» My current avatar photoby GallopingGhostler Today at 7:02 pm
by LooseSpinner99 Today at 4:38 pm
by Kim Today at 3:28 pm
by rsv1cox Today at 2:23 pm
by bsadonkill Today at 1:19 pm
by Levent Suberk Today at 11:39 am
by rdw777 Today at 11:24 am
» Pathé Modeling Videos
Educate me on these little Enyas please
I got these two among a bunch of engines I bought recently. Not very much info on these online or I just don't know where to look...
Anyway, one is a .08, the other is a .10. I compared and measured a little and it seems the crankcases are pretty much identical except for the numbers on the bottom. The .10 cylinder has a little bigger fins and head. The .10 is a "T.V." variant but the carb sits weirdly close to the cylinder. The .08 is a C/L or F/F, the square venturi stack is kinda neat These don't have provisions to install mufflers, so I am guessing they are from the '60s.
My NIB Enya 45BB 6001 came with a leaflet that pictured similar engines but that's about all the info i have found so far.
Here they are, in my opinion pretty neat engines. I have the needles for both, they are just not installed right now. I'd appreciate any info on how to use them, what NOT to do if disassembling them, what are those blocked little holes in the bottom sides of the crankcases etc. Right now they are stuck solid so at least some soaking and cleaning-up is in order.
Re: Educate me on these little Enyas please
Well, to start with the markings are in cc, i.e. you have a .8cc (.049 cubic inch) and a 1.0 cc (.061 cubic inch) engine. They have recently been discussed on this forum, not sure what else you want to know?
They are a little heavy and not so strong, but neat or cute indeed.
There are/were also mufflers for these engines;
Some Enyas used a tank pressure tapping in the bottom of the crankcase. Yours look to have points that can be drilled and tapped for that purpose.
rsv1cox chimes in he can point you in the right direction but if you don't want them just boxem up for me at least they are rotary valve and not reeds you cant get (find) getback
http://www.svensktmodellflyg.se/users/5466/ENYA_Model_Engine_Compendium.pdf
Hi Kari - The above link will tell you about everything you want to know about Enya engines. It's quite long and involved but if you scan though it you will find information relative to your engines. I consider the author an internet friend and I have benefited greatly from his advice. I also own several of his former engines. Congratulations on that .10, one of the few that I do not have.
They are quite easy to disassemble, but unless they are very dirty I would recommend against it. A little heat will loosen them up, I follow with Remoil and a lot of flips. Parts still are available. See Bob Brooks "[bleep]" on ebay. Your guess is as good as mine.
Surfer_kris wrote:Well, to start with the markings are in cc, i.e. you have a .8cc (.049 cubic inch) and a 1.0 cc (.061 cubic inch) engine. They have recently been discussed on this forum, not sure what else you want to know?
Well, I guess I'll need to take the backplates off and try to measure the stroke to make sure what size they actually are. They are about the same size externally as my Queen Bee, and close to OS MAX10, that led me to think cubic inches.
rsv1cox wrote:http://www.svensktmodellflyg.se/users/5466/ENYA_Model_Engine_Compendium.pdf
Thanks Bob, a lot of info in that link indeed. By a quick look I narrowed the manufacturing year down to 1965...70 for the 08 and 1965...71 for the 10. Exact dates are not important but it's nice to get a ballpark figure. What the document didn't tell was how rare or "collectible" these are. The fact that I'd never seen one of these before means nothing as these are a bit "before my time" and there was no club nor older hobbyists around where I lived as a kid.
Yes, maybe it would be smart not to take these apart. I think I'll just remove the backplates, plugs and venturis, apply some heat and try to get them loose, then soak them in gun oil.
Thanks for the tips!
Collectable? I think so, cause I like them and the early ones do go back to the 1930's. My earliest are around 1950. The .049's, .06 thru .10's do show up but not often and go for $80/$120 USD.
I do have the instruction sheet for the .10 but it's written in Japanese, I will try to decipher the Bore and Stroke and let you know.
Thanks Bob, but I have the sheet that came with my 45BB 6001 and it has the figures of all models available at the time.
Wow, $80+ is quite a lot, are we talking about used engines? Well, I am not going to reveal what I paid for them but it was a bargain after all.
EDIT sorry the photo is out of focus, there is a better one in the other Enya thread.
Yes, NIB engines. I forgot just what I paid used but not much off those figures. The engines in the old style blue crystal box are hard to find and more expensive.
Japanese ......
Japanese ......
Sorry if I was a little blunt earlier, it does look like the .08 and .10 engines. They seem to have many parts in common with the .06, and the marking on the bottom of the crankcase should be a reliable identifier.
If they live up to their specs they might be very strong for their weight, the .10 is possibly beating the more common .09 engines...
No worries Kris
Only differences between these and the 06 seems to be that the bigger ones have one or two fins more, as the cylinder is a bit taller due to the longer stroke. The specificied weights are pretty much the same on all three.
The specificied bhp figures really are impressive. The 08 has about twice the power of a Queen Bee and the throttled 10 kicks throttled 09 Medallion's butt. And it loses only about 10-20% to the unthrottled Tee Dee 09 on equal rpms. Of course the Enya numbers are from the brochure and Cox numbers I picked from test reports on sceptre flight.
There seems to be no reviews published about these little Enyas
