» Kofuku Maru Fishing Boat Modelby rsv1cox Today at 9:47 am
by TD ABUSER Today at 12:50 am
by 1975 control line guy Yesterday at 10:35 pm
by 706jim Yesterday at 9:32 pm
by TD ABUSER Yesterday at 2:58 pm
» Pathé Modeling Videos
by rdw777 Yesterday at 10:28 am
by roddie Tue Nov 12, 2024 3:27 pm
Gave up finding any Nelson 36s
OK Ken, Ron, and the rest of you Fox users. When I was young doing circle combat the MCCoy and Enya engines were withing my paper rout money range.... once I won a contest and the prize was a new Fox 35...hell I was in tall cotton but soon was married and kids and no flying for a few decades
Years later I started RC flying and soon learned that I really wanted to do circle burning again...found CEF, found Ron Cribs, found Ken Cook, found Rusty and all the other really fantastic folk on this web site.... eventually Ken introduced me to Jeff Dawson and Jeff introduced me to his father and a few other old time combat and stunt fliers....Full on hook in mouth! I got the fever!
BUT...what the hell...!!!!
There no real way to get good equipment.... lots of folks flying F2D on ARF planes and recipe engines....
But 1/2a is not supported well, fast combat is dying, and few are supporting the hobby outside of some few clubs and Bob Mears (who I have not met yet but will soon)
Ok OK!!! You all know me as long winded (sorry)
I lost a lot of money trying to get a 1/2a cyclon engine from Russia
I have a bunch of bucks in NV and FORA and Picco engines for 1/2a ( and great aircraft from Ken and Jeff)
I do not want to gear up for F2D or speed limit ( this may change in time)
I DO want to fly fast combat 36s but failed finding the hot Nelson 36s
So I am focusing on old skool Fox 36X Mark series acquisitions
I have a worn out 35 stunt and several Enya 35s 5224s
I have a well preserved 36 X Mark VI
I have the means to win a couple of the current 36 Mark ?? series on e-bay auctions
I want opinions, advice, and references for folks like Lew Wollard and Doug Galbreath
Is it true Clarence Lee passed and can not tweak engines for us any more?...are there folks to fill his shoes?
Fred
wants to go FAST
Fred
wants to go FAST
help with Fox 36 Mark VI
I recently won this engine and need advice:
FOX .36 Mark VI ABC Combat Special Control Line Engine, Used, excellent condition, never run on pressure, Smooth bearings, excellent compression, Double-Bubble head
Full comp. main bearing ,Double oil grooves machined in piston (see photo)
Super Tigre needle valve assy, McCoy MC-9 glow plug, Milled exhaust port and head fins.
Milled mounting lugs for slight offset.
On case is FOX C
On mounting lug is RP (Not RR as photo seems to show)
This engine has never been mounted on a plane or stand (I know engines very well and have a fairly high power loop and the mounting lugs have never seen a bolt inside nor a nut and washer squish)
This motor has zero drag and has the most compression of any 35 or 36 I ever hand propped over
So the questions... how do I set it up for bladder? ( it has the insert and NVA in upper position)
I read all the other threads on here and RC groups on break in...does this engine need any special attention?
On case is FOX C
Re: Gave up finding any Nelson 36s
Fred, someone already massaged that engine. The MK VI is ABC engine if you weren't already aware. The crank is larger than the earlier MK engines and should be propped with a 8x6. APC makes the 7.8x6 which uses the D-1 hub. That's incredibly important D-1. DON'T run that engine on a Master Airscrew prop unless you desire a trip to the emergency room. Woodies will work, I would just use caution. Your safest bet is the APC and not the sport versions. The Tiger needle in that engine will take bladder pressure. If it doesn't work, the OS 1A R/C needle will work but you will have to do some bracket fabrication. Remove the needle and take out the restrictor reinsert the needle. That engine will run fine on 10% nitro but can easily handle 40%. Plugs shouldn't blow but if they do, see Jeff for head shims. That head had it's fins milled off so that tells me someone already did their homework on the engine. The head buttom should be the double bubble hemi. Use a high pressure bladder which is the thick wall. No restrictors within the tubing anywhere. You will probably see 112-116 mph flying a 500 sq foamie. Ken
That engine looks like one mean chunk of aluminum Fred! Very nice.
I see Fox .36X engines all the time on Ebay. Grabbed one for myself for $22.
Thanks for the information...now to relearn about prop hubs.....crap this stuff gets complicated for an old guy with CRS! grin
Fred, another suggestion that works well is the mist for priming. Suck fuel into your syringe and and squirt it back into the container. Before running, have the bladder filled. Don't purge the bladder, there's no reason to do so with this engine. Point the venturi to the ground with the wing straight up and open the bladder. Adjust your needle so that fuel is dripping to the point of a steady stream. Just before your ready to start it, lower the piston and prime with the misted fuel. Don't overprime the engine with raw fuel. It will want to run backwards. Rotate the prop clockwise bringing the piston up to TDC. Hook up battery and smack the prop backwards and it should fire right off. Wear a glove. and one other thing, wear a glove. Important tips, don't use a ni charger on this engine. This can be a violent engine. If that pops off not only can it knock your teeth out, it could severely injure the one holding the plane who may release it unwantedly. Get behind the prop as soon as it's running. If this means pinching the bladder line until you can get a needle setting, then do so.
Seeing that your attempting combat, one important factor that I would recommend would be hand placement on the plane itself. Not only for you, but for your launcher. This engine is LOUD and it becomes extremely difficult to communicate to your helper if need be. Wear ear & eye protection. You should place high vis tape or high vis paint on your leading edge which is placed on a safe area away from the prop area. Seeing that many combat planes have their engines recessed into the leading edge, this is a helluva a lesson to learn if your not aware of it. Certainly an engine to be well respected. Ken
Sounds like one scary mean engine.
These engines (well any engine really) but these buggers can surprise the hell out of you until you help start and launch them a few times
Last year for combat camp they used OS 25s for practice on the big planes and surprisingly they do a good job of hauling them around a 60' circle...They taught me how to hold and launch them
Later at the bladder grabber I got my first experience with the Nelson36...serious loud and mean engine!
Most pilots had them well adjusted and the prime and start with one flip was normal for most...only guys having trouble were almost all from bad plug or low battery.. First day there Jeff brought his predator with a Fora on it and I launched....then he hooked up a Nelson powered plane to the lines and it was the first Nelson I held to launch.... surprising torque as it fires and burns the prime until bladder released......you get real about hand placement and prepare for the sudden pull forward as your pilot is directly in front and will get seriously injured if you don't pay attention!
The hardest thing I had to learn was how to tweek the needle as the pilot heading on a run for the handle and the engine sagged, sputtered or went too lean...My left hand was around the leading edge out side of prop circle and I had to release my right hand to tweek the needle or pinch the fuel line.....right elbow in front of leading edge was needed to hold back the plane
Most pilots don't want you even touching the trailing edge as the soft foam will take a set from your hard grip and screw up the inner or outer wing flight....some planes have a real spar to the tail feathers and you can hold that but many are just a wing and the elevator is ON the trailing edge
At the end of the contest Mel Lyne brought out a balsa plane with a Fox 36 Mark VI and let 80+ year old Bob Carver (of professional audio gear fame and biggest sponsor of the Bladder Grabber) fly a few tank fulls ....I was seriously impressed that Bob could have competed very well with the Fox and the older style airplane. I was also happy to know that the FOX timed and tuned correctly can be relatively competitive with the Nelsons
So thank you gents for the tips and advice
Think I will do my training this spring with full sized Fast combat with 25 on front. First, to preserve the hard to find fast engines, and also because I think I would have to seriously redesign my stooge to hold back that much forward power
Which OS 25's were they using?
Jason_WI- Top Poster
FP's or FX's would be my guess.
Any of the ball bearing OS's. The late FSR's, the newer FX's. ASP's and Magnum XLS's which are clones to the OS. The FX is by choice due to it's weight which is essentially the same as the Nelson .36. Propped with a 8x5 and 52' lines, a 500 sq foamie will be at 100 mph.
While the FP does work well for us 75mph max flyers in the northeast, it doesn't have the power that the ball bearing versions have. Although, some of the competition here has made Nelson heads for the FP and done some porting mods which send the rpm's over the top compared to stock. Ken
» What a friend gave me.
» the bell crank gave way doing a figure 8!
» I mounted my new Tee Dee .049 on a test block and gave it a spin.
» Friend gave me Two Spark Ignition Engines -- Converted
» Need help finding
» Need help finding
