» My current avatar photoby roddie Today at 8:48 pm
by 1975 control line guy Today at 8:05 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by Levent Suberk Today at 2:10 pm
by rdw777 Today at 10:28 am
by layback209 Today at 1:20 am
by rsv1cox Yesterday at 6:55 pm
by roddie Yesterday at 6:20 pm
by roddie Yesterday at 3:27 pm
» Octura engines?
by UncleLumpy Yesterday at 8:16 am
» Tatone EM-7
by sosam117 Yesterday at 7:50 am
Need to identify this engine (Please look at page 2)
Hi, I tried to find out which engine it is. But I like to ask the experts here to be sure.
It has a thimble drome mark on the tank. On the backplate is written Made in USA.
This engine was built in a cox cl warhawk from 70`s. The plane looks like never used (no castor oil or other residues), but the engine might be. I am wondering if this original, as I also never have seen this combination before (with a muffler).
coxaddicted- Gold Member
Re: Need to identify this engine (Please look at page 2)
Looks like a QZ .049.
From Mr. Hepperle's Site:
http://www.mh-aerotools.de/airfoils/cox_frameset.htm
Thanks a lot. So it could be original fitted in a cl warhawk I think.
I just bought another engine at ebay (and maybe I will buy a couple of engines if the price is not too high). If it does not bother anybody, I will post it here after receiving it.
That would be a Super Bee from a P40 Warhawk. A Babe with dual bypass ports. I had a P40, but for some reason I can't locate the tank with Thimble Drome printed on it. When I was a kid, one of the carwash workers nabbed a Bee out of our back seat, maybe that's the one I'm missing.
Is that a high compression head? (there would be rotary knurling on the top of the head)
Can you get the cylinder off? Some numbers/letters would help.
No, I can tell by the shape of the combustion chamber in the third picture that it's a standard compression head.microflitedude wrote:Is that a high compression head? (there would be rotary knurling on the top of the head)
The prop and spinner look like they are from a P40 Warhawk, but I don't remember any p40 having a muffler.
All the Super bees that I remember had the heavier crankcase snout on them, as well.
But I am old and my memory is not as good as it used to be, so...um...what were we talking about again? OH yeah, the bee.
lousyflyer- Gold Member
Yes indeed, I also never seen a engine with muffler on a warhawk, therefore I ask.
Maybe the thief who stole RknRusty's the bee installed it into a brand new warhawk, shipped it to europe, waited a couple of years and sold it to me.
The head has no knurlings. I tried to disassemble the engine, but the cylinder has no keyways for the cox-tool. How do you remove the cylinder with a gripper? Sorry for those questions but I do not want to ruin the engine
There are a couple ways.
Strap wrench or leather strip and pliers the leather strip bring wrapped around the cylinder and the pliers around that.
That is the only way pliers are to be used on these engines
Hope that helps
Hope that helps
Oh wait, there is another way a bit riskier but, soft wood either side of the cylinder clamped in a vice would work.
Easy on the clamping force though.
'n solvents n' heat (Lösungsmittel und Hitze: thanx to babelfish!)
ahrma_581- Gold Member
Okay people, I'm gonna start a rash of people telling me I'm nuts.
A Cox wrench that hasn't been warped or bent, slips over the exhaust ports without touching the inner edges that get galled and interfere with the piston. But it's so soft that it spreads when you apply pressure to a too-tight cylinder and mars it. BUT... if you clamp the whole wrench, including the fork, into a vice tight enough to keep the fork from from spreading, slip the upside down cylinder into the forks while holding the crankcase, and unscrew it, it works every time and will never gall your exhaust ports.
Okay, you may pile on now.
As a last resort, after heating the crankcase with a
small torch, I have used a wrench through the exhaust ports.
Works like a charm.
I would never admit it though............
Works like a charm.
dckrsn- Diamond Member
Will the standard Cox wrench fit through the slot in the muffler housing? I haven't had one of those mufflers for quite some time.
Stick it in the oven at 350F for about ten minutes and the aluminum crankcase will heat up faster than the steel cylinder, allowing the threads to loosen up.
I'm almost sure you have a post 1962 Babe Bee with a muffler added later on. Does the engine have SPI? Is it a double bypass?
I have tried many different ways to remove cylinders, the one that seems to do the best is a leather strap wrapped around the top of the cylinder several times and then very slowly tightened up in a vice grips. If it is on there too tight for the vice grips to loosen it, I use my small torch to heat around the threads on the crankcase and then try again.
Oh yeah, I forgot about that muffler blocking access to the exhaust ports. Throw that thing in your box when you get it off, they don't do much anyway. Besides, iirc, a Super Bee has spi.
Thank you all for your answers. I did not get the cylinder off, it is really tight. I have a little gas torch but no bench vice (but I will buy one).
I will carry it off in a few days, I hope.
I have seen through the crankcase, that the cylinder has open exhaust ports and 1 bypass port with no bypass bosters.
I have also seen through the muffler, that somebody already tried to get the cylinder of with the cox tool as described above.
So it is clear that the engine was opened from a previous owner.
Heat helps
It is a #2 stamped on the cylinder
Yeah, you have a Babe Bee that someone put a muffler on. I would say around the early 1960s, so far the details would say it is a post 1962.
That's a great Babe Bee. I learned to fly control line with the same type engine mounted on a PT19 trainer.
As written before I received another engine purchased from Ebay.
I already search at Mr. Hepperle's Homepage regarding the modell but I like to ask here to be sure.
It looks like a product engine from the 70's but i am surprised about the exhaust port (it is slotted)
Here is a picture:
Thank you in advance
Here is a picture:
That's a later product engine, later cox engines had slotted ports.
nitroairplane wrote:That's a later product engine, later cox engines had slotted ports.
Thank you!
» Identify this engine
» Please can someone identify this Cox engine?
» Can someone identify my Cox engine.
» Please help identify this engine
» Can someone identify this engine?
