2 engine questions Cox_ba12
2 engine questions Pixel
2 engine questions Empty
2 engine questions
2 engine questions Empty 2 engine questions
Post  akjgardner Tue Apr 07, 2015 7:03 pm
2 engine questions Img_0110
2 engine questions Empty Re: 2 engine questions
Post  akjgardner Tue Apr 07, 2015 7:06 pm
Is there an easy way to tell an .049 from a .051 and what is this one.thanks for the help
Post  stuntflyr Tue Apr 07, 2015 7:50 pm
051's have red cases, black for 049's.
Chris...
stuntflyr
stuntflyr
Post  fit90 Tue Apr 07, 2015 7:51 pm
A Tee Dee .051 piston will have a ring around the bottom. It can be seen through the exhaust opening if you bring the piston up near top dead center.
fit90
fit90
Post  Cribbs74 Tue Apr 07, 2015 8:06 pm
Both the above points are correct. Just keep in mind apart from the color of the carb body and the ring around the piston skirt they are identical.
I say this as it's easy to swap parts around. Look for both the ring and the carb body color. From a glance though the carb body color is a dead give away.
The one in the picture you posted appears to be an .051, to be sure though you would have to remove the muffler and look for the "ring around the skirt"
Post  Jason_WI Tue Apr 07, 2015 8:24 pm
Should also have a 5 stamped in the exhaust port flat.
Jason_WI
Jason_WI
Post  akjgardner Tue Apr 07, 2015 8:53 pm
Thanks for the help,I picked that up at a flea market for 10 bucks, I was hoping it was a .051,that would be my first.
Post  TDbandit Tue Apr 07, 2015 9:28 pm
Another thing, if it has the TD P/C set, I would take the muffler off anyway if it has SPI the muffler will choke it out. It will run but will have little power. (Bandit)
TDbandit
TDbandit
Post  akjgardner Tue Apr 07, 2015 9:50 pm
It looked like it had a ring around the bottom of the piston but it had a 4 stamped on the exhaust port
Post  Oldenginerod Tue Apr 07, 2015 10:09 pm
Post  TDbandit Tue Apr 07, 2015 10:13 pm
akjgardner wrote:It looked like it had a ring around the bottom of the piston but it had a 4 stamped on the exhaust port
If its a 4 that's the .049 the .051 piston would not fit in a #4 the #5 is the TD cylinder set with a slightly larger bore. Here's a pic of my 051 showing the ring on the piston skirt. Hope this helps (Bandit)
2 engine questions Td051_10
TDbandit
TDbandit
Post  akjgardner Wed Apr 08, 2015 5:16 am
Thanks for all the help,Joe
