Glow Plug Head Adapter  Cox_ba12
Glow Plug Head Adapter  Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Glow Plug Head Adapter  Empty
Glow Plug Head Adapter  Empty Glow Plug Head Adapter
Post  jorigger Sat Jul 20, 2013 12:44 pm
I have to see in the market that is Adapter for the use in the Cox of the standard Glow Plug, and i want know if work well ?
Thanks and Regards
Giuseppe - Italy
jorigger
jorigger
Glow Plug Head Adapter  Empty Re: Glow Plug Head Adapter
Post  navion34 Sat Jul 20, 2013 1:18 pm
Hi,
You can find the good item :
there,
http://www.exmodelengines.com/cox-.010-.020-.049-.051-.074-.09-.15-glow-plug-clip-oem.html
or there,
http://coxengines.ca/cox-glow-plug-clip-oem-style.html
Regards,
navion34
navion34
Post  jorigger Sat Jul 20, 2013 1:25 pm
navion34 wrote:Hi,
there,
or there,
Regards,
Hello, thank you for the reply, but is probable that is not clear the my question,and sorry for the my english.
This is the glow plug.
I want know if i can use the Standard Glow Plug with one adapter in the Cox Engine.
Thanks and Regards
Giuseppe - Italy
jorigger
jorigger
Post  pkrankow Sat Jul 20, 2013 1:36 pm
Bernie has colors
http://coxengines.ca/top-end/
Matt does not (at least for now)
http://www.exmodelengines.com/top-end/
The clamp on type uses a special insert, the threaded type uses the same type of glow plugs as larger engines use. I have used the threaded type and found it acceptable, but I prefer stock glow heads.
If you have the equipment (lathe) you can drill and tap a glow head for 1/4-32 and make your own adapter.
Post  jorigger Sat Jul 20, 2013 2:01 pm
pkrankow wrote:Bernie has colors
Hi Phil,
thank you very much for this you informations.
Yes i have lathe and also the tool for threded in this size of 1/4-32.
Please,that is the best 'Glow Plug' for the use in the Cox.
Regards
Giuseppe - Italy
jorigger
jorigger
Post  navion34 Sat Jul 20, 2013 2:49 pm
jorigger wrote:
navion34 wrote:Hi,
there,
or there,
Regards,
Thanks and Regards
Giuseppe - Italy
All my apologies Guiseppe, I read too fast your post and I done a bad answer...
navion34
navion34
Post  jorigger Sat Jul 20, 2013 3:19 pm
navion34 wrote:
jorigger wrote:
navion34 wrote:Hi,
there,
or there,
Regards,
Thanks and Regards
Giuseppe - Italy
Not problem Navion34.
Regards
Giuseppe - Italy
jorigger
jorigger
Post  fredvon4 Sat Jul 20, 2013 3:21 pm
Unfortunately Larry Driskill will only ship to overseas from USA for large orders and by personal arrangement
His site"Kitting it together" has fewer and fewer items each year
http://kittingittogether.com/glow-plugs/
I personally believe the Adapter and Nelson plugs are the best (you asked)
Of course the original standard compression glow plugs are not too expensive or hard to get. The higher compression TD plugs are a bit more money
A company named Merlin makes plugs that are also very good for the Cox engines
http://www.merlinglowplugs.com/main_page.html
Matt and Bernie both can provide standard Cox plugs or adapters for Merlin, and the typical screw in glow plug adapters and plugs
All out performance the Nelson adapter and plug
Good reliability and very good economy is the Merlin set up
Proper looking and good reliability are the standard Cox heads
Lower power and cheapest in the long run are the adapters for normal glow plugs
Post  jorigger Sat Jul 20, 2013 3:28 pm
fredvon4 wrote:Unfortunately Larry Driskill will only ship to overseas from USA for large orders and by personal arrangement
Hi Fred,
thank you very much for all this informations, i have to see the Merlin Website with great interesting.
I don't know this: merlinglowplug.com, is the first time that i know.
Regards
Giuseppe - Italy
jorigger
jorigger
Post  RknRusty Sat Jul 20, 2013 3:50 pm
This is my favorite. I use them on most of my Cox engines.  It's made by Merlin. It is very high compression and needs at least 3 head gaskets:
Glow Plug Head Adapter  1417
Post  jorigger Sat Jul 20, 2013 3:58 pm
RknRusty wrote:This is my favorite. I use them on most of my Cox engines.  It's made by Merlin. It is very high compression and needs at least 3 head gaskets:
Always you let me know very good informations. Thank you very much, you is very kind.
Regards
Giuseppe - Italy
jorigger
jorigger
Post  tonsberg Fri Jul 26, 2013 12:00 am
Hello Guiseppe,
Please don't even think of using a standard glowplug in a drilled out Cox head. You will lose a large amount of performance and let us face it, most Cox engines are not blessed with high performance, they have all been overtaken by the march of time and development!
I use the Galbreath head adapter with the heavy duty Nelson turbo plugs. This way you get a very big performance increase! The Nelson plugs last forever. I have yet to blow one!
The Merlin head and plugs are also good, but not quite so much performance increase (it is all due to higher compression). They don't last as well as the Nelson plugs, but infinitely better than Cox glowheads.
Last time I purchased any Galbreath head adapter from Larry Driscoll there was no problem shipping overseas, maybe he has got fed up of filling in the customs declarations!
Regards,
Andrew.
tonsberg
tonsberg
Moderate Poster
Moderate Poster
Post  jorigger Fri Jul 26, 2013 12:39 am
tonsberg wrote:Hello Guiseppe,
Regards,
Andrew.
Hello Andrew,
I thank you very much for all this information and explanations, I'm not very experienced with these engines Cox, recently i returned his passion for these engines and through the Forum, and especially thanks to people like you, I'm of enriching my conoscenza.Gentilmente could you send me the address of Nelson? He has a website? I would also like you to know that nationality are you?
Thanks again for this answer and best regards.
Giuseppe - Italy
jorigger
jorigger
Post  stevej Fri Jul 26, 2013 1:11 am
Order from Doug Galbreath.
http://www.the-printer.net/DookCat.html
stevej
stevej
Post  jorigger Fri Jul 26, 2013 1:32 am
stevej wrote:Order from Doug Galbreath.
Thanks and Regards
Giuseppe - Italy
jorigger
jorigger
Post  tonsberg Fri Jul 26, 2013 2:57 am
Hello Steve
Thanks for updating my take on Larry Driscoll's web site. Guiseppe, the Nelson plugs are available from M B Schuettes as well (Spelling?) He has a web site that is called MBS Model supplies. He certainly does the nelson heavy duty plugs and may well do the Galbreath adapter heads. from memory the plugs are a little over $4 and the adapter heads were a little over $12.
Re reading my reply. I was a little harsh on the Merlin plugs and heads. I use both and I have had a couple of plugs blow (after much use!). I believe that Merlin still has a deal available which is 3 plugs and an adapter head for around $13.All prices plus postage.
Both conversions gain power by reducing the head volume compared with a standard Cox head (and for that matter even a TD head!). You may well have to decompress the engine by adding anything up to 3 head gaskets. So order a bunch from Bernie.
I just ge.t a feel for the right amount of head gaskets, difficult to explain, maybe someone can explain the technique better than I can?
Merlin have their own web site (Look up Merlin glowplugs, that should get to it
Regards,
Andrew.
tonsberg
tonsberg
Moderate Poster
Moderate Poster
Post  jorigger Fri Jul 26, 2013 7:38 am
tonsberg wrote:Hello Steve
Regards,
Andrew.
Hello Andrew,
thank you very much for this reply you with all informations and explanations.
You is very kind, and for me is very very important.
My Best Regards
Giuseppe - Italy
jorigger
jorigger
