Engine loading questions... Cox_ba12
Engine loading questions... Pixel
by Ken Cook Today at 3:23 am
Engine loading questions... Empty
Engine loading questions... Empty Engine loading questions...
Post  roddie Sat Sep 07, 2013 11:50 am
I realize that all engines have a max. "design" rpm... and engine "mods." can improve performance. I have heard that; on the Cox engines, it's the ball/socket joint at the piston/conn. rod, that will fail; under too heavy loading... followed by a broken "crank-pin", in extreme cases... I.E. "diesel" conversions.
Stay with me here... because I know this forum consists of mainly "flyers"... and some of my questions could apply to aircraft applications.
I've wanted to try an .049 "reed-valve" engine in a "marine" application (water prop) and I have the "Dumas" kit; complete with flywheel, 1" dia. prop., U-joint, shaft/stuffing tube... that was designed for an .049... but may be more "well suited" to a Tee Dee (rotary-valve) engine.
Question #1. Can a stock reed-valve engine be used "with success", using the Dumas "drive" kit in a model of similar specs. for which the kit was designed?
Question #2. If I didn't have the Dumas running-gear kit, and wanted to try making my own; does the "flywheel" have the most influence on performance... or does the entire running-gear's "rotational-mass" including the Dumas 1" prop.; need to be duplicated? Perhaps a larger dia./steeper-pitch prop. with a lighter weight flywheel would work... Anyone ever try this?
Question #3. Which condition is worse for the engine; "under-loading"/over-revving or "over-loading"/lugging? Will either; result in merely a weakened ball/socket joint... or will more severe damage result to the engine? The "former" can be remedied by re-setting the ball/socket joint with the Cox tool.
Question#4. Does frequent re-setting of the ball/socket joint come with consequences... other than the chore of engine dis/re-assembly... or should this only be done once or twice; before replacing the piston/rod assy. and/or cylinder?
Question #5. Does running a "Killer-Crank" in an otherwise "stock" (glow ignition) .049 engine, cause the ball/socket joint to loosen sooner... or affect the top-end rpm?
I naturally don't expect any "one" member to address all these questions... and I realize that there are other variables involved. I'd just appreciate some feedback.
Thanks, Roger
Engine loading questions... Empty Re: Engine loading questions...
Post  Cribbs74 Sat Sep 07, 2013 12:36 pm
roddie wrote:I realize that all engines have a max. "design" rpm... and engine "mods." can improve performance. I have heard that; on the Cox engines, it's the ball/socket joint at the piston/conn. rod, that will fail; under too heavy loading... followed by a broken "crank-pin", in extreme cases... I.E. "diesel" conversions.
Thanks, Roger
Roger,
I can only answer questions #3-5
Over revs will kill an engine quicker than anything depending on the parts installed. I say that as if you use a KB crank or similar you can spin the engine a lot faster. Usually the crank is the first to go either up front or the pin. I have never seen a problem with losing the ball socket. Sure it may need reset from time to time, but basically the same piston is used in the reed valves and TD's
A KB crank will rob some power, but not a lot (more mass)
You can reset a ball socket many times as long as you do it properly. Usually once they are set a couple times they hold and need no further reset.
Post  roddie Sat Sep 07, 2013 1:47 pm
Thanks, Roger
Roger,
Thanks Ron, good to know. I'd like to try a throttled reedie in a super lightweight RC "out-rigger" hydro I've been designing (huge variables involved here...I know...) It will be subject to intermittent "over-revving" if it gets up "on plane". Maybe the KB crank would be a good idea.
some project photos
Engine loading questions... Rog-ri10
Engine loading questions... Rog-ri11
Engine loading questions... Rog_ri10
Engine loading questions... Cox_ba11
That's a custom flywheel I made for the engine. it's a little lighter weight than a Dumas flywheel. I modified the tank to use a 1 oz. external one. The muffler is the same design in the "build" article that I submitted to Bernie for his Sept. emag issue.
Post  pkrankow Sat Sep 07, 2013 1:49 pm
I answered them all, but 1&2 are not my area.
1: I don't see why not. I'm not a model boat guy though. (Full size is a different story.)
2: The flywheel help prevent over-reving when under no load (like in the cars) and carries the engine through the exhaust part of the cycle when there is load. There is a range of working amounts of rotational inertia that will work. Basing on a proven system should make sure that you start in that range.
Changing the system can reduce or improve performance, depending on the desired definition and measure of performance. Change your measure or your definition and the same system will evaluate differently.
Again, not a model boat or model car guy.
3: Over-reving will destroy an engine in pretty short order. Over loading generally will stall the engine or slow the engine, which will reduce maximum stresses by slower operation.
4: Work hardening will eventually come into play. (These engines never get hot enough to re-crystallize the metal.) Ron stated after a couple resets they tend to not need them anymore. This might be a result of said work hardening.
5: A heavier crank will slow the engine due to more rotational inertia. I doubt it would affect the ball joint any.
The heavier crank may allow for a lighter flywheel though, but that would depend on your definition of performance.
Post  roddie Sat Sep 07, 2013 2:39 pm
pkrankow wrote:I answered them all, but 1&2 are not my area.
Thanks Phil, I'm learning a lot here!!! The marine app. will take lots of patience... because it can only be tested in the water. I will be using a venturi throttle; which should help keep the revs at bay... both; under "no-load" (start/tune/launch) and "if"...... it gets up "on-step" and starts to skip on the rear-tips of the sponson's, with the prop running 1/2 out of the water; as it "ideally" should.
I'm going to bench-test the engine/throttle/flywheel combo soon, using a radio and a test fixture that will allow running the marine prop "wet" in a tank... with the stuffing tube running through a rubber grommet, to seal it. stay tuned!!!
Post  roddie Sat Sep 07, 2013 3:17 pm
Has anyone "over-revved" an .049 resulting in damage to it? How did it happen?
I had a Baby Bee on a test-stand years ago... (many...) with a thin alum. 2" dia. "louvered" fan disc bolted on... (don't try this) When the engine started... it was screaming for about 1.88879 seconds... Affraid or WOW!  the disc and screw flew off, and were never found. Shh  The engine however; was not damaged... I was lucky... further tests involved Cox props....
