» Chocolate chip cookie dough.........by rsv1cox Today at 10:20
by rsv1cox Today at 10:07
by rdw777 Today at 9:24
by batjac Yesterday at 21:47
by roddie Yesterday at 20:50
by getback Yesterday at 12:05
by rsv1cox Wed 20 Nov 2024 - 15:21
by 1975 control line guy Wed 20 Nov 2024 - 8:17
by rsv1cox Tue 19 Nov 2024 - 18:35
by Cox International Tue 19 Nov 2024 - 12:01
by getback Tue 19 Nov 2024 - 6:08
by roddie Mon 18 Nov 2024 - 21:05
Recent engine acquisitions
Page 4 of 20
Page 4 of 20 • 1, 2, 3, 4, 5 ... 12 ... 20
Re: Recent engine acquisitions
Yes I may have read the number in haste. In fact the BW maxes out where its dark green curve intersects the brown at a bit below 16.5k
George, an unusual feature of your Cub engine. I note it has the late type cylinder which has the wider diameter at the top to accommodate a Cox-type glow head, but it seems that it has a standard type head with a glow plug installed. I would have expected that it would have a glow head, although OK Engines do include in their parts list a head to take a glow plug to suit the later cylinders. I just would have thought the adaptor head would have been produced as a replacement part rather than factory fitted from new. You just never know. OK just seems to have built engines out af whatever parts they had lying around.GallopingGhostler wrote:balogh wrote:You must know this Surestart engine mount, do you? Seems to be a more rigid, customized mount than the plastic stand-offs. http://coxengines.ca/cox-.049-engine-firewall-helicopter-mount.htmlGallopingGhostler wrote:I've found that nylon standoffs can be purchased at a hardware store, so one doesn't have to create a recess in the engine mounting area on the plane to clear the choke tube.
Hello Balogh. Yes, I am familiar with that mount. Personally, the nylon spacers were cheaper and have adequate contact area for stable mounting of the engine.
Latest acquisition from a CL friend, Bro. Dane Martin as a gift; a brand new and un-run OK Cub .049R engine.
balogh wrote:Yes I may have read the number in haste. In fact the BW maxes out where its dark green curve intersects the brown at a bit below 16.5k
Graph refers to Peter Chinn's Aeromodeller article, where that "bit below" is 15.5k. However, with higher nitro levels would shift curve upward and to the right with max bph at a higher rpm, so 16.5k might be achieved. That might explain why I had good sea level performance with a 5.25x4 prop and 25% nitro fuel. A hotter cylinder with additional bypass / widened bypass ports and lighter piston, improved subpiston induction would shift that curve, too.
But it does illustrate that the BW even with original porting remains a prized engine for powering sport models.
Oldenginerod wrote:George, an unusual feature of your Cub engine. I note it has the late type cylinder which has the wider diameter at the top to accommodate a Cox-type glow head, but it seems that it has a standard type head with a glow plug installed. I would have expected that it would have a glow head, although OK Engines do include in their parts list a head to take a glow plug to suit the later cylinders. I just would have thought the adaptor head would have been produced as a replacement part rather than factory fitted from new. You just never know. OK just seems to have built engines out af whatever parts they had lying around.
Rod, thanks for posting that, I'll have to pull of the head and check. If a Cox glowhead will fit would certainly improve performance and make this a worthy sport engine.
GallopingGhostler wrote:balogh wrote:Yes I may have read the number in haste. In fact the BW maxes out where its dark green curve intersects the brown at a bit below 16.5k
Thanks for the correction, you are right.
OK, here is the latest lot, from Finland. I had bought engines from this guy earlier, a few days ago he told me he had found a couple of TeeDees in good condition and some loose parts and also an .049 product engine. He asked 38€ incl postage. Yup, I said.
Well, the two engines were no TeeDees but Medallions in great condition. If they have ever been run, they have been meticulously cleaned afterwards. One even has a muffler. The loose parts included unused TeeDee .020 mount and a tank, an .020 glowhead, a Kavan tank kit minus one screw and also a brand new stunt tank. I forgot to put the product engine on the table for the picture but it has a slit exhaust cylinder and a brass driveplate. I think it may actually be a Babe Bee originally, since there was also a short tank and a late model metal backplate among the loose parts and tank screws too. And the horseshoe backplate had a .020 needle jammed into the plastic seal
This has got to be one of my better deals. I had wanted a couple of Medallions for some time, and I already had 4 TeeDees of this size (two .049s and two .051s). So I was pleasantly surprised to receive these. I'll pick one of them for my collection, and make the other a runner with a non-SPI cylinder and a muffler.
The hunt for .09 engines continues
Nice buy Kari. Happydad
happydad- Rest In Peace
Looking good Kari !! you will like the medallion its a easy starter and runs pretty strong , mine lifted the Stuntman 23 off the ground like a rocket compared to the Bee that was on it till I slapped it into the ground LOl . Eric
Ok, here's the latest one. I finally got that "P-40" engine, but it came with a plane attached
Well, actually it has a horseshoe engine with a slit-exhaust, no-flats-for-wrench cylinder so it is a later model. It doesn't seem to ever have had its engine running. The exhausts, the spinner, and the antenna are missing. I do have a couple of spinners so no problem there but the rest I'll have to either source or make. The rudder/fin is bent and the bellcrank is jammed inside somehow so that the elevator is stuck in the down position.
So nothing major, should be easy to sort out
Edit: the regular pic hosting service is not working right now so I used another one... The little pic is a link that leads to a bigger one.
Except for a few missing pieces, you got one in mint conditions, congrats, Kari. Cox did a really nice job on that one.
Thanks George. I am not sure what the story behind this plane is, I think it may have been a display piece in a hobby shop, or maybe it was a gift to someone who was not interested in model planes.
I noticed the ad at a classifieds site, it was listed at the "wanted" area by mistake and the price was not shown. I sent the seller an email asking about the price, and he responded 150€, but also told that he had no clue what these might be worth. He said that at least the engine must be worth something. I told him that the plane looks like it is in good condition, and definitely most valuable as a complete unit. I also told that the engines can be had for 10-20€ easily but the plane with the engine is many times more valuable. I told him that his asking price is not insane, but it is too much for me, as I collect engines, not the models, and said that I would be ready to pay 50€ for such a plane. He responded: "well if that 50€ is your offer, we got a deal". What a surprise!
It is a nice plane, a bit flimsy, a tad heavy maybe and definitely fragile. But it looks good as it is and will be near perfect once I add the spinner, clean the whole thing and free up the elevator. This one is just perfect for me, since it is not NIB , which means I can handle it, play with it and there is some things to tinker on it too. Just the way I like them.
And finally, as a warning to all diehard toy collectors, the spinner I am going to install on it is RED I have a couple of yellow ones too but I think the red one will look better
Edit: just couldn't help it. I HAD to go find the spinner and try it on
Kari, as far as I can recall, these came with a red spinner, so it is appropriate to use the color. Regarding flimsiness, all RTF's were that way back then. The plastic would easily shatter upon crashing. I found out later that balsa flew better and had better crash resilience. I never personally witnessed it, but I understand that during the 1960's, Cox would give CL flying demonstrations at Disneyland in California. That must have been some sight and helped to sell models and engines.
Maybe I confused it with the Spitfire, which, in my opinion, would also look better with a red spinner but has a yellow one as standard. The plastic is probably polystyrene, same stuff that is used for static scale models. It is not very tough, but it is heavy, soft, and especially fragile in cold. A lot of these were probably destroyed while flying in the winter here in Finland. I have no practical experience on these but it is easy to believe that balsa flies better.
Demonstrating these models in Disneyland was a great marketing strategy, reaching hundreds of kids (and dads) at one time, most of them already in "spending mood".
Oldenginerod wrote:George, an unusual feature of your Cub engine. I note it has the late type cylinder which has the wider diameter at the top to accommodate a Cox-type glow head, but it seems that it has a standard type head with a glow plug installed. I would have expected that it would have a glow head, although OK Engines do include in their parts list a head to take a glow plug to suit the later cylinders. I just would have thought the adaptor head would have been produced as a replacement part rather than factory fitted from new. You just never know. OK just seems to have built engines out af whatever parts they had lying around.GallopingGhostler wrote:balogh wrote:You must know this Surestart engine mount, do you? Seems to be a more rigid, customized mount than the plastic stand-offs. http://coxengines.ca/cox-.049-engine-firewall-helicopter-mount.htmlGallopingGhostler wrote:I've found that nylon standoffs can be purchased at a hardware store, so one doesn't have to create a recess in the engine mounting area on the plane to clear the choke tube.
Guys, just noticed this, it's a .059/.060 engine from the early 60's and yes the .060 that came in a RTF Comet plane with the glowhead, c.1958. The head on it now likely came from a mid fifties or later .049, or was assembled at factory from parts. Hard to say as Herkimer was hit or miss toward the end of production, that and they were also built from parts for the last forty some years!
I recently received my box of OK Cub parts from the OK Engines stock clearance. Lots of goodies to keep my engines going for a few years yet. Interestingly, having discussed the heads here, Ted also included (free of charge) a glow plug adaptor head for both this .049/.059 and the .024/.025. When I have a chance I'll do a comparison between how the head and the plug run. I can't see the .024 adaptor being at all successful, with that engine being pretty marginal even with the extra compression the glow head would provide. Lower it even more with the adaptor & I can't see it running too well.
KariFS wrote:Thanks George. I am not sure what the story behind this plane is, I think it may have been a display piece in a hobby shop, or maybe it was a gift to someone who was not interested in model planes.
yep i agree, the red spinner does look better! i also added the pilot.
That's a nice looking Warhawk Mark. I like the way the engine is installed in that version. Were the wheel centers painted like that originally? Mine are all black.
Again I was offered some Cox engine parts along with some other stuff. 20€ plus shipping.
Here is the package:
I thought, what the... Who ordered a pair of spare kidneys? Weird styro box with weird text on top. Anyway, here are the Cox gems from the box:
A cast crankcase assy, silly-cone muffler, a very strange custom backplate assembly, a home-ported cylinder and some other odds and ends. Together with this item that came with a bunch of parts over a year ago...
... Plus a barely used cylinder and piston...
We have the makings of an RC Bee! Extra credit to whoever is the first to point out all three parts that I forgot to put in the picture above
I had never seen one in person, it looks quite nice. Much better than in pictures that I'd seen before. I see Bernie has new tanks for these for less than 10 bucks, seems like a decent deal if you have a cast case engine kicking around. And if you don't, Bernie has those too
Oh yeah, the other stuff in the kidney transplant box were a big and heavy lump of sandblasted Soviet alloy plus a weird looking long silencer that by the looks of it won't silence much.
Now what kind of model would this combination fit anyway?
Just kidding It's an NIB Soviet-made CSTKAM 2,5cc from 1990 with its tuned pipe and original spares as supplied when new. It is rather sticky to turn over, I didn't even try, as these are known to have particles inside them straight out from the factory. So I'll take it apart and clean it up, possibly also fit new bearings. According to the documents this should be a real powerhouse, with 0.66 Hp @25+ k rpm. Some day I will at least bench run it.
Here is an example where the .15 engine fits well!
I think a have at least three of these plus some of the similar MVVS .15 engines...
They will give you a proper pylon face too ))
I'll take a WAG at the missing parts: glow head, reed retainer/gasket between tank and crankcase. I think I see a prop screw off to the right of the picture.
Marleysky wrote:I'll take a WAG at the missing parts: glow head, reed retainer/gasket between tank and crankcase. I think I see a prop screw off to the right of the picture.
Close... Hint: this engine model has the reed retainer built-in into the tank front face.
But yes, glow head is one, and the tank/case gasket is another. The third may be so "trivial" it is actually difficult to spot
Surfer_kris wrote:Here is an example where the .15 engine fits well!
That's a fast looking plane and the pipe extending out over the wing looks just bada$$
Is it a different engine model or an R/C carb retrofit? I remember seeing pictures of R/C stunt planes with pipes in the '80s, with the pipe enclosed into a removable canopy/turtledeck.
@ the pylon face... I could imagine my face would go through a full series of expressions for the 5 or 6 seconds I could handle a beast like that
The MVVS carb is a direct drop in, but the stock glow head is a little cold to give a good throttling. For me it is just nice to be able to slow things down and to land at will.
The is also an MDS .15 that is quite similar in appearance, plus the Rossi .15 which probably is what they all tried to copy.
Where the REED ??KariFS wrote:Marleysky wrote:I'll take a WAG at the missing parts: glow head, reed retainer/gasket between tank and crankcase. I think I see a prop screw off to the right of the picture.
Eric, the reed is the little shiney piece of mylar between the NV and piston, in the picture.
Ok, the other trivial missing piece has got to be the head gasket?.
Or possibly the throttle ring for the muffler, looks like a c clip with a hole for linkage.
Last edited by Marleysky on Fri 21 Oct 2016 - 13:59; edited 1 time in total (Reason for editing : 2nd guess)
Marley, you got it
The missing parts are the tank/case gasket, the glowhead and the head shim.
The engine is a beauty, very different from other Cox products. And it is the only one that has any kind of run-in procedure in the instructions... Was it 4 or 6 tanks with two different propellers on the bench before installing on a plane. I wonder if it was on account of the cast crankcase or something else?
» My recent engine purchase
» Roddie tears-down his recent bench-run engine
» Recent experience with Norvel?
» My recent disaster
» AMA membership
» AMA membership
Page 4 of 20
