» Tee Dee .020 combat modelby getback Today at 7:14 am
by getback Today at 7:02 am
3D Printing
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Re: 3D Printing
How not to smooth an ABS print - I dipped the part in acetone. I was really pleased it went smooth and shiny --- then as it dried the newly formed skin bubbled and blistered!
Anyway, I took the opportunity for a slight redesign - smaller with less curved edges and I am ready to continue
Any ideas what it is going to be? It is something to do with model aeroplanes!
Re: 3D Printing
It progresses! - more clues
The dog isn't very interested either!
Re: 3D Printing
Dang! I thought it was an arrow shaft linkage connector in the 12/5 post. No Idea now though.
Re: 3D Printing
Assembled
Re: 3D Printing
Drive for a car?
Re: 3D Printing
No gears inside. Just a shaft running through two bearings.
Re: 3D Printing
Then axle for a car. Gonna get some suspension?
Re: 3D Printing
It's one of those thingies with
all the little bits attached.
dckrsn- Diamond Member
Re: 3D Printing
No sane person could even fathom what goes on inside your mind, so how are we supposed to guess at what comes out of it?
Re: 3D Printing
Well really! Implications that I'm bonkers!
Here it is ready to use.
He'd fly through the air with the greatest of ease, That daring old man on the flying trapeze.
Re: 3D Printing
I was only kidding of course....we love ya Ian!
Hmm, model airplane storage? Some kind of hangar hanger perhaps?
Spray paint lazy susan?
Re: 3D Printing
So it is a sort of center of gravity measuring device?
Re: 3D Printing
pkrankow wrote:So it is a sort of center of gravity measuring device?
A very accurate centre of gravity measuring device?
Re: 3D Printing
ian1954 wrote:pkrankow wrote:So it is a sort of center of gravity measuring device?
It seems you type with a British accent. (center vs centre)
Yes, on reviewing the video I see the function of it.
Re: 3D Printing
However, don't let the previous video fool you into thinking that the plane was nose heavy.
It was tail heavy - how do I know? I had a disastrous flight with it after following the instructions on the kit for the CoG position! It said 100mm (4") behind the leading edge. I thought it strange and soon found how uncontrollable a tail heavy aeroplane is! Followed by the walk of shame!
You set the trapeze so that the model is at its flying level position or (tech. speak) its datum line is horizontal.
Once level, the plumb line will indicate the centre of gravity. These pictures are after adding 15g of weight to the front.
Re: 3D Printing
So...why does it need to rotate freely?
Re: 3D Printing
Interesting question? Hope I can explain.
The strings are looped around the bobbins to prevent them slipping but the bearings allow the plane to settle. The strings are then adjusted on the plane to bring it flight level. As you move the strings the bobbins turn freely but the string doesn't slip.
As you adjust the strings and the plane stays level (it is still free to rotate) the plumb bob indicates the C of G.
Add weight to the nose and the plane will tip forward.
Adjust the position of the strings on the plane again to bring it level and the plumb bob will indicate the new C of G further forward.
The strings must not slip freely or the plane will nose down or tail up!
Simply sliding the strings forwards or backwards on the plane brings it level and the freely rotating bobbins automatically adjust the strings so that the bobbins are directly over the C of G.
The freely rotating bearings allow the minutest adjustment, the bobbins (and the loop around them) prevent the strings slipping.
The C of G is not indicated until the plane is level.
Re: 3D Printing
So how big of a TD do you want to make?
Jason_WI- Top Poster
Re: 3D Printing
Well, I'll be darned.
That looks very good Jason! What color is it? It appears to be grey in the picture.
Re: 3D Printing
It is white. Bad camera lighting. I need to modify the part to make the venturi support a bit thicker. It likes to collapse during the print even with support. This was scaled up 2x from the original file which I got off of grabcad.
Re: 3D Printing
That is a nice looking print - I am having trouble with small prints collapsing or looking too "stringy" but the larger ones are coming along a treat.
When I get a little more time I will post a few more pictures.
I joined Gabcad the other day but find "searching" on there a little difficult.
Re: 3D Printing
Ian, I keep starting to ask questions about your C/G locator, but hesitate and think more about it. Suspension string location, mostly. Very interesting.
Re: 3D Printing
RknRusty wrote:Ian, I keep starting to ask questions about your C/G locator, but hesitate and think more about it. Suspension string location, mostly. Very interesting.
The way it works is simple but more complicated than it looks. I have a few more planes to balance and I will video it (when I get the time - busy finishing things off so that I can tidy up for Christamas!) because it is very accurate. I find it better than the Great Planes thingy I have as it works with very light models. The Great Planes thingy needs planes of a certain weight.
» PT-19 3D printing
» Printing on Tissue
» Printing out .pdf plans to scale
» 3D printing nonstop
» Todays Cox 3D Printing Adventures....
Page 1 of 4
