3D Printing - Page 3 Cox_ba12
3D Printing - Page 3 Pixel
by roddie Today at 1:34 pm
3D Printing - Page 3 Empty
3D Printing
Page 3 of 4 Previous  1, 2, 3, 4  Next
3D Printing - Page 3 Empty Re: 3D Printing
Post  ian1954 Sun Dec 22, 2013 3:38 pm
pkrankow wrote:
Cribbs74 wrote:Could one just suspend the model by a single string at the CG point and add or remove weight to make the plane level?
Yes.  Using fingers, pencils, or other under the wing support is another option too.
This is just a different way to skin the cat, so to speak.
I suspect this would function without the bearings, or any other added fanciness.
I mark the wing to do a quick check using fingers just before flying. On a large plane though, it is difficult to use arms, sight for level and make adjustments.
I tried wobbling a plane on two pencils with rubbers (sorry erasers) on the ends. Not easy if the wing is cambered and doesn't have a flat surface.
ian1954
ian1954
Post  pkrankow Sun Dec 22, 2013 3:39 pm
Now THIS is a keeper!
If its not obvious, a continuous loop of yarn (first string type I found) laced through the clothing hanger to hang evenly. The broken propeller half is the plumb bob, held by a second piece of yard the around the hook of the hanger, and passed over the wire, and under the crossing yarns. A slipped overhand knot secures the prop and allows for easy adjustment of its height to the plane.
3D Printing - Page 3 Img_2019
Post  ian1954 Sun Dec 22, 2013 4:35 pm
pkrankow wrote:Now THIS is a keeper!
That is a brilliant demonsration of the principle and would suffice for most practical purposes.
However, and this requires some thought, the friction between the yarn used and the coathanger together with the weight of the aeroplane may affect the accuracy.
If you take the set up as pictured an tilt the plane slightly. Does it stay in that position?
If it were heavier, could it remain stationery at an angle?
If it can then because the plane is level on the trapeze it may not mean that it indicating the balance point.
ian1954
ian1954
Post  pkrankow Sun Dec 22, 2013 5:27 pm
Yes, the plane can be tilted, carefully, as the strings do not move and there is considerable friction. The bob remains pointing at the same position. Verifying by supporting the wing from below the balance point is the same position as indicated in the photograph.
I hope this is a little more clear. The string is laced around the hanger braces, down, and back again around the hanger braces. With a light load it won't slip. It also means the plane wing slides on the string, instead of the string sliding on the hanger.
3D Printing - Page 3 Img_2020
Post  pkrankow Sun Dec 22, 2013 5:42 pm
Ah HA! A "Vanessa" machine!
http://home.mindspring.com/~the-plumber/Vanessa%20CG%20Machine.htm
http://www.rcuniverse.com/forum/tips-techniques-180/708060-vanessa-c-g-rig-how.html#post708060
Post  roddie Sun Dec 22, 2013 5:45 pm
Wouldn't this work with a single pulley? Balanced is balanced... right? Extend the pulleys' axle, to hang the plumb-bob.
(edit) I'll expand on that... one string with slip-loops on each end, that cradle the "fuse" fore/aft the wing; would accomplish the same thing, wouldn't it?
Roddie
Post  Mark Boesen Sun Dec 22, 2013 6:22 pm
I see where this is going, a person could make a 2x or 4x scale model of a Babe Bee!
Post  pkrankow Sun Dec 22, 2013 6:25 pm
I think we need a mod to split the CG machine portion out to a separate thread, if the OP is onboard.  That way this thread can return to 3D printing, and the CG discussion can continue separately.
feel free to delete this post when a decision is made.
Post  pkrankow Sun Dec 22, 2013 6:33 pm
roddie wrote:Wouldn't this work with a single pulley? Balanced is balanced... right? Extend the pulleys' axle, to hang the plumb-bob.
Roddie
Don't need a pulley.  All that is needed is a sling to hold the airplane, and a plumb bob from the same support point.  This could be done with a single hook, except it would bind against fancy paintwork, so separation is desired.
The plane in the sling is one pendulum.  The free hanging pendulum is obviously a second pendulum.  The two originating from the same point mean the CG of both systems are in line with each other.
Because the orientation of the suspended object doesn't matter (people use this for race cars and boats too), but the plans are marked in the way they are, usually from the LE of the wing, having the plane level makes it easier.  Leveling the horizontal stabilizer is the most simple manner described in the linked thread on RCuniverse, as when the plane is flying level, with no elevator input, the horizontal stabilizer will be level.
Having the sling adjustable by turning the support rod means re-leveling the H. Stab after adding weights or adjusting components is much easier than sliding against friction.
Post  ian1954 Mon Dec 23, 2013 6:40 am
Hi Phil,
I tried out the coat hanger approach this morning and it works rather well.
Unfortunately, I tried it out with my "Max Thrust Riot" and the coat hanger snapped. Luckily it was dangling only 2ft above a bed at the time.
Looks like I will have to print a coat hanger around a steel frame  Laughing
ian1954
ian1954
Post  ian1954 Tue Dec 24, 2013 4:17 pm
This resembles my face when the coat hanger snapped!
3D Printing - Page 3 Christ10
ian1954
ian1954
Post  pkrankow Tue Dec 24, 2013 4:24 pm
ian1954 wrote:This resembles my face when the coat hanger snapped!
That is awesomely grumpy. Looks like me before coffee in the morning.
Post  pkrankow Tue Dec 24, 2013 4:32 pm
ian1954 wrote:Hi Phil,
Coat hanger might be a little weak on something heavy...I'm probably going to swap out the coat hanger for something better soon. I see my hanger breaking if I hang something much heavier than this decathlon on it.
Post  RknRusty Tue Dec 24, 2013 4:38 pm
pkrankow wrote:That is awesomely grumpy.  Looks like me before coffee in the morning.
Or me, after eating a green persimmon.
Post  ian1954 Tue Dec 24, 2013 4:40 pm
I think for a simple approach - a 2" x 2" block of wood drilled through for a broom handle (1" diameter). A really good hook then screwed into the block. That would be strong enough.
ian1954
ian1954
Post  Jason_WI Wed Dec 25, 2013 12:18 am
Some iphone cases I printed for xmas gifts. The gears are printed seperate then the pins are glued in to hold the gears in place. They turn pretty smooth.
3D Printing - Page 3 B6F0033F-DC51-481C-86B1-C0E30C878524_zpsrpgzz5fb
3D Printing - Page 3 DDE8B9B0-9BA9-47F7-9760-D52447597D00_zpsqrdsb1vw
Jason_WI
Jason_WI
Post  ian1954 Wed Dec 25, 2013 2:26 am
The finish looks superb and the phone case is smooth. My prints are all still rough looking but I am perservering.
Marvellous job Jason.
ian1954
ian1954
3D Printing - Page 3 Empty Battery holders
Post  ian1954 Mon Jan 06, 2014 4:22 pm
3D Printing - Page 3 Wizard46
Now mounted
3D Printing - Page 3 Wizard45
ian1954
ian1954
3D Printing - Page 3 Empty Electric motor mounts
Post  ian1954 Mon Jan 06, 2014 4:25 pm
3D Printing - Page 3 Jive_010
3D Printing - Page 3 Jive_011
ian1954
ian1954
Post  Jason_WI Mon Jan 06, 2014 5:04 pm
Looking good. Is that still ABS? What percentage of fill you you normally use. Most of the stuff I print is 40% infill but on large objects I might drop down to 25%.
Might need to build up a boss around the hole for the battery mount to beef it up. Would hate to loose a battery midflight!
Jason_WI
Jason_WI
Post  ian1954 Mon Jan 06, 2014 5:12 pm
In these items the fill is solid. All ABS.
I did a pull test on some sample battery brackets I made and it took some effort to break one.
The rods on the motor mount will have steel thread rods running through - with lock nuts on the engine bracket and blind nuts on the firewall. Length still to be decided when I balance the plane.
ian1954
ian1954
Post  Cribbs74 Mon Jan 06, 2014 8:28 pm
Pretty good looking stuff Ian!
Post  pkrankow Tue Jan 07, 2014 6:51 am
The battery hanging off the bottom is not going to be helpful for stunt. It is shifting the CG low. Otherwise looks good.
Post  tru168 Wed Jan 08, 2014 7:26 am
Hi,
I just ordered Reprap Pro Ormerod from RS component, still waiting for delivery.
two things which I'm keen to know,
1)temperature of crank case might too high for ABS motor mount. anyone successfully run an engine on printed ABS mount yet?
2)ABS fuel proof?
ew
tru168
tru168
Post  ian1954 Wed Jan 08, 2014 4:40 pm
I have run both diesel and glo engines on mounts made from ABS and they appear to be fuel proof. Only time will tell!
I have seen no engine crankcase heat cause any ill effects but ABS starts to soften at around 90 deg C and melts at 105 deg C. The mounting lugs don't get that hot but the cylinder definitely does.
However, they dissolve readily in acetone and, over time, will absorb water. I can't say how long something printed with ABS will last or if it degrades.
ian1954
ian1954
