T-28 sand cast Enya engine under construction Cox_ba12
T-28 sand cast Enya engine under construction Pixel
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
T-28 sand cast Enya engine under construction Empty
T-28 sand cast Enya engine under construction Empty T-28 sand cast Enya engine under construction
Post  rsv1cox Thu May 02, 2019 5:03 pm
T-28 sand cast Enya engine under construction Spike_16
T-28 sand cast Enya engine under construction T-28_e10
T-28 sand cast Enya engine under construction Empty Re: T-28 sand cast Enya engine under construction
Post  NEW222 Thu May 02, 2019 5:52 pm
Wow. Sure looks neat when disassembled like that. I really see the look of what a sandcast engine looks like now. Also to note, I actually really like the raised lettering. It still is too bad about the head though.
Post  Mike1484 Thu May 02, 2019 6:44 pm
Looks like a new engine ! All the parts look like they don't have much time on them .
Mike1484
Mike1484
Mike1484
Post  Dave P. Thu May 02, 2019 8:17 pm
Wow! What was that about a silk purse and a sow's ear?
Dave P.
Dave P.
Post  rsv1cox Fri May 03, 2019 9:05 am
Got it back together this morning only to take it apart again when I figure out helicoil & anodizing.  Keeps parts from getting lost this way.
Only half the head threads were stripped out (shorty plug), I replaced it with a long plug and got compression with no leak around the plug.  No matter, it's getting fixed now that I have come this far.
T-28 sand cast Enya engine under construction Enya_223
My Enya overhaul kit.  Ground down 1/4 and 5/16 sockets, a ground to fit most Enya machine screws screwdriver salvaged from my wife's 1977 VW Scirocco (best part of that rolling hunk of junk) and various wooden dowels for removing/installing the piston.
T-28 sand cast Enya engine under construction Enya_224
1/4" socket is the only way to remove/tighten the captive NVA nut and the ground down 5/16" gets in around those heads with tight to the plug fins without damaging them.  And, thankfully this Enya has no broken or damaged fins.
Also no crust around the rim of the cylinder, good and bad.  Crust helps pop out the cylinder from the case as it captures the piston.  Didn't happen on this Enya as there was no crust leaving the cylinder in the case.  Doesn't matter much but I like getting it out and removing the castor goo allowing better heat transfer to the fins.
T-28 sand cast Enya engine under construction Enya_317
T-28 sand cast Enya engine under construction Enya_316
