» My current avatar photoby roddie Today at 8:48 pm
by 1975 control line guy Today at 8:05 pm
by balogh Today at 4:39 pm
by TD ABUSER Today at 2:58 pm
» Pathé Modeling Videos
by Levent Suberk Today at 2:10 pm
by rdw777 Today at 10:28 am
by layback209 Today at 1:20 am
by rsv1cox Yesterday at 6:55 pm
by roddie Yesterday at 6:20 pm
by roddie Yesterday at 3:27 pm
» Octura engines?
by UncleLumpy Yesterday at 8:16 am
» Tatone EM-7
by sosam117 Yesterday at 7:50 am
Gunk and Goobers
Gunk and Goobers
While digging in the garage I came across a "box" of old Cox engine parts... kind of like a gold mine. Some are easily 40 years old in that I haven't used this type of engine for a long time. There are .049s, parts of .020s and some 'non-descript' pieces.
They are covered in ... for lack of a better word... goobers. Kinda sticky like old fuel, dust, and such. The parts and engines are in good shape other than that.
What can I use to soak these items in to get them clean... and then, what can I treat them with before assembly and attempts at operation??? I long for the scream of a Bee.
Much appreciated. Been modeling for over 6 decades... yup, not kidding, and still at it. That is why I know these parts are old.
Older than Dirt Dave
Dfairchilds- New Member
Re: Gunk and Goobers
Dfairchilds wrote:While digging in the garage I came across a "box" of old Cox engine parts... kind of like a gold mine. Some are easily 40 years old in that I haven't used this type of engine for a long time. There are .049s, parts of .020s and some 'non-descript' pieces.
Ironically, the "goobers and goop" is what saves them and keeps away corrosion! If you soak them in a closed container of glow fuel, for a while, then take a firm-bristled toothbrush to them, they should clean up just fine. Light machine oil will work just fine to lube them before their "first" run since retirement.
And...Welcome to the Forum !!!!
I found that denatured alcohol works quite well and a old toothbrush. I've never had an issue with plastic parts using this. Ken
I like denaturesd alcohol too. Just make sure to dry and oil any parts cleaned with it IMMEDIATELY after cleaning to avoid rust.
Welcome back,
Welcome back,
fit90- Diamond Member
Thanks
Bob, Ken and Kim....
Thanks very much for the timely replies. I am looking forward to learning soooo much more on this forum and total website. I will try both techniques this week.
OtDD
Older than Dirty Dave
OtDD
A good way to free up stuck pistons is to put a prop on the engine and place it in front of a blow dryer set to high and let it cook for several minutes. The heat will melt any dried castor oil allowing you to move the piston. Once it gets loose add fuel to the top of the piston. Another area where castor will clog is between the prop plate and the crankcase neck. Squirt fuel there also.
Have fun, Joe
Have fun, Joe
jsesere- Rest In Peace
May I add my welcome to the forum, Dave?
Wilf
Wilf
Ivanhoe- Diamond Member
Oh, and...
NO PLIERS!!!!!!
(traditional welcome to the forum)
NO PLIERS!!!!!!
ahrma_581- Gold Member
