» My N-1R build logby GallopingGhostler Today at 2:04 pm
by 1/2A Nut Today at 1:43 pm
by roddie Today at 12:13 pm
by sosam117 Today at 10:32 am
by rdw777 Today at 8:24 am
by batjac Yesterday at 8:47 pm
by rsv1cox Wed Nov 20, 2024 2:21 pm
by 1975 control line guy Wed Nov 20, 2024 7:17 am
by rsv1cox Tue Nov 19, 2024 5:35 pm
by Cox International Tue Nov 19, 2024 11:01 am
by getback Tue Nov 19, 2024 5:08 am
by roddie Mon Nov 18, 2024 8:05 pm
brass reed
brass reed
One of my Babe Bee's has a bad brass reed. Can I use the plastic one from a plastic back plate to replace it?
chevyiron420- Gold Member
Re: brass reed
chevyiron420 wrote:One of my Babe Bee's has a bad brass reed. Can I use the plastic one from a plastic back plate to replace it?
Yes.. BUT the plastic (Mylar) reed is slightly thicker (.002" to .003" thicker..) than the Copper-beryllium (star-shaped) reed. The replacement reed should rotate freely (not be "pinched") when you re-install the wire clip-retainer. If it's tight.. you could try to run it.. but if it only runs off an "exhaust-prime" and quits after several attempts at starting, you may need to make some adjustments. Some modelers slightly "sand" the face of the wire clip-retainer (the side that faces the reed..) to achieve enough of a "gap" for the replacement reed to freely rotate with the clip installed.
Re: brass reed
Thanks Roddie. the reed will sit down in there nice and flat, with out bind, but honestly I cant rotate it. My eyes and hand coordination just aint much anymore. I use an oil stone on the clip and put a little flat on the reed side of it. I have four babe's and I am useing info from here to put all the right parts back on the right engines the way they came. When I was a kid I mixed parts without care. A dual port cylinder, high compression babe doesnt run long on a tank of fuel. I have them all right now as best I can tell and two test run great. The third was the reed jumped out, and the fourth my batterys were dead. I hope to test the other two tomorrow. I have had some of these for over fourty years.
Re: brass reed
You're welcome Phil. These engines are a lot of fun.. especially the more you learn about them and tinker. Just run the fuel that's made for them (plenty of castor oil in the total lube-package).. keep them leak-tight and clean.. and they'll return the favor by providing reliable running over their lifetime.
» Brass wrench
» 3D printed PeeWee .020 tank backplate
» Miniature Display Models made of steel / brass
» Davis diesel head improvement
» Brass wrench
