 2024 6:32 pm
Reed me.........Please
One of my Cox chainsaws is missing a reed. It might has well be both as it won't run with just one. I thought someone here with the manual dexterity that I no longer have might be able to make me one out of a floppy disk or some other material? If someone is up to it, I'm sure I have an engine of your liking to trade for services.
Doesn't look to be easy.........Sorry, I can't find either my calipers or my micrometer. Thickness is the same as what you would find in a Babe Bee. Perhaps a shade thicker.
It goes in this little jewel.
Re: Reed me.........Please
Hi Bob, I’ll give a shot…..I think I have some floppy disk material… We’ll have check to see if it will stand up to gasoline…. Good photos and alignments
rdw777- Diamond Member
rdw777 wrote:Hi Bob, I’ll give a shot…..I think I have some floppy disk material… We’ll have check to see if it will stand up to gasoline…. Good photos and alignments
If not.. it seems to me that I've seen parts of electrical switches (or circuit breakers?) that use thin annealed copper contacts that might be large enough to make one..
Old relays and contactors have some interesting material in them Roddie…. Will keep that in mind
There is a ”proper”, or should I say ”bespoke” material available for making reed valves:
https://www.puchshop.de/en-gb/malossi-membrane-sheets-carbonit.html?gad_source=1&gbraid=0AAAAAD02mw3P-4b5nARi-XQDwcZ8hYDFO&gclid=EAIaIQobChMIqfin-o7XiAMVAEGRBR0R0xmiEAQYAyABEgK9o_D_BwE
The link is to a moped tuning shop in Europe, but most likely these are available in the USA too.
(Googled ”reed valve material” )
I suspect floppy disk material is too thin for a reed that size. This wouldn't be annealed copper, but spring temper beryllium copper.
gkamysz- Gold Member
I made a brass one first to use as a pattern ….Then traced it out on to floppy disc material…. The floppy disc is .004” thick so yes, Maybe a little thin but worth a try…. I’ll make a couple more then send them to you…. I’ll hang on to the pattern in case the size needs to be tweaked or we need to find a better material….
You bet!, They’ll be on their way today
» Fastest reedy??
» Which reed is best???
» Reed types! What do you use?
» Questions about reed valves and retainers
» Fastest reedy??
