» Kofuku Maru Fishing Boat Modelby rsv1cox Today at 9:47 am
by TD ABUSER Today at 12:50 am
by 1975 control line guy Yesterday at 10:35 pm
by 706jim Yesterday at 9:32 pm
by TD ABUSER Yesterday at 2:58 pm
» Pathé Modeling Videos
by rdw777 Yesterday at 10:28 am
by roddie Tue Nov 12, 2024 3:27 pm
McCoy 0.19
McCoy 0.19
Never could get this puppy to run.
Maybe the cylinder liner had been installed backwards?
706jim- Gold Member
Re: McCoy 0.19
3 srews hold the cylinder on a Mccoy. I don't think it can go on backwards due to the way the screw holes are triangulated. I presume your talking the Mccoy red head stunt? Many issues are apparent with these engines. I would highly suggest if all other factors are good, plug, fuel, needle valve not blocked to take a look at the head gasket. The head gasket and the cylinder base gasket were fibre paper. You could remove them both which can be a job in itself if their stuck hard to the surface. I would use high temp Permatex Ultra Copper in place of the new gasket. Replace all head screws using 4-40 socket heads. The 3 longer screws that hold the cylinder in place may need approx 3/32" ground off of them is you use a 1" long screw. The screws that came with the engine are poor quality and will strip out due to not being able to finding a screwdriver that fits them correctly not to mention their dead soft. Doing so will lower the deck height thus raising the compression further. Use Permatex on the backplate making sure the nylon button is in place on the conrod. Ken
Re: McCoy 0.19
There's something going on with 706jim's engine. The Testor McCoy .19 Red Head I have is very easy to start with plenty of power, usually starts within the first several flips. One thing that the instructions state is the needle valve needs to be opened 5 turns. Also, break in prop is an 8x4 or 9x4.
Jim, which McCoy .19 do you have? There were several different models of .19, from the early Duromatic .19's, front and rear rotor venturis, the Red Head, and Series 21 Black Head.
If You got the Red Head, I have the instructions, can E-mail them to you.
McCoy 19
Thanks for the offer, but the McCoy is long gone. Sold it to an unsupecting friend back in 1965. I think it had a red cylinder head but don't remember it having a box or instructions. However, if you can email them to me, it would be nostalgic to read them. Being fairly new on this site, did I provide an email? If not I can.
706jim- Gold Member
Re: McCoy 0.19
I left you a private message a couple days ago, Jim, I don't have your E_mail address. A scanned image of the Testor McCoy .19 manual may also be had at:
Stunt Hangar - McCoy .19 Engine Instructions Post
If link doesn't work, you may have to register to be a member of stunthanger.com to see, but it's there.
