by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Merlin Head and Glow Plug Inconsistent Running
I have a merlin head and glow plug. When I run it on various engines it seems to run really good for maybe 30 seconds then kind of fluctuate and then get back into business. Then I change out for a standard or high comp cox glow plug and it runs true without any fluctuation until tank empty. I needed to add four copper head gaskets until it would start ok. I guess that the compression is higher on the Merlin accounting for the multiple copper shims required. I have wondered if any other suggestions are out there that would help as regards why this head might fluctuate while running but the Cox one does not do that?
Thanks
Iceberg
Thanks
Iceberg
Iceberg- Gold Member
Re: Merlin Head and Glow Plug Inconsistent Running
How does it run with five gaskets? Over compression will cause a engine to sometimes run erratic, as is a hard to needle engine.
Is that a flat coil glow bee plug? So this is the insert type with an adapter plug?
Yes it has a coil similar to the cox ones but has a separate insert piece that threads over it. I've only tried 4 head gaskets I'll try 5 gaskets tonight and see.
Thanks
Iceberg
Thanks
Iceberg
Well I put 5 shims and then went to 6 shims. I actually ran pretty good but still had some slight rpm wavering? I took off the two blade 5x3p and put a three blade 5x3.5p. That was what ran pretty good. Prop wash was also good. Dare I try seven shims? Seems loosing a lot of compression?
Thanks
Ice
Thanks
Ice
Could it be that the engine just "wants" more load? The other prop has one more blade and higher pitch. Do you have an even bigger prop to try with?
5x3 sounds kinda small for a hopped up engine, although I am far from an expert on this.
The plugs I have are like the one you show on the right with the purple color. I am going to try a 6x4 tomorrow with the Merlin head. The motor is a real nice venom looking block. Fred sent over. I ran a 6x4 yesterday with standard coz head. Ran great just a touch slower.
Yes 6 or 7 shims didn't sound right to me.
Thanks
Ice
Thanks
Ice
Hey, Ice. It's not unusual to need 5 head gaskets with those drop-in plugs. Especially with a fairly new engine that has good compression already. In fact I usually advise people to start with 5 and work from there. That is a good head and plug combination though. I run them on all of my Cox engines. And on Norvels when they need replacing.
Hey there 1/2A Nut. Question time for you! Where on earth did you ever find the flat coil plugs? Also , who the heck makes those. I have nover seen nor heard of those before your mentioning it along with pictures. That looks kind of funny, but interesting. Thank you.
Without the hole in the plug you get better compression is one reason for the flat coil
another is it spreads the heat further out across the top of the piston for bigger burn
more bang / power. The flat coil element is more robust and can handle higher nitro
lasts longer and handle higher compression. Great for competition engines.
Merlin Glow Bee Plugs. Owner died the family is not currently selling the plugs.
Now the site has been closed down here is the old link:
http://www.merlinglowplugs.com/Aircraft.html
New link modified with the following message:
http://merlinglowplugs.com/
Some sites still have old stock but Merlin also made conventional plugs. The sites
i have found that had stock did not have flat coil types all those have been sold out.
Very interesting. Thanks for the information. Too bad they are no longer available. Funny to me though as one would think someone else would try to produce them. I could see the benefits now though.
Iceberg wrote:Well I put 5 shims and then went to 6 shims. I actually ran pretty good but still had some slight rpm wavering? I took off the two blade 5x3p and put a three blade 5x3.5p. That was what ran pretty good. Prop wash was also good. Dare I try seven shims? Seems loosing a lot of compression?
Thanks
Ice
-Make sure there's no varnish on cylinder?
-needle is not leaking, add a short piece of tubing to needle base. Remove needle and wipe, sometimes crap will cause wavering.
-no air leaking on backplate?
-decent gasket on airtube?
-Is it a new engine, it just might need some time?
-What is the nitro and RPM you're getting? What is the 5x3 you're using? Is it flexing?
-welcome to the fun world of 1/2a's!
» Merlin Glow Head Test Run
» merlin glow plug screw thread size, making testor adaptor
» Glow head/plug possibilities
» Glow Plug Head Adapter
» Cox .15 glow head adapter plug type
