testors mccoy repair project Cox_ba12
testors mccoy repair project Pixel
by GallopingGhostler Today at 8:51 pm
by LooseSpinner99 Today at 4:38 pm
by Kim Today at 3:28 pm
by rdw777 Today at 11:24 am
» Pathé Modeling Videos
testors mccoy repair project Empty
testors mccoy repair project Empty testors mccoy repair project
Post  chevyiron420 Fri Oct 13, 2017 11:33 pm
After reading the other threads here I got motivated to fix two engines I have with broken cranks. Both engines cranks were heat colored where they broke, but the shaft wasnt tight. To me it looked like a lack of lube. I noticed there is no lube groove in the thrust face in the case. It looks to me that when the shaft is pulled forward under thrust no oil could get in there.
testors mccoy repair project Img_0210
chevyiron420
chevyiron420
testors mccoy repair project Empty Re: testors mccoy repair project
Post  roddie Sat Oct 14, 2017 12:03 pm
Hey Phil, Maybe a small (as in very small..) V-notch/relief at the top of the face would be enough to get some oil in there? A triangular jewelers-file or very-fine small square-file would do it. Lap it in with some rouge using the replacement crank and flush everything out completely with solvent afterward.
Post  fredvon4 Sat Oct 14, 2017 2:32 pm
I have absolutely zero experience with ANY Testors 1/2a engine
But I do remember well that as youngsters we had no earthy idea about fuel or oil content
I have oft wondered how many we burned up just cus the hobby shoppe had the high nitro stuff and we did not know better
perhaps the Testors could benefit from a oil ingress slot of some sort...but I really bet just running the correct fuel oil combo works as designed
Post  chevyiron420 Sat Nov 18, 2017 10:04 pm
Just a small update on the testors engine rebuild. I have been working on it, and have it assembled. I have replaced the crank, prop drive, back plate, cylinder\piston combo. I have been quiet about it cause its giving me trouble getting the performance and consistency out of it. I will post more as I figure it out.
testors mccoy repair project Img_0219
testors mccoy repair project Img_0218
chevyiron420
chevyiron420
Post  Ken Cook Sun Nov 19, 2017 3:15 am
Phil, the discoloration as you mention is more than likely not a result of overheating but a result of hardening. I've seen this on many of these cranks and seeing that a mild steel is used, this is a result of case hardening. The color is used as a indicator during heat treating. You can't fully harden mild steel but you can make it very brittle which is typically what is noted with these engines. Any small engine is going to result in poor performance if there's a bind. In my opinion, if the shaft wasn't getting oil or lack of, it's going to seize. If your experiencing problems as a result of it being tight, is it a result of you replacing the crank with another? If so, polish up the crank a bit. If you have access to a drill press, you can chuck up the prop end and polish using fine paper, starting with 400 and some oil. Spend a bit more time at the intersection where the crank web meets the shaft and avoid putting a radius at the crank window. Once cleaned up check the smoothness and fit in the case. If needed, a little aluminum polish with the crank in the case might be needed. I like to touch the inner face of the shaft hole on the inside of the case with a countersink to reduce a bit of drag when the crank is seated. I use a Weldon countersink rather than a fluted countersink, due to it leaving a nice chatter free surface.
Do you have additional engines to compare rpm numbers with? I would certainly lap the glow plug flat which will not only flatten the seat, it will raise compression slightly. Do this with a piece of sandpaper on glass and use a rotating motion keeping the plug flat. I would also do this to the front of the crankcase to prevent any drag there as well. The head gaskets of these engine were typically aluminum as well and they don't generally fair well if repeatedly tightened. Piston fit is equally as important. I fabricate a high tech tool to lap the piston. This is a piece of tubing with masking tape wrapped around the top of it. I press the piston onto the tape making sure it fits snug over the tape. You can insert the piston upside down into the cylinder and using metal polish, twirl the tubing while moving the piston up and down. Don't bring the skirt up high in the cylinder bore . Keep the bottom of the piston skirt no higher than the exhaust port and spend a bit of time here relieving the lower portion of the cylinder. At this point, I like to run a Davis Diesel bore brush up and down in the cylinder. This will improve rpm's by reducing drag down low. Clean the parts in hot soapy water , dry and reassemble.
Post  Oldenginerod Sun Nov 19, 2017 4:35 am
Just make sure you have the correct head/gasket set-up. As Ken mentioned, they use a thick aluminium gasket on some heads, but there are some heads which use no gasket at all. A ridge on the alloy head seats directly in the cylinder. If you have used a gasket with a head designed to run without a gasket then you will be way down on compression.
Post  getback Sun Nov 19, 2017 7:24 am
Hey Phil , is that new back plate replacement BENT or distorted ? from the look of the Pic. , it may bee dragging on the CS con rod . Or i am not seeing it right ? Turkey
Post  chevyiron420 Sun Nov 19, 2017 5:16 pm
Im gonna post a video of it running in another thread.
chevyiron420
chevyiron420
Post  chevyiron420 Sun Nov 19, 2017 5:55 pm
Ken Cook wrote:           Phil, the discoloration as you mention is more than likely not a result of overheating but a result of hardening. I've seen this on many of these  cranks and seeing that a mild steel is used, this is a result of case hardening. The color is used as a indicator during heat treating. You can't fully harden mild steel but you can make it very brittle which is typically what is noted with these engines. Any small engine is going to result in poor performance if there's a bind. In my opinion, if the shaft wasn't getting oil or lack of, it's going to seize. If your experiencing problems as a result of it being tight, is it  a result of you replacing the crank with another? If so, polish up the crank a bit. If you have access to a drill press, you can chuck up the prop end and polish using fine paper, starting with 400 and some oil. Spend a bit more time at the intersection where the crank web meets the shaft and avoid putting a radius at the crank window. Once cleaned up check the smoothness and fit in the case. If needed, a little aluminum polish with the crank in the case might be needed. I like to touch the inner face of the shaft hole on the inside of the case with a countersink to reduce a bit of drag when the crank is seated. I use a Weldon countersink rather than a fluted countersink, due to it leaving a nice chatter free surface.
Thanks for the input Ken. I have been over this thing three times now. I had some shaft end play issues at first due to a defective prop drive hub\clutch, but it has plenty of shaft clearance. The piston fit may have been a little snug at first. I think most of the problem now is the worlds worst NVA. It does run a bit better on 20% nitro, but does not equal the performance of my other engines. I mounted up one of my other engines yesterday with the same fuel and prop. It needled easily and quickly right to 15250 rpm and stayed there for the whole run. That engine has always been like that though. I like to see about 14500 rpm and as steady as I can get, with my 10% fuel and 6x3 cox prop.
chevyiron420
chevyiron420
Post  chevyiron420 Sun Nov 19, 2017 6:02 pm
getback wrote:Hey Phil , is that new back plate replacement BENT or distorted ? from the look of the Pic. , it may bee dragging on the CS con rod . Or i am not seeing it right ? Turkey
Eric, its just the bad side lighting in here making it look warped. its good.
chevyiron420
chevyiron420
Post  chevyiron420 Sun Nov 19, 2017 6:06 pm
Oldenginerod wrote:Just make sure you have the correct head/gasket set-up.  As Ken mentioned, they use a thick aluminium gasket on some heads, but there are some heads which use no gasket at all.  A ridge on the alloy head seats directly in the cylinder.  If you have used a gasket with a head designed to run without a gasket then you will be way down on compression.
Rod, you are right about the different glow head set ups. Most of my glow heads are from pipe bomb engines I bought from testors, and use the thick gasket. They are also faster than the older style.
chevyiron420
chevyiron420
Post  Oldenginerod Mon Nov 20, 2017 3:16 am
Phil. You're definitely going to need more nitro than 10%. My new Testors P-40 I got as a kid ran a couple of times on the small amount of fuel supplied but never started again for years until I discovered Cox 25% nitro fuel. I'd been trying 5% which I was using in larger engines with absolutely no luck. Not even a pop. I'd be trying a hotter brew. I'll make comment on the engine run video in that thread.
testors mccoy repair project Empty Wen-Mac/Testors radial mount
Post  roddie Fri Nov 24, 2017 8:04 pm
Just thought I'd throw this out there. My Wen-Mac Mark XI engine's case had one radial-mount which was not drilled-through. The correct size drill is a #40 (.098") drill to "chase" the hole.
before drilling..
testors mccoy repair project Undril10
after drilling..
testors mccoy repair project Undril11
I intend to run this engine.. and also the Testors/McCoy variant that I rebuilt recently. For simplicity-sake; I plan to mount them radially to a block of hardwood.
Post  roddie Fri Nov 24, 2017 9:09 pm
okay.. I said that I planned to mount the engine(s)... so I made-up a mount tonight.
This is my Wen-Mac/Testors (rotary-valve) .049 bench-mount.. or should I say "deck-post" mount.. Smile I haven't worked-out the fuel-tank mounting yet.. but I'll come up with something..
testors mccoy repair project Radial10
testors mccoy repair project Radial11
It's good and sturdy.. screwed into a block of Poplar. The "Testors/McCoy engine is mounted.. but I'll probably run the Wen-Mac Mark XI first. I want to find a better fitting piston-rod for the Testors engine. I have a Testors "Pipe-Bomb" (reed-valve) engine soaking in penetrant.. in an effort to free it up, so I can check the "play" in its conrod. Then it's a question of the best piston/cylinder fit. Huh... Huh... Huh... These engines are new to me. Aluminum head-gaskets.. Huh... different cylinders.. Huh... I'm not sure.. but I don't think that "any" of the cylinders had any sort of special-porting like the Cox cylinders.. "let alone" sub-port induction.. Shocked Has anyone heard of any "hop-ups" for these engines? Removing material from the bottom of the piston-skirts.. etc.?
Post  Oldenginerod Fri Nov 24, 2017 11:58 pm
It was common for the WenMac/Testors engines to have undrilled radial mounts. These engines were generally used in RTF models and rarely were mounted radially in earlier versions. Many WenMacs had one (left hand I think) mounting hold drilled oversize to pass the fuel line through, using it as a support bracket.
Piston to rod fit was extremely variable in these engines. Some had heaps, some had little. They can't be swaged to tighten the joint like a Cox. That's why I went through my assortment for Phil, finding him the tightest joint I had.
The porting in these cylinders is quite substantial, although are only a single cut either side, having no "additional" boost flutes like some Cox. In comparison to an equivalent Cox cylinder (No. 1) the bypass ports were much deeper. I've never looked into the possibility of SPI on one of these, but I think trying to hop one up would be a waste of time as you would probably break a crank/rod. They are generally pretty reliable in standard form but have very little margin-of-error.
