» Funny what you find when you go lookingby rsv1cox Today at 9:18 am
by batjac Today at 1:36 am
by roddie Yesterday at 6:54 pm
by rsv1cox Yesterday at 6:40 pm
by rdw777 Yesterday at 6:03 pm
by amurphy6812 Yesterday at 5:43 pm
by LooseSpinner99 Yesterday at 5:17 pm
by roddie Yesterday at 11:27 am
by GallopingGhostler Fri Nov 15, 2024 7:39 pm
by rdw777 Fri Nov 15, 2024 6:58 pm
by Kim Thu Nov 14, 2024 3:28 pm
by bsadonkill Thu Nov 14, 2024 1:19 pm
Engine starter battery box
aungmyatoo- Gold Member
Re: Engine starter battery box
Those "D" size battery boxes are a great idea, and so cheap. I'm going to get a couple. I won't bother with the AA batteries in the adaptor case, just use D size Alkalines. Two cheap "D" size wired together and taped up have lasted me a real long time.
And hey, when the batteries get too flat in parallel I can swap the boxes around and put them in series to get a final few starts from them.
Oldenginerod wrote:Those "D" size battery boxes are a great idea, and so cheap. I'm going to get a couple. I won't bother with the AA batteries in the adaptor case, just use D size Alkalines. Two cheap "D" size wired together and taped up have lasted me a real long time.
Careful with series batteries, it can burn off the filament in the engine head if over 1.5 volts.
Well aware of that. I was young and stupid once (like most of us) and impatiently tried to start a stubborne engine with a little extra juice.
I would only do it to get the last from my batteries once they were too flat to work in parallel. Just unclip the boxes from the side-by-side position and connect them end-to-end, and your two half flat (.75 V) batteries make 1.5 Volts. Just trying to be a penny-pincher.
Good idea with the rechargeable AA Batts , alot of things i have take those same batts. So i bought a few and a charger / i don't know if the Ds would last longer though?
Rechargeable battery has 1.2 volt compare to normal single use battery of 1.5 volt.
The plus point for rechargeable battery is less internal resistance so it can produce higher current / amperage in short period.
It won't last long compare to D size normal battery, any way we can recharge several time.
I had thought of using a triple case that would use C cells, and stretching the springs to use the sub C cells. I guess it would be best to rearrange the cells to charge them. Can't forget to put them back to parallel before use. I still use the panel, but sometimes it is nice to have a more portable unit for control line stuff.
aspeed- Platinum Member
» D.I.Y Graupner 1.5 V Starter Battery Box
» LiPo Battery for Starter
» Cox Starter Battery Box Printable Templates
» Electric starter with a built on battery?
» Printable Label for Cox G Size Starter Battery
