Need a needle valve Cox_ba12
Need a needle valve Pixel
by rsv1cox Today at 7:05 am
Need a needle valve Empty
Need a needle valve
Help! Need a needle valve
Post  fit90 Mon Mar 21, 2016 2:20 pm
Need a needle valve Dc10
HELP!  I need an NVA for this.  It is a DC 0.5 cc.  I do not need an original NVA, just something to make it run.  Any and all help is greatly appreciated.
Thank you,
fit90
fit90
Help! Re: Need a needle valve
Post  EXModelEngines Mon Mar 21, 2016 4:22 pm
Any idea what the thread is Bob?
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  ian1954 Mon Mar 21, 2016 6:37 pm
Peter advertises these regularly.They are fully adjustable to centre the hole in the spraybar.
http://www.ebay.co.uk/itm/model-aircraft-engines-universal-NVA-/291712528258?hash=item43eb6bef82:g:pVMAAOSwstxVFt4a
Need a needle valve _57_210
ian1954
ian1954
Post  fit90 Tue Mar 22, 2016 7:04 am
Matt,
I have no idea. It is a tiny little thing. I might try the needle from something else to see if I even have something small enough to get an idea of size/thread.
Thanks
Ian,
I saw that from another post. I noticed that he specializes in these types of engines. I will contact him and see if he ships to the U.S.
Thanks,
fit90
fit90
Post  fit90 Thu Mar 24, 2016 7:28 pm
I think that I have solved this problem twice. I have found that the needle from an MP Jet .061venturi is the same size and thread as this engine. Only, the needle is too long. Any way, I had an entire NVA in an MP Jet .061 venturi that I stuck in the Dart and it worked beautifully! I also won an NVA from the seller Ian recommended. Thank you, Ian. That tip was greatly appreciated. When I got the engine it was frozen up and missing the needle of the NVA. Now it is a running engine. This was my first true diesel that I got running. After I got the compression in the proper range it was surprisingly simple and easy. With a Top Flite 7x4 wood prop it was running between 8900 and 9000 RPM very steadily. I don't even want to guess how long it would run on an ounce of fuel. Regardless of how long it ran, it was rock solid. I am looking forward to seeing this little gem pulling a plane around some day. The plane will have to be pretty small and light, though.
fit90
fit90
