Reed Valve Design Ideas Poll - Page 2 Cox_ba12
Reed Valve Design Ideas Poll - Page 2 Pixel
by getback Today at 12:05 pm
Reed Valve Design Ideas Poll - Page 2 Empty
Page 2 of 2 Previous  1, 2
Reed Valve Design Ideas Poll - Page 2 Empty RE: Reed valve design polls
Post  66 Malibu Fri Mar 23, 2018 6:32 pm
Regarding designs of the actual reed valve itself, Cox flirted with a Beryllium Copper rectangle reed.
I have one from a bag of about 50 that was in R&D.
The guy was more than really difficult dealing with so I got the one only.
I hate to use it because of it's oddity, although it would been fun to compare with the stainless steel version in use.
I read later that there maybe possible environmental issues working with Beryllium alloys, and I concluded that may why Cox didn't use them, Maybe cost too?
I scored a bunch of Cox stuff from a Texas seller on eBay so, I got a number of the mylar star shaped reeds that will do me a while.
66 Malibu
66 Malibu
Reed Valve Design Ideas Poll - Page 2 Empty Re: Reed Valve Design Ideas Poll
Post  roddie Mon Mar 26, 2018 12:50 pm
I did some more messing around today with redneck reed design.. Laughing This time I tried making a star-shaped reed by first; marking a 7/16" dia. circle on my material.. then cutting it out "square"... Shocked
Reed Valve Design Ideas Poll - Page 2 Dsc05513
Then I nibbled-out the four radius-cuts using a paper hole-punch..
Reed Valve Design Ideas Poll - Page 2 Dsc05514
This leaves just the "legs" to trim.. which is easier than trying to cut-out the entire circle cleanly with scissors..
Reed Valve Design Ideas Poll - Page 2 Dsc05515
It needs to be test-run.. but the "blow/suck" method reveals that it seals.
Then there's what I'll call my "hybrid".. What?
Reed Valve Design Ideas Poll - Page 2 Hybrid10
I'll be working on a method to more accurately index the cuts.. because symmetry is likely a key to whether the reed will function correctly.
Post  Admin Mon Mar 26, 2018 1:07 pm
Nice work Roddie!
I've played around with various reed designs over the years. I like the Mylar star reeds the best.
One reed design I think could be a winner is this:
Reed Valve Design Ideas Poll - Page 2 Specia10
These were designed off a reed I hand cut out of a floppy disk one day. Jason made the first machine-cut ones off the design. I need to get a new cutting mat for my die-cut machine, then I can get back to cutting them out. I know a few of you guys on here are probably waiting for them. They need to be ran through a lot of tests to see if they really improve anything first. I know I sent some to a few members on here...have never heard anything back about performance though.
Post  balogh Mon Mar 26, 2018 1:27 pm
Roddie I like the star shape but to me the "hybrid" leaves too small transfer area i.e. only 2 small bites through which the mixture is drawn into the crankcase...of course your bench test will tell us if I am wrong
Reed Valve Design Ideas Poll - Page 2 Empty RE: Reed valve design ideas
Post  66 Malibu Mon Mar 26, 2018 4:40 pm
Roddie,
Great creativity and engineering to make a complicated shape easy for even me to do !!!!
Thanks, Steve
66 Malibu
66 Malibu
Post  SkyStreak Mon Mar 26, 2018 6:23 pm
My gaskets finally came from Cox Int. today. Now I can resume testing.
I've been thinking of getting some of those Cox Forum reeds to try.
SkyStreak
SkyStreak
Bronze Member
Bronze Member
Post  roddie Tue Mar 27, 2018 10:33 am
by balogh on Mon Mar 26, 2018 2:27 pm
You're probably correct Andras.. but we'll see. I'm hoping to possibly improve fuel-economy without sacrificing performance. Who knows how much (if any) unburnt fuel passes through the exhaust ports. It certainly happens with a rich needle-setting.
by 66 Malibu on Mon Mar 26, 2018 5:40 pm
Roddie,
Thanks, Steve
I actually enjoy messing around with these kinds of things Steve. I'll probably end up in the funny-farm from it one day though..  Sad Goodbye
A circle-template is a must-have tool. I use it for lots of things. It definitely came in handy for this application. I used the 7/16" and 7/32" to mark the reed's outer-diameter and seat-area respectively. This helps to provide a ball-park reference when punching the radii for the star-shape.
The oblong/oval-shape reed is easy to make.. once you get the hang of it. The "straight-sides" are approximately .270" apart. If you cut a strip of material to that width.. and a couple of inches long; you've then established the cross-section for cutting as many reeds as will fit on the strip.. side-by-side. I use a small steel-rule and razor-knife. The 7/16" circle-template is used to mark the radii by placing it over the strip and sighting-it on-center. Mark the radii with a fine-point pen. Using a "nibbling-action" with good sharp scissors; cut the radii "on".. or just inside the ink-mark.
You'll know where to cut after making a couple. If the overall radius is too "large".. the reed will warp in the housing.. and won't seat properly. Too "small".. will allow side-movement of the reed which would probably cause "floating" and loss of power. In extreme cases.. a reed that is much too small could slip past the retainer.. and get sucked into the crankcase.
I made a couple more reeds this morning.. marking the seat-area..
Reed Valve Design Ideas Poll - Page 2 Dsc05516
Reed Valve Design Ideas Poll - Page 2 Dsc05517
Note a new experimental cross-flow reed-type having x4 radii of .125" accomplished using my 1/8" hole-punch.
Reed Valve Design Ideas Poll - Page 2 Dsc05518
Reed Valve Design Ideas Poll - Page 2 Dsc05519
Again; this material is a semi-rigid type of plastic-sheet which is "gloss-smooth" on one side and has a "matte-finish" on the other side. The thickness is .008". The smooth/reflective side faces the valve-seat.. and the matte-side I use to make my ink-marks.
Reed Valve Design Ideas Poll - Page 2 Dsc05520
