Mccoy .049 Cox_ba12
Mccoy .049 Pixel
by 1/2A Nut Yesterday at 11:26 pm
by roddie Yesterday at 11:01 pm
by davidll1984 Yesterday at 8:49 pm
» Green vent..
by roddie Yesterday at 7:49 pm
by rsv1cox Yesterday at 6:59 pm
by Cox International Yesterday at 4:33 pm
» PSA propellors!!!
by robot797 Yesterday at 2:39 pm
by roddie Yesterday at 11:42 am
by roddie Yesterday at 10:51 am
by davidll1984 Wed Oct 16, 2024 6:15 pm
» OK Cub .024
by 049kid Wed Oct 16, 2024 12:31 pm
by 049kid Tue Oct 15, 2024 12:17 pm
October-2024
MauricioB's
"Cox .049 Circa 1975, custom."
Mccoy .049 Empty
Mccoy .049
Mccoy .049 Empty Mccoy .049
Post  jsesere Mon Nov 30, 2015 3:00 pm
Does anybody have a spare set? Mine broke off in the NV receiver so I would need both parts.
Thanks, Joe
Mccoy .049 00610
Mccoy .049 00214
jsesere
jsesere
Mccoy .049 Empty Re: Mccoy .049
Post  getback Mon Nov 30, 2015 3:43 pm
Joe I pressed my old one out with a punch and replaced it with a assy. from a Cox postage stamp that was broken a little JB weld to secure it and your good to go>> Mccoy .049 Wp_20110 getback
Post  Kim Mon Nov 30, 2015 5:35 pm
Yo Joe!
I may have a case assembly like that buried somewhere in the storage shed. Let me check tomorrow...need daylight to get through all that stuff !
Junk Yard Kim
Post  batjac Mon Nov 30, 2015 7:48 pm
I had an AMF Wen-Mac, pretty much the same thing, that needed a new spraybar.  I just pressed the bad spray bar out and pushed in a standard Cox product engine spraybar.  I have a bunch of them.  I didn't even have to use JB Weld or anything.  It was a tight fit after massaging the spray bar hole.  I got about 14.5K using a Cox 5x3 rubber ducky prop.  I'd consider that about average for these engines.  Here's the thread:
https://www.coxengineforum.com/t8206-follow-the-bouncing-brain
The Masseuse Mark
Post  Kim Tue Dec 01, 2015 7:12 am
Yo Joe!
Think I got you covered! Please PM me with you address (probably have it somewhere, but this makes sure I use the right one!) and I'll try to get it on it's way later this week!
Fred Sanford Kim
Post  pkrankow Tue Dec 01, 2015 11:35 am
There is a good chance the needle can come out if it is not glued in. Use a fresh heavy #11 blade and poke into the end of the needle. The metal used for needles is usually on the soft side so the knife should get some bite. A little fiddling can get teh needle to back out.
I have done this on a couple cox engines. It takes patience. When you get a turn or two out, it pays to put it down and come back 5 minutes later instead of getting overexcited.
Still need a needle though.
Post  roddie Tue Dec 01, 2015 6:36 pm
pkrankow wrote:There is a good chance the needle can come out if it is not glued in.  Use a fresh heavy #11 blade and poke into the end of the needle.  The metal used for needles is usually on the soft side so the knife should get some bite.  A little fiddling can get teh needle to back out.
I wonder if using a heat-gun might help with Phil's method? Not that the venturi area gets that hot during operation.. but if there's hardened fuel-gum in the needle-threads, it might help to loosen it. Either way.. I'm sure you'll get that engine running again!
Post  jsesere Tue Dec 01, 2015 7:05 pm
I have used both a blow dryer or boiling water with a few drops of dishwasher detergent added to loosen up stuck cylinders and glow heads.
jsesere
jsesere
