Starting a G-Mark .03 - Page 3 Cox_ba12
Starting a G-Mark .03 - Page 3 Pixel
by Kim Yesterday at 3:28 pm
» Pathé Modeling Videos
Starting a G-Mark .03 - Page 3 Empty
Page 3 of 4 Previous  1, 2, 3, 4  Next
Starting a G-Mark .03 - Page 3 Empty Re: Starting a G-Mark .03
Post  MauricioB Tue Oct 16, 2018 4:47 pm
thus the finished support work is now observed.
The carburetor is firm without displacements ... as it should beStarting a G-Mark .03 - Page 3 20181038
Starting a G-Mark .03 - Page 3 20181039
Post  MauricioB Tue Oct 16, 2018 4:51 pm
then you can experience new engine gears, everything is going very well !!
Starting a G-Mark .03 - Page 3 20181040
Now I am working on the optimal height of the tank to find your ideal carburetion!
To be continue... Very Happy Thumbs Up
Post  Marleysky Tue Oct 16, 2018 6:18 pm
That looks Great! Hope it runs as good as it looks!!
Post  MauricioB Tue Oct 16, 2018 10:44 pm
Marleysky wrote:That looks Great!  Hope it runs as good as it looks!!
Thanks Friend ... I think everything is working fine !!!
I'm working on a model .... SHHH Shh  Shh  Shh  ... do not tell anyone! lol! Beer Cheers
Starting a G-Mark .03 - Page 3 Img-2016
Post  MauricioB Tue Oct 16, 2018 10:58 pm
oh it seems that the tin plug that had been placed in the exhaust chamber has been removed. I'm going to have to put in some very small screw!
(indicated in the photo with yellow arrow)
Starting a G-Mark .03 - Page 3 20181054
Post  MauricioB Fri Oct 26, 2018 9:34 am
Well, I have finished another Pocket Rocket and I have placed the G-Mark .03.
I'll be waiting to have time to go fly and test how the model behaves.
Here are a few photos ... I will give you some more!
Starting a G-Mark .03 - Page 3 20181055
Starting a G-Mark .03 - Page 3 20181056
Post  MauricioB Fri Oct 26, 2018 9:36 am
Pocket Rocket and Cox .020 r/c & Pocket Rocket and G-Mark .03 r/c
Starting a G-Mark .03 - Page 3 20180610
Starting a G-Mark .03 - Page 3 20181057
Post  1/2A Nut Fri Oct 26, 2018 10:25 am
Very nice Thumbs Up
I look forward to your video and opinion on the engine power compared to the TD .020 during flying.
Airplane
Post  balogh Fri Oct 26, 2018 2:55 pm
Beautiful planes Mauricio congratulations!
Post  GallopingGhostler Fri Oct 26, 2018 3:40 pm
Excellent workmanship, Mauricio. I'll be interested in hearing how the G-Mark .030 RC compares with the Cox .020 Tee Dee in flight.
Post  MauricioB Fri Oct 26, 2018 4:41 pm
thank you very much friends of mine! ....
Here I leave some photos so that you can appreciate the two models, each with its engines.
I hope to be able to fly soon ... I will share my experiences with you... RC Plane Wink
Starting a G-Mark .03 - Page 3 20181061
Starting a G-Mark .03 - Page 3 20181062
Starting a G-Mark .03 - Page 3 20181063
Post  MauricioB Fri Oct 26, 2018 4:43 pm
more... Smile
Starting a G-Mark .03 - Page 3 20181065
Starting a G-Mark .03 - Page 3 20181064
Post  Levent Suberk Fri Oct 26, 2018 5:18 pm
Very good craftmanship. Congratulations. Thumbs Up
Post  MauricioB Sun Oct 28, 2018 1:30 am
Levent Suberk wrote:Very good craftmanship. Congratulations. Thumbs Up
Thanks friend! Thumbs Up
Post  MauricioB Sun Oct 28, 2018 1:37 am
Well, well, well ... how to explain ... I'll try to do it ...
Install the G-Mark .03 in my Pocket Rocket model, the engine runs at full throttle, but can not regulate ... so I started to see what the problem was.
Finally I discover that the height of the engine is very much above the height of the fuel tank and there is no way to accommodate the engine lower because of its size, it is also not possible to place the fuel tank higher. Believe me I made all the attempts, but finally I will discard this engine for this model size, it is necessary that the model is a little larger, to be able to place it correctly and aligned with the fuel tank.
While I think that a Tee Dee .020 Cox will be the replacement.
The G-Mark .03, will have to wait for you to build an appropriate model for it.
That is the ideal position of heights, engine and fuel tank, impossible to achieve in the Pocket Rocket!
Starting a G-Mark .03 - Page 3 20181066
Post  GallopingGhostler Sun Oct 28, 2018 1:41 am
You would have to modify or eliminate one of the cheek cowls, but you could mount the engine horizontal. Then the fuel tank would be in line with the carburetor.
Post  MauricioB Sun Oct 28, 2018 1:46 am
GallopingGhostler wrote:You would have to modify or eliminate one of the cheek cowls, but you could mount the engine horizontal. Then the fuel tank would be in line with the carburetor.
Yes friend I thought, even if I put the inverted model the engine works very well, regulates accelerates and all of wonders, that's because when inverting the model, the engine is below the height of the tank.
I thought then of placing the engine at 90 degrees, at 45 degrees and even put it inverted, but I'm sorry to have to sacrifice the nose or nose of the model ... I prefer to start a new project for the engine, now that I learned some details of the operation , I think it's worth doing something new for him ...but ... the G-Mark .03 will have to wait!
Post  1/2A Nut Sun Oct 28, 2018 3:20 am
You have the feed line to the carb going up and over the firewall this causes fuel draw issues.
You could reroute the feed line. Note the clunk distance to the carb vs if the tank was a
smaller diameter and a bit longer to elevate the clunk closer to the nipple on the carb.
The clunk sweet spot is always a bit below the carb nipple so fuel will not flood the carb when
the engine is not running. If the tank diameter is over the height of the carb the fuel mass
can push out and flood the carb. The trick is to find the right diameter or square tank that
works well with the engine  size and location on the firewall.
Starting a G-Mark .03 - Page 3 20181012
Starting a G-Mark .03 - Page 3 20181011
Post  MauricioB Sun Oct 28, 2018 8:22 am
Thanks friend Brad, you're right. Here I leave the real photo of the location of the tank and engine in my model (outside) so that the difference in level between one and the other is appreciated.
Here is all wrong!
I will have to see if it is possible to place an adequate tank - tank and that the height is correctly.
Starting a G-Mark .03 - Page 3 20181068
Starting a G-Mark .03 - Page 3 20181067
Post  getback Sun Oct 28, 2018 9:12 am
I would try and reroute the fuel line before moving forward with a new build and (the planes look Great ! ) Just asking because i don't know ((( would it bee beneficially to put a spring in the fuel hose like a reedie to help with the fuel flow ?? Or will it slow it down as not to get the fuel needed? Huh...
Post  GallopingGhostler Sun Oct 28, 2018 10:02 am
MauricioB, Brad and Eric have valid points. I'd probably trim the bulkhead so that the tank could be moved back may be a half inch, then strengthen the bulkhead by overlaying it with 1/32"- 1/16" thick plywood glued to it. straighten the fuel feed line so it penetrates the engine bulkhead.
Post  MauricioB Sun Oct 28, 2018 11:16 am
Thanks guys ... I am already starting to work on a new "extra flat" deposit to achieve a better flow.
I will be sharing the results!
Starting a G-Mark .03 - Page 3 20181069
Starting a G-Mark .03 - Page 3 20181070
Starting a G-Mark .03 - Page 3 20181071
Post  MauricioB Sun Oct 28, 2018 11:19 am
more... Very Happy
Starting a G-Mark .03 - Page 3 20181072
Starting a G-Mark .03 - Page 3 20181074
Starting a G-Mark .03 - Page 3 20181073
To be continued...
Post  fit90 Sun Oct 28, 2018 1:17 pm
MauricioB wrote:more... Very Happy
To be continued...
Very nice! And you got to play with the lathe, too, sweet.
fit90
fit90
Post  GallopingGhostler Sun Oct 28, 2018 3:25 pm
Nice lathe work, Mauricio, good way to a new tank stopper. When I mentioned a possibility of also mounting engine sideways, here's one way someone solved it some time back, made a hole or clearance for the cylinder:
Starting a G-Mark .03 - Page 3 408210
